Question about Dell Inspiron 6400 Notebook
No battery power up
Works fine with ac but no dc(battery) power up,any time ac is removed laptop is dead.battery is reading 91./.battery charging light is blinking pick and green
    Scholar:
  • 110 Answers
If the battery is more than a year old its time to get a new battery. Try a good known battery and see if that does the same.
Posted on Sep 17, 2008
The adapter light is on when first plugged in but then when I connect the adapter to my laptop the light goes off and it doesnt supply any power
I suggest check out the AC adapter first.
1) When plugged into power, and plugged into the laptop, gently wiggle the cable from the AC adapter TO laptop.
Any change?
Do the same on the power cord TO AC adapter.
NO?
Go on.
2) The port on the laptop that the plug from the AC adapter plugs into, is the DC Power Jack.
If we are discussing an Acer Aspire 5738Z Notebook PC, the DC Power Jack resembles this one, (Not installed),
http://www.batterysupport.com/acer-aspire-5738-jack-p-302046.html
(When I note the DC Power Jack, it is this link I will be referring to )
As you can see there is a Center Pin. All power removed from the laptop, use a small wooden, or plastic object, and see if this pin moves around.
ANY perceptible movement means a bad DC Power Jack.
DC Power Jack checks out it's back to the AC adapter.
Wanted to perform the easy diagnosis first.
This will require a multimeter. An economical, yet fine for this test multimeter, can be purchased for as little as $8 to $12.
Available in a multitude of stores. An auto parts store is but one example.
Analog or digital is fine.
http://www.youtube.com/watch?v=bF3OyQ3HwfU
(Analog is fine. Some of us still like 'em)
DC Voltage is what you are going to check.
Black probe lead (Negative) goes in the Common port on the multimeter. (COM)
Red probe lead (Positive) goes in the Voltage port on the multimeter. (V)
If the multimeter just has symbols around the Function Knob, set it to the dotted line over a solid line, symbol.
The plug on the end of the AC adapter, that plugs into the laptop, has a center hole, and a cylindrical metal shield surrounding it.
The Center Hole of the plug is where the red Positive lead, of the multimeter goes.
The outside cylindrical metal shell is where the black Negative lead of the multimeter goes.
Hold the AC adapter plug in one hand, and at the same time hold the red Positive multimeter probe in the center hole.
With the other hand touch the black Negative lead of the multimeter, to the cylindrical metal shield on the outside of the plug.
You should read 19 Volts (DC), or VERY close to it,
http://www.cellularfactory.com/laptop/ACER/3/305268/
I believe the AC adapter is the problem. Post back in a Comment as to your findings.
Regards,
joecoolvette
Apr 29, 2012 | Acer Aspire 5738Z-423G32Mn Notebook
My sons power pack died leaving laptop with dead battery. small light flashing orange at the front .i bought a replacement power pack making sure it was for his model.plugged it in and nothing it wont...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 25, 2011 | Advent 4211c Notebook
My advent battery would not charge so i bought a new one and it still wont charge having to run my laptop from the mains
Mar 12, 2011 | Advent Netbook
Dear people, I have a acer aspire 8930g laptop. through the battery it works fine. Through the electric cable he strikes out every time. I opened the laptop and cleaned the fan. Fan is working but...
Feb 19, 2011 | Computers & Internet
Dell 1720; battery meter says plugged in not charging. The comptuer is running fine. 91% left in battery. Already checked device manager, drivers, wriggled the charger cable, plugged in and out several...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Your response is very much appreciated...
Feb 15, 2011 | Dell Inspiron 1720 JetBlack T5450 Laptop...
Battery problem not working or the power button not working,,Why?
Feb 09, 2011 | Toshiba Computers & Internet
Its that the battery is not charging, and on the power meter icon its blinking four times orange and one time green. If I remove the battery, the laptop works with ac adapter. but if I reinstall the...
Check for a DC connector problem:
Feb 06, 2011 | Dell Latitude D610 Notebook
My laptop battery i guess hit critical stage but now the system wont work with ac power
Jan 26, 2011 | Acer Aspire 7520-5185 Laptop
Computer is not charging the battery.
Your DC connector is probably loose from the system board:
Jan 05, 2011 | ASUS F8Sn-C1 PC Notebook
My toshiba satellite pro doesn't work , even with charger in , it doesn't turn on , its like all the power is gone :o ?
You may have a bad DC connection:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Toshiba Satellite A60 Notebook
Dell Inspiron 6400 Notebook Logo
47 people viewed this question
Alun Cox
