Question about Car Audio & Video
MOPAR DVD Rear Seat Video setup menu Query
installed in grand Voyager: the manual describes the process to change the "RATING" under the setup menu ! a password is required, (thats no problem)
However the defination of "RATING" is unclear !
Does this have anything to do with setting a different region code for DVD's (say from Asia / Europe / USA etc)?
the menu options are:
Level: 8 no limit
7
6 ....etc..
..... 2
1 All Limit
What could "Rating" Mean ?
Ultimately i would like to set the player to paly disks from all regions (i.e. Multi Region dvd player)? Any Solutions?
silly girl
  • 513 Answers
SOURCE: I would like to know this dvd player can play in europe
I couldn't find any info on this players region code, but most DVD stores carry DVDs from all regions, and many players today can play DVDs of any region. To be sure call the local DVD store that you like and ask them what region DVDs they have. Hope I helped ;]
Posted on Mar 30, 2006
hogan doan
  • 227 Answers
SOURCE: region code
Contact manufacture and address the problem. Let me know if they would help.
Posted on Mar 10, 2008
  • 105 Answers
SOURCE: multi region code
This is not possible without bypasssing/cracking the firmware on your DVD player. your player will generally allow 3 changes to the region code. If you have not changed yet, you may do so within the DVD player's setup options.
Posted on May 03, 2008
futureloginn
  • 734 Answers
SOURCE: Unlock region codes for portable dvd player - panasonic DVD LS80
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Posted on Nov 11, 2008
quang123
  • 107 Answers
SOURCE: change dvd player region to multi region
Try this procedure
. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
Posted on Dec 05, 2008
What auto transmission fluid do i put into chrysler grand voyager se
If you read the back of any trans fluid bottle, it tells
you what it is for
Chrysler uses ATF+4 in most cases
If you have a drip stick, it should be stamped on it
Owners manual is a must if you own a vehicle &
you can always check with dealer service dept
Oct 19, 2012 | 2000 Chrysler Grand Voyager
Truck lock is jammed by briefcase strap. can i get into the trunk from the back seat? such as does the back seat fold down?
I searched the owner's manual and there was no mention of folding the rear seats down. If you don't have a manual, you can get one here: http://www.extendedgmwarranty.com/owners-manual/buick/1999-Buick-Century.pdf
You can remove the seats following the instructions below from autozone.com.
Rear Seats
SEAT CUSHION
Fig. Typical W-Body rear seat cushion removal
  1. Locate and remove the small bolts at the front lower edge of the seat cushion.
  2. Pull the tabs on the rear cushion retainers.
  3. Remove the seat cushion by lifting up and pulling out of the retainer.
  4. Installation is the reverse of the removal procedure. Make sure the retainer tabs are snapped into place. Tighten the bolts to 18 ft. lbs. (25 Nm).
SEAT BACK
Fig. Typical W-Body rear seat back removal
  1. Remove the seat cushion as described above.
  2. Remove the anchor nuts securing the rear seat retainer at the bottom of the seat back.
  3. Grasp the bottom of the seat back and swing upward to disengage the offsets on the upper frame bar from the hangers.
  4. Lift the seat back upwards to remove from the vehicle.
  5. Installation is the reverse of the removal process. Make sure the hooks on the seat back are properly installed to the hangers. Tighten the anchor nuts to 89 inch lbs. (10 Nm).
Nov 07, 2010 | 1999 Buick Century
I have a 1991 grand caravan the right front half shaft keeps breaking i changed the shaft,caliper,rubber brake line,metal brake line.
Two things, if you get a vibration when you are decelerating( an indication of shaft problems) you may need to replace your 3 motor mounts. But more important, most aftermarket rebuilt shafts are junk. Buy only new or Mopar rebuilt axle shafts. Anything other than Mopar new shafts or Mopar rebuilt shafts(sometimes Mopar rebuilt can be bad too) and you are pretty much guarantying that you will be replacing the shaft again with in 6 months. I own a 1993 Voyager and have replaced a dozen axles. The problem stopped with the OEM parts. Forget about the lifetime warranty offered with auto store axles, unless you enjoy replacing axles.
Aug 18, 2010 | 1991 Dodge Grand Caravan
Mopar DVD player in Chrysler Voyager
where can i get a replacement dvd remote, for a chrysler voyager, without going to dealership?
Oct 06, 2009 | Car Audio & Video
Denon Avr-588 setup
dojran,
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
smeags
Jan 03, 2008 | Denon AVR588 Receiver
No system setup menu on screen
its related to the control AVI switch inside on the right side with the contact and 7 Ri sisters.
about 200.00 something to repair.
I can help with some money do you have the reciever still???
Jan 04, 2007 | Denon AVR-1706 Receiver
Ilo DVDR05
To change from p-scan back to i-scan with no video picture, mu1 model: 1.turn dvd on with no disc, wait 10 sec. 2.press "setup" 3.press "down arrow"(selects audio/video) 4.press "enter" (selects audio/video menu) 5.press "down arrow" 4 times (selects scan mode) 6.press "right arrow" (selects scan menu) 7.press "up arrow" (selects interlace mode) 8.press "enter" (should see picture) Or find a tv with p-scan capability.
Nov 30, 2006 | iLO DVDR05 DVD Recorder
Car Audio & Video Logo
870 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
