Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Drier, doesn't turn, doesn't heat, but dings.
My Maytag drier is 40 years old. It neither turns nor heats. But every few minutes it makes a loud click (I think that's supposed to be the bell.) It clicks more frequently on damp dry.
  • 943 Answers
Hi thanks for the question i would check the power coming to the dryer it looks like its only getting 110 check that the appliance doc
Posted on Sep 18, 2008
Drier is running hot, smells like my clothes are burning, and it keeps blowing the fuse in the main panel.
Most probably a venting problem and probably caused the heating element to ground out in its casing. Easiest way to verify is turn your timer to 30min and if dryer starts heating without pushing the start button you got a bad element caused by bad venting most of the time.
Apr 16, 2013 | Estate TEDX640JQ Electric Dryer
Drier won't heat
try replacing hearter wire under drier
Apr 08, 2012 | Whirlpool Dryers
The signal dings at end of drying cycle but dryer keeps on running without heat
The drier works fine and heats during the cycle and then when the cycle is over the heat quits but the drier keeps running? Does it shut off when you open the door?
Aug 08, 2011 | Samsung DV330AE Dryer
Drier turns but no heat (electric drier)
dsd
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 30, 2010 | Maytag Dryers
Dryer taking to long to dry cloths, all vents are clear
sometimes a element that heats the dryer breaks giving it only power till were it broke /then will cause no or very little heat these run about 30-34$ depending on what type of brand of dryer you have
Apr 10, 2010 | Maytag PYE2300AY Electric Dryer
Td 4212 w Drier is not heating
Check if it still turns but no heat. If it's a kenmore or whirlpool, it's like a fuse in back of dryer. I would need mor info if it's not these models
Jul 28, 2009 | Zanussi TD4212W Electric Dryer
No heat
make sure the drier vent is cleaned out of all the lint including under your filter screen in the drier all through the drier hose and out the vent to the outdoors
Apr 23, 2009 | GE Profile Prodigy DPSR513GA Dryer
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Estate dryer kicks off circuit
you can check where the cord is connected to the drier did you use the cord off your old drier see if the cord is tight at the back of the drier and the center terminal of the cord should be on the center of the terminal block and why did you buy a new drier hold my rating till were done please
Jan 30, 2008 | Estate TEDX640JQ Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
103 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
