Question about Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi dlp 62 wd-62527 will not turn on
I have replaced the buld and about a month later it will not turn on please help
  • penry207 Jan 07, 2009
    The Light under the Timer button flashes green all the time and the set will not turn on
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
Slinteriors
  • 8617 Answers
SOURCE: i have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blin
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Posted on Sep 26, 2008
  • 1779 Answers
SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Posted on Feb 14, 2009
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
  • 126 Answers
SOURCE: Mitsubishi WD-62527. Dark picture.
That unit is a two mirror set. Meaning the light engine lens shines down onto a small mirror and that is reflected onto a large mirror and then onto the screen. Gravity being what it is dust and other contaminants cover the lower mirror. Moving the set would only aggrevate dust settling on it. To fix the problem the screen must be removed and the mirror cleaned. You won't believe the difference. It will be like watching a new tv.
Posted on May 28, 2009
Screen Removal - Mitsubishi WD-62527
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
Aug 01, 2009 | Mitsubishi WD-65735 Television
Blue clouds in the screen of a Mitsubishi WD-62527
i have had similar problems before for me it was caused by a strong magnet on the floor below me. i suggest looking around for a strong magnet that could cause the problem
Jun 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
Feb 02, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Mits wd 62327 "NOT WORKING"
I recently repaired a Mitsubishi DLP for a similar symptom. Found C9a37 and C9a38 in the power supply to be defective. They feed the light engine driver. The power supply module is located all the way up front on the left side of the chassis looking from the rear. The module is also shielded so you will have to remove the shields to locate the capacitors. The value of the caps are 3300mf/25v. Good luck
Dec 14, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Jul 15, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD62527 62 in. LCD HDTV Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
