Question about RCA RP5430 Clock Radio
Crackling Noise Even when the radio is off and the volumn is toured all the way down there is a crackling noise comming from the bottom of the unit. Yes that's right not from the speaker but the bottom. Sometimes loud and annoying enough to keep me awake, other times very softly even on occasion no noise at all. Pushed all the buttons turned alarms off you name it can't get to be quit.
  • 1 more comment
  • Anonymous Oct 20, 2008
    I have that same problem, and also now the alarm 2 button is permanently pressed down. I can't turn this stupid alarm off now. I decided to throw it away and buy a new one.
  • Anonymous Nov 10, 2008
    Now what? Buzzing is really annoying...
  • Anonymous Mar 29, 2009
    same
I can't take credit for this because on found on a review on Amazon.Com, but I tried it and it works!
"Another update, for everyone who is having the common crackling problem, if you open the clock radio there is a black disk on the bottom with a red and black wire coming out of it. This black disk is a component called a piezo disk. They are commonly used to make noise for buzzers in electronic devices, but appear to have no use whatsoever in this clock radio. If you cut the wires going to this disk, the crackling noise goes away. You can still use both buzzer and radio alarms. There doesn't appear to be any functionality lost other than the annoying crackling sound. Obviously cutting wires would probably void your warranty, but do you really want to try your luck with another RCA clock radio? Chances are the crackling will happen again with the replacement or it will be DOA."
If you can handle a screwdriver and a pair of scissors, you can easily tackle this project, don't be worried about it being too complex. 5 screws, a snip, and you are all set. Make sure the radio is unplugged of course.
Posted on Apr 24, 2009
My radio and cd want put no sound out fuses are ok and my speaker is makind nose even when the car is turn off
'03 G35 Radio Problem. Speaker Noise Even When RadioTurned Off ...
g35driver.com/.../437164-03-g35-radio-problem-speaker-noise-even-w...
Feb 1, 2014 - Turned entire car off/on several times, no change. ... Still had the static/crackling type noise from driver rear speaker at all times - even with ...
Oct 01, 2015 | 2007 Kia Amanti Sedan
Loud crackling noise
The monitor function is turned on, on the unit that is noisy.
The manual describes the procedure for setting the monitor function the manual is available here.
https://www.cobra.com/support/product-manuals
May 11, 2014 | Cobra Microtalk 100 FRS Walkie Talkie...
Background noise problem with motorola radius cp200 and also crackling status during transmissions
Bill,
If the crackling and static are coming from the radio, it could mean 1) Something in your environment is putting out RF (radio frequency waves). 2) You have an old battery. 3) You are at the edge of the radio's range. 4) You have a bad speaker in the radio.
Possible solutions for you could be:
1) Have the radios reprogrammed to have Private Line (PL). This would block out RF noise on your frequency. Also, within the factory if there are devices putting out RF noise, there may be some solutions for them.
2) Replace old batteries. (Try a known good battery and see if it helps.)
3) Check to see if you have the same problem when radios are within a closer range. If it is a range problem, education yourself and other users to hold the radio upright (perpendicular) to the ground. You will get the best range. Tilting the radio can reduce range as much as 2/3s. Even the bodyfluid of a person wearing the radio can absorb range.
4) See if you have the same problem with another radio, or if the crackling static is just with the one radio. It may need repaired.
Another solution for you might be a noise canceling remote speaker mic. This would put the speaker of the radio up on your lapel. And these mics also have some noise/wind canceling ability.
There are a few programming things you could have your local dealer try. They may be able to tighten up the squelch and knock out some of the noise.
Best regards.
Mar 11, 2013 | Radio Communications
My speakers will start to make a crackling sort of noise then stop. Sometimes the radio will not play at all. Sometimes the speakes make this crackling noise then they stop making the noise and play ok for...
Are your speakers factory? Sometimes the wires start corroding from moistures or from not being covered well. If you can or know someone who can, you may try checking the wires to the speakers/radio. If they are corroding, they may be shorting out.
Jun 30, 2010 | 2005 Kia Amanti
Crackling noise when I adjust the volumn. How do I connect two (2) turntables to one amplifier. One of them is currently connected through the 'aux'?
Hi, it all depends on how many output your amp. has?.
You can check at the back of the amp. (depending on the type and how many output in has). Don't just look at the aux output alone, your main check should be for more outputs. Some amps. have tuner output,cd output,video output and so on. Just connect it to any of this outputs at the back of the amp. and at the front you have to set it to the selected output at the back so that they can correspond which each other.
NOTE: you can't use to output at ones you will have to e interchanging them one by one. Two different out put do not work together, but separately.
Take care.
May 20, 2010 | Audio Players & Recorders
Unit will sometimes make a crackling noise.
Mine does it too, I finally just tried something else when I was cleaning the blades. I took some alcohol on a qtip and with the blades out of the machine I wiped up and down the line wires that are inside that go from the top to the bottom, and also the little balls that are on the bottom of the wires that slide when you turn your unit upside down. It seems to work, I do it every time I clean the blades. scribner062
May 22, 2010 | Sharper Image Ionic Breeze Quadra Air...
Crackling noise coming from my speakers
sounds like a short one wire is hot all the time for the clock and memorey may have to change radio
Aug 17, 2009 | 2005 Chevrolet Equinox
Technics su-v560 stereo amp crackling
That is a common symptom of not properly grounding of negative side of the output of power amplifier section.Just resolder all component parts joint in power amp.sectiton and double the solder all negative ground.Also clean the pots of all volume controls and selector with a lighter fluid or desame that fluid so whatever sound or crackling noise eliminated and works normal again.. Hope it may help you;;
Jun 08, 2009 | Technics Audio Players & Recorders
Small black device within RCA RP5420
That black disc is the "backup" alarm if you lose power.... The battery then takes over and "buzzs" throught that little speaker too wake you... even tho there is no power... Mine buzzes too... cut that little speaker outta there.!
Robert
Oct 23, 2007 | RCA RP5420 Clock Radio
RCA RP5430 Clock Radio Logo
784 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
