When serging, the fabric advances, the thread advances, but it's not actually sewing. I'm just left with holes where the needles went in. For some reason the thread isn't catching.
I changed the needles, opened it up and did my best to clean it out (not unscrewing anything that is), rethreaded it too.
I remember in the past it being picky about the order that it has to be threaded - does anyone know which lower looper is best to thread first?
any other ideas?
Thank you.
Make sure the tension disks are clean and not binding.. You can use a piece of yarn dampened with alcohol and floss the disks.
Threading order is:
1) Upper Looper first
2) Lower Looper
3) Right Needle -- exception: if you are doing 3 thread using left needle only
4) Left Needle
I forgot to add that the threading order I listed before ( first Upper Looper, then Lower Looper, Right Needle, then Left Needle) is normal for most 3 or 4 thread machines, but it Does Not Mean All machines.
You need to check your manual or quick threading guide for the particular stitch you are doing. The 5 to 10-thread machines have a different order for some of the stitches, and different thread paths for things like the chain stitch -- if your machine can do that stitch. You have to read your manual carefully so you don't miss a step.
I have the exact same problem as posted in Sept 2008.
any other ideas?
Thank you.
fabric got jammed. put new needles in. rethreaded all, but lower looper-as I turn wheel crosspiece doesn't move right for me to thread thru left hole. also, needle hits that piece as i lower the needles. how do I adjust?
