Question about Canon FAXPHONE L80 Laser
Inoperative fax and telephone line
I have a 2 line telephone, a Canon L80 fax machine and a 2 line answering machine, All were hooked up and working optimally --- with telephone line 1 Optimum Voice (internet) and line 2 Verizon (standard analog carrier).
I just changed line 2 to Optimum Voice and with the same *hookup, I get no dial tone on line 2 and cannot send or receive faxes, Bypassing the fax machine, I get a dial tone on line 2 - but of course have lost use of the fax machine. Any solution? Si Kreindler sibearzy@optimum.net
*Hookup - Line 1 to answering machine to telephone.
Line 2 to fax to answering machine to telephone
  • Si Kreindler Sep 23, 2008
    Kevin's solution is simplistic connect line to telephone and all is OK if there is a dial tone. I have done that as part of testing both tel lines 1 $ 2. They work but - sorry, Kevin's response does absolutely nothing to solve my problem. Gentlemen, I need help. Tks
  • Si Kreindler Sep 24, 2008
    Sammy Expert - thanks for the tip but answering machine is totally empty of messages. There has to be a more technical reason. Thanks.
  • 2,071 Answers
Check for the phone line,see if you have a dial tone,if no dial tone,call your service provider. Make sure the phone line that is connected to your fax plugged into the slot marked by the "L" on your fax machine. if not make the correction. If so then plug in your phone into your fax machine labeled with a picture of a phone and see if you get a dial tone and be able to fax.
Hope it may help you;
Regards,
VOTIT
Posted on Sep 24, 2008
    Sergeant:
  • 264 Answers
If you are getting no dial tone when the Fax is plugged in to the Network and you have the dial tone when the fax is unluged. This can also happens smetimes if your answering machine is full of messages.
Kindly check the same and delete if your message box is full
    Sergeant:
  • 241 Answers
Well I can sure help You
Posted on Sep 23, 2008
  • 1 more comment
  • Jayson Brollini
    Jayson Brollini Sep 24, 2008
    HI, I have a VOIP internet phone and a Standard. My fax machine was having
    a problem with faxing in general. But I had to go into the settings on my Fax
    and change the page output rate(bps) By default the Fax Machine is set to
    the Highest speed 26000 bps or even higher. I changed mine to 12000 bps.
    My dial tone was there but when I switch to the VOIP that is when I started to
    have all these problems.
    • Check to make sure that You have the VOIP going into the correct Jack on the Fax Machine.
    • If You still have no dial Tone
    • See if your VOIP phone settings has a option to for output (Phone/PC Speakers/)
    • Still no dial tone
    • Switch back to the LAN line and see if you are getting the Dial Tone
    • If no Dial tone is present then the setting on the Fax Machine are causing the problem
    • I would do a Factory Default Rest on all the settings. Make sure that you write down
    any phone numbers/contacts etc.
    • If there is a Dial Tone with the LAN Line then You have to change the settings on the VOIP service etc.
    I sure hope this helps you
    you may rate my solution if you found this helpful
    Thank You
    Jayson
  • Jayson Brollini
    Hi Just checking back,
    Did are solutions help you
    locate the problem?
    If you still need assistance please leave additional comments.
    Thank You
    Jayson
  • Jayson Brollini
    Jayson Brollini Sep 26, 2008
    Good Luck
    Genius:
  • 1,847 Answers
Try connecting line 2 to a simple phone and chk for dial tone.
Posted on Sep 22, 2008
  • Legin Varghese
    Legin Varghese Sep 22, 2008
    if you dont get dial tone yet, then the issue is with the pstn line. contact the service provider.
Cannot receive faxes
Make sure that the telephone line from the wall is plugged into "LINE" and not "PHONE" on the fax machine. You might also call the fax number from a different phone to see if you can hear the fax tones.
Aug 20, 2009 | Canon FAXPHONE L80 Laser
Faxphone L80
have it hooked to phone only . can not figure out how to hook it up phone keep ringing when you answer the phone and it's not a fax
Apr 15, 2009 | Canon FAXPHONE L80 Laser
I just changed over to one phone line and need to now use my fax
Phone symbol. The line port is for the telephone from the wall jack.
Dec 30, 2008 | Canon FAXPHONE L80 Laser
Fax line stays busy continously...
Are there any other phones that use that line? If you have a phone attached to the fax machine, is the reciever in the holster all the way?
Jul 06, 2008 | Canon FAXPHONE L80 Laser
Telephone callers get fax sound even when fax is in manual
Sounds as though you are answer ing a phone that is not connected to the unit and you have the Man/Auto switch set to on. Press Function then Data Registration press Set using the > scroll to RX Settings press Set scroll to Man/Auto Switch make sure it is turned to Off.
Apr 21, 2008 | Canon FAXPHONE L80 Laser
Canon Fax phone L80
If it is a dedicated fax line it is probabaly best set to fax only mode. Fewer rings (No more than two) FaxTel mode will ring for longer to allow you to pick it up if its a phone call.
Check if the machine has dial tone by onhook button or handset to check. If you have none try testing with another phone to rule out the machine.
Try a manual reception. Pick up the phone when it rings and press the start button.
Jan 31, 2008 | Canon FAXPHONE L80 Laser
Fax is inoperative
The incoming telephone line was out of order need to call the phone maintenance to fix telephone line.
Jan 10, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Still a problem? Can you be more specific?
Jan 29, 2007 | Canon FAXPHONE L80 Laser
Hooking up a fax machine on home telephone line
Well... the problem is that you are running two machines on one line. ONE of them has to take predominance. Both machines should have settings for "number of rings to answer at". It sounds like you currently have the fax set to less than the answering machine, so the fax picks up after two rings, while your answering machine might be set to more, which it never gets to, because the fax answered the call already(It doesn't matter if you answer the phone, or the fax picks up, once the line is open, the answering machine is taken out of the equation). Even if you set the answering machine to answer first, you're then taking the fax service out of the loop. I'm not sure how you're going to juggle that, since both types of machines each need control over the line to work properly. That's why we (business machine folk) always recommend a dedicated line for fax service.
Jan 23, 2007 | Canon FAXPHONE L170 Plain Paper Laser
Canon FAXPHONE L80 Laser Logo
276 people viewed this question
old marine
old marine
