Question about Maytag Dryers
New Maytag MED5707TQ dryer purchased. plugged in and it ran for about a half hour. Stopped and won't start. seems to be power getting to back of dryer when plugged in. any ideas?
  • 943 Answers
Thanks for the question you need 2 30 amp fuses to run the dryer i would check your breakers or fuses it needs 240 volts thanks the appliance doc
Posted on Sep 18, 2008
Some cloths got stuck and jamed the drum now the drum will move or start
hello lks.. pry off the top of the machine and check the belt. chances are that this jam either stretched or broke the belt. Joe
Apr 28, 2011 | Maytag MED5707TQ Electric Dryer
I need to install a 4 wire plug
The following link explains how to properly install a 220VAC power cord on your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Jul 01, 2010 | Maytag MED5707TQ Electric Dryer
The heater element stopped working in the middle of the drying cycle and now will not heat up. What are things I need to check?
Check that there is 240vac present. Check the thermal fuse on the blower housing. Finally check the condition of the element.
Eric
Jun 13, 2010 | Maytag MED5707TQ Electric Dryer
Maytag MDE8600AYW takes way too long drying clthes
either your house vent is plugged, or the vent in the dryer by the blower is plugged. when the vent is plugged, even partially, the moisture is not leaving the dryer. It will take a long time to dry, and the top of the dryer will get hot when the vent is plugged. Clean the house vent and check down below the lint trap by the blower, then it will dry fine again.
Oct 09, 2009 | Maytag MDE8600AY Electric Dryer
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Our dryer ran for about half an hour and then stopped running I opened the door shut the door and you can hear the timer but when you go to push the button to start it it will not start. Any suggestions?
sounds like the overheat circuit breaker popped for safety. when the unit cools it will work again. most likely problem is your vent out is blocked, or lint filter full. once i found a birds nest on the exaust outside lol.
Jun 14, 2009 | Maytag PYE2300AY Electric Dryer
Older washer/ dryer with no power
Check to see if power cord is loose at connection inside dryer. ONLY after UNPLUGING! Held on by three screws inside.
Aug 22, 2006 | Maytag PYE2300AY Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
