Please replace you OK pad with new one. Over time this pad can be deteriorated and need replacement.
Regards
It could be a battery issue. Make sure you inserted it properly and the battery door is closed tightly. Also make sure that the battery is fully charged or new. Try removing the memory card too, then turn it on. Remove the battery too, then replace it back after a minute then turn it on again.
Is a hardware malfunction. May be the button or the Board.
I recommend disasembly the camera
remove back cover
remove the buttons and check for obstructions
Clean the contacts buttons wiht a soft cloth.
With the back cover and button remove.
Turn ON and press directly the Menu swicth (gold circle in board)
