I often have to unplug my router and re plug in order to connect to the interenet. This has just recently started. What is going on?
    Sergeant:
  • 300 Answers
Many things could be causing this ..
1. Defective Router
2. Defective Power Supply.
3. Router Thermal Shutdown due to Over Heat.
4. Plain ole user error.
5. Computer error
Routers are offten subject to these issues.
Computer error is what I suspect is happening to you.
1. Download ALL of the windows critical updates and service packs
2. keep your computer and the router cooled off , keep the room temperature down to 75F
3. Check everything to see if things are getting too hot. if anything is getting too hot to touch it's too hot normaly computer components should not exceed 145F sometimes more than 100F will cause
things to start shutting down.
Heat and DUST are the enemy.
4. make sure your computer is clean.
5. Once you've gotten all that straight , it's time to start digging
The very first thing to do is call your ISP to make 50000% certan that you have configured
your router and your computer exactly as they specify.
a router configured incorreclty can cause a loss of connection.
Thank you for using FixYa!
Az.
Posted on Sep 18, 2008
Internet not working
Make sure the router is set to DHCP to avoid any IP conflicts. This may be caused by connecting a switch before the router and blocking the routing table.
Jun 11, 2013 | D-Link Computers & Internet
Won't connect online
This just happened to my siste and a frind of mine recently. It can be a few things.
Are you connecting via wire from your laptop or wireless? I'm hoping they did not remove a wireless router and not explain this to you.
With a new modem your main IP address would change. First I would try turning off everything, unplug the modem and any connected switches or routers. Wait at least 10 minutes, better yet, unplug them and go to work, go shopping etc.. Then plug the modem back in, wait 2-5 minutes, plug in any routers and switches, wait 1 minute then turn the laptop back on. See if that solves the problem.
Nov 19, 2007 | X-Micro Technology (XWL11GRIX) Router
Dropping internet connection
Yes like all equipment a router can go bad. Watch the lights and try to see if it is power cycling when you loose connectivity. Some other things to look at would be: Have you moved it?New wireless device nearby (like a new cordless phone)Has someone in the area put in a garage door opener recently?The list goes on and on, however if you have not had any changes the router could be bad.
I hope this helps
Jan 27, 2012 | NetGear WGT624 Wireless Router
I purchased a d-link device (model:dir-615) and i can't get it to install i am toddler in computer working
first you need to plug in your router to the internet with the ethernet cord from your modem once you have done this reset your modem by unplugging it or pressing reset button. Make sure your modem has completely rebooted, Then with another ethernet cord connect your router to your comp then turn on your router. Now once your router has completely booted up type http://192.168.0.1 into your web browser and hit enter. A login screen will appear and the default login is just admin, leave the password black. Now once you have done this there should be a link for setup wizard or it might be "wireless set up wizard". Click on that and follow the instructions. the only part you might be unsure of is the part where it asks you what type of interenet you have I do not know what you have but the large majority are dynamic and during setup it should be the default setting. After the setup is done you should be good to go GL
Jul 25, 2011 | D-Link Computers & Internet
Hey i recently bought a new PS3 connected ps3 to ethernet cable which is going directly into router, when i do interenet connection tests it says that its connected and ip adddress is working...
Tel me what is the model of your router. ? Who is your internet service provider. ? For voice assistance....Just cal this number right away im online here.... +1 760 284 4601
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
I have just brought a netbook from ebay for my daughter for xmas and when i tried it yesterday it was working fine but today it not connecting to the interenet the wifi is on but i keep getting cant...
Unplug the router for 20 seconds, then plug it back in..
Routers get stuck every now and then.
Hope this helps
Thank you for visiting Fixya.com
Nov 11, 2010 | Computers & Internet
Router causing internet connection to fail intermittently
There are a few things can make your wireless router to lose your connection. I like to start with the most simple things first. First clear Out any clutter on your browser. If your are using Internet explorer, go to tools click delete browsing history. When the box appears, clear out the first 3 things. History, Cookies, and temporary Internet files. Firefox, you click on tools, clear private internet files.
After than do a disk cleanup.
In start menu, go to all programs, accessories,system tools and select disk clean up. After this unplug Cable modem's electric cord, unplug the power to your wireless router, leave it unplugged for a couple of minutes, Then plug in your modem,router and restart your pc in that order. If that doesn't work you can always change you network name and WEP key, Hope this helps, also I was assuming you are using a PC and not Mac.
Jul 28, 2009 | Linksys Wireless-G WRT54G Router
Router cannot connect to the internet.
Turn everything off:
Cable modem unplug the power to the modem if it has a battery remove it.
Router unplug the power to the router
Shutdown any and all computers connected to the router
Turn everything on in this order:
Cable modem wait until all the lights are on but the internet act light
Router wait until the lights goes through it's test cycle and the internet light (wan) is on.
Boot up the computers one at a time after the first computer is fully loaded go to the next computer
Hope this helps
Terry
Feb 27, 2009 | Arris Touchstone 450a (CM450) Modem
Router won't log into it's IP address online
It appears to me that you have everything plugged into the desktop PC. This is not the way that it should be done. Plug the cable modem into the wireless router via the Internet/WAN port. Plug your desktop PC into one of the ports numbered 1-4. Now connect to the router via the wireless connection for the router and you should be able to now connect to the internet with your laptop.
If it still does not work, power down everything in this order: Laptop, Desktop, Router, Cable Modem. Bring everthing up in the reverse order (Cable Modem, Router, Desktop, Laptop) waiting for each device to stablize before moving to the next.
Once you get everything working, turn on your wireless security (WPA not WEP) asap to keep your computers and surfing safe, and to keep intruders off your network.
Jul 20, 2008 | NetGear RangeMax WPN824 Router
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
