Question about Frigidaire FRS26R4A Side by Side Refrigerator
Side by side frigidaire . 1994 Model # MRS22WRAW1
Water keeps filling up at bottom of freezer. I Have checked ice maker for leaks and none. Dont know what else to do.
Mark
I found a drain tube that came from the freezer to the pan where the fan is.
I have had this problem for at least 3 years . I have finally resolved it . Thanks anyways. Mark
Posted on Sep 19, 2008
I have a KitchenAid side by side fridge, type 25SSA, water is leaking from bottom of ice maker down front of freezer and into ice bin, how do I stop leak?
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know.
http://appliance911seabreeze.com/
Nov 14, 2015 | KitchenAid Refrigerators
Frigidaire glrs264za ice in freezer
The ice-maker supply line enters the back of the freezer near the top. There is a rubber piece that fills the ice tray, attached from the outside. If that is cracked you will have a leak. There is also a water line that runs through the refrigerator to the reservoir that supplies chilled water at the door. All of these lines should be checked for leaks that can drip into the freezer compartment.
Apr 01, 2014 | Frigidaire GLRS264ZA Side by Side...
Loose fill tube on ice maker Maytag side by side
Please look around your refrigerator fresh food section door frame for a model number. I believe the reason water is leaking inside freezer is a defective water control valve that you attached to with water line on back of most refrigerators.
I am here to help just let me know, Thanks Sea Breeze
E-Mail
Nov 20, 2012 | Maytag Refrigerators
Water dispenser does not shut off
That is most likely a dual water control valve stuck open on back of refrigerator near floor. One side feeds ice maker and other side feeds the water dispenser. If the ice maker side began to leak slowly it would create quite a mess of ice flowing over ice maker and freeze every place it could inside the freezer. Part and Model Search If helpful Please Rate this solution, Thank You, Sea Breeze
sea_breeze_260.jpg Refrigerators
Freezers
Washers and Dryers
Oct 18, 2011 | Frigidaire Refrigerators
Fill tube to ice maker keeps freezing up. Replaced double water valve and worked good for a week. Stopped up again today and found a leak in elbow going up to water in door. Would this let water leak into...
1.Check water pressure is lower than actual. Turn it full flow.2.Check water filter, replace it if over dust particles. 3.Freezer setting may be very low. Increase it. Better to keep in 5 degree always.
4.Inspect the water hose from one end to the other. If there are parts that are bent or pinched, the water will not be able to pass through and chances for get freezes. Thanks.
Jan 24, 2011 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water leaking from freezer door and ice maker not gettin water
Check the fill tube for the ice maker and make sure it is in the correct place. This sounds like the fill tube has been moved and is running water into the freezer instead of the ice maker. Let me know what you find. I am here to help you.
Nov 12, 2008 | Frigidaire FRS266ZDSB Side by Side...
Frigidaire, ice on floor of freexer
check to see if the defrost drain is not frozrn over or stopped up
this is the only way that water can get into the freezer
frost could and melt but dont think that i would check the drain at the bottom of the rear freezer panel if you see ice it is stopped up for sure
if all is clear there go to the ice maker, have had some that are overfilling and runnig over the ice maker into the bottom of the freezer
Jun 23, 2008 | Refrigerators
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
90 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
