Question about One For All URC-8080 Remote Control
URC-8080 UPGRADE I have three device upgrades currently stored in my remote, BUT the last time I sent the remote to the company, they knocked out a previous upgrade: MSC AUD 263. The company (Universal Electronics) now claims they no longer have the software to do upgrades....& in any event I think my memory is maxed out. HELP!!!! Get to me @: penelopeantelope@ca.rr.com
I need to program my sanyo with this one forall
Posted on Sep 17, 2008
Bt vision box
you must call to the company supplier for to see if there are a problem with the upgrade, in the signal or model, and adjust.
If the problem is o.k so can reset the r.control in menu to factory default. Otherwise you must the TV with some repair shop TV for fix it. However you must setup in the MENU to go factory default. Retest any cable dirty or corrosion, clean it with solvent cleaner contacts, buy it from any stores from supplier electronic devices, like computer, etc
God bless you
Jul 12, 2013 | Televison & Video
Tip
URC-R6 Remote Code Entry
AVEX URC R6 Universal Remote Control Entry
Follow these steps to program your URC R6 Universal Remote control:
  1. Turn on the component you want to program.
  2. On the AVEX R6, press the Component button that you want to program and the SELECT [SEL] button at the same time. Hold down both buttons for 2 seconds until the TV Component LED light turns on. This signals that you are in programming mode.
  3. Enter the three digit code for your component. If this is the correct three digit number, your device will turn off.
  4. Press the component button you just programmed (in this case TV) one more time to save the code number. The component LED light will blink three times to confirm that the code was successfully stored.
I hope that helps.
____________________________________________________________________
URC-R6 Manual Download
on Jul 14, 2010 | Universal Remote Control R6 Remote Control
Tip
I hope that helps.
on Jul 14, 2010 | Televison & Video
My problem is that when i start to open the game. I always have sent a message the application failed to initialize properly (0x00000ba)
error message usually caused by glitch in software
best to first look for upgrades online and install them as they scan current to upgrade
if that doesn't work then reinstall original watch for error messages on install and contact company for advice
Feb 11, 2011 | Computers & Internet
Lost code booklet for my oneforall remote
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Sanyo TVs is: 0154.
The codes for RCA DVDs are: 0522, 0571, & 0717.
The codes for Magnavox DVDs are: 0503, & 0675. These may or may not work with newer Blu-Ray players. Since you have two disc players, you will need to reassign the CBL/SAT key to act as a second DVD key.
I don't believe the URC-3021 stores codes for surround sound amplifiers: it has only three function buttons: TV, DVD/VCR and CBL/SAT.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Feb 13, 2010 | One For All URC-3021 Remote Control
Need program code and instructions for a memorex DVD player to program my One For All URC-9910 to a Memorex DVD player
The original instructions do not list Memorex as a maker of DVD players.
One forum says it might be DVD 0695, 0831, or 1270, but does not say if that was before or after a code upgrade from One For All.
Search for URC-9910 to find a complete instruction manual.
Also try "SEARCHING FOR YOUR CODE", although tedious, it may work:
1. Turn on the TV and or device to program.
2. On the URC-9910 remote control, press and hold
SET until you see the display change from the
current device and time to [CODE SET].
NOTE: To exit programming at any time, press EXIT once or
allow 30 seconds of inactivity to lapse.
3. Press the DOWN key on the 4-way pad once until you see the display change to [MAN SEARCH].
NOTE: If you go past [MAN SEARCH], press the UP key one or
more times to return to it.
4. Press SELECT once to begin programming.You will
see the display change to the last-selected device
and its code (e.g., VCR and 0035).
5. Press a desired device key once (e.g., DVD).You will
see the display change to the desired device and the
first code in the manual search list (e.g., DVD and
0047).
6. Aim the URC-9910 remote control at the device
(e.g., DVD) and press SELECT once.You will see the
LED (red light) blink and the (IR) icon flash
indicating IR codes are being transmitted.
7. If the device (e.g., DVD) turned off, skip to the next
step. If it did not turn off, aim the URC-9910 remote
control at the device (e.g., DVD) and press the UP key
once to advance the manual search to the next code
(e.g., DVD and 0054).Again you will see the LED (red
light) blink and the (IR) icon flash.
Repeat this step as often as needed until you find a
code that turns off the device.
8. To save the working code, press SELECT once.The
display will confirm your entry with [SUCCESS] and
then [EXIT SETUP].
Aug 10, 2009 | One For All URC-9910 LCD Remote Control
GotomyPC Intermittent connection
had same prob. 3 wired an 1 wireless . wireless would not conn. an others lose connection . after cable upgrade it was in router upgrade changed settings in router i had to call maker of comps an get them to reset ip adds took almost 3 hours to get them all working again they will do a remote access help by useing your ip threw your internet company hope this helps
Aug 07, 2008 | Belkin (F5D5231-4) Router
2 remotes....same problem
try a firmware upgrade if a firmware upgrade doesnt work, try e-mailing them from www.logitech.com go to contact us and send an e-mail:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Apr 04, 2008 | Logitech Harmony 880 LCD Remote Control
Insignia NS-1UCDVD DVD Player Code
This Remote is UPGRADEABLE. Please CONTACT 330-405-8616 To get your remote reprogrammed for new devices and brands.
-----CALL THIS NUMBER FOR MORE CODES.....THIS REMOTE'S CODES ARE OLD.....CALL TO UPGRADE FOR FREE
Feb 21, 2008 | Televison & Video
One For All URC-8080 Remote Control Logo
94 people viewed this question
Top One For All Televison & Video Experts
Electro Med Services...
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
