My acer aspire 5920 is making alot of noise the built in microphone does not seem to turn off
  • 6 more comments
  • Anonymous Nov 16, 2008
    i have exactly the same problem. also when i go to turn off the mic the whole computer freezes and i have to reboot. definately need some help.
  • jkirsch Dec 02, 2008
    Mine just started doing this a few months after I bought it. Mic is live (both up by the Crystal Eye). It's so hot that when you fold the cover down on standby, it's still on and feeds back through the speakers! Sounds like a microwave beep or smoke detector. How do we turn off the built in mic????
  • Anonymous Dec 16, 2008
    minez exactly the same n i cant find any info on the internet
  • mikeo225 Dec 27, 2008
    my microphones never seem to turn off on my acer aspire 5920g laptop - when i have my volume turned up loud i get extreme amounts of feedback, even when the laptop lid is closed and on standby - how should i fix it
  • Anonymous Jan 10, 2009
    Same
  • Anonymous Jan 30, 2009
    Hey ive got the same problem - help !!
  • Anonymous Feb 25, 2009
    here is another one doing the same thing.. lid close, just starts squealing like a smoke alarm
  • Anonymous Feb 27, 2009
    Im a different guest and I did NOT always have this problem. Strangely enough, mine worked fine with blu ray - until I got this horrible shreiking when I closed the lid without shutting down first! Since then I get bad feedback when watching movies.
Ok i had the same problem up until today and i found a post on a site that really helped me out i had this problem for about two months and was very close the sending it into acers repair center but all it was, was a setting in the audio manager ok here is what you need to do go to control panel, then go to hardware and sound, and then go to manage audio devices under sound then go to recording then click on microphone and go to properties, then go to levels and you should see two settings microphone volume and and microphone boost if your microphone boost is set to +20 which it prolly is just slide it down to zero and wow your problem is fixed. Im not really sure what program might change this setting but acer should really check into it and your system shouldnt let programs change things such as this cause this is a very important setting for having a wonderful entertainment experience. well i hope this helps and all the credit here goes to original poster at http://wynddancer.livejournal.com/22092.html
Posted on Mar 05, 2009
  • gracenfrance Apr 28, 2011
    My goodness I have been looking for a solution to this for ages. It works! Thank you sooo much - so easy to fix too..
  • noble_sean
    noble_sean Mar 03, 2013
    THANK YOU SOOOO MUCH. ive been dealing with this problem for almost a year now.
I have had the problem of the volume in my left channel sound lower than the right for some time time trawled the internet couldn't find a fix just did this opened sound and audio devices the one with the little grey speaker icon at the bottom of the box pressed speaker performance tab in there there is an adjustment for ledt and right channels so i turned down the right channel and wakllah problem fixed hope that helps oters :)
Posted on Jun 17, 2009
How can i make the microphone work ? on my acer aspire 5920 running vista built in.
Posted on Dec 09, 2011
Acer aspire 5920 running vista has built in mic not working
Hey,
It is all because the Microphone is not set as a default device to start recording.
Its like your computer has no device for recording even if the computer has connected with Mic.
Just change the settings and enjoy..!!!
Check the below link:
How To Install and Setup a Microphone:
http://www.vista4beginners.com/How-To-Install-and-Setup-a-Microphone
Set up microphone:
http://www.microsoft.com/enable/training/windowsvista/srmic.aspx
Hope it helps.
Regards,
Nags
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
Hi, Meens here In my Acer Aspire 5920 Vista home preimum getting weird sound frm inbuild microphone after swtich on n the sounds stops after plugging headfons :(
The usual cause of microphone noise is caused by audio settings where the microphone gain may be turned up to high causing it to pick up noise from the computer or built in speakes. This can cause noise ranging from an odd hum to a high pitched squeal.
Check your sound setting first
Jul 12, 2009 | Acer Aspire One PC Notebook
We have aspire 5920 laptop, if we are talking to others through net like skype viop the others cannot hear our voice. we are using head phone.
According to the specs for your model laptop, it appears that it does not have a built-in mic. Attach a mic to the mic port on the laptop, it will be next to the headphone port and configure Skype for your microphone settings.
Jun 11, 2009 | Acer Aspire 5920-6727 Notebook
How to turn-on/function mic in my acer aspire one pc notebook?
To test the microphone, click "start" button, then "Control Panel", then "Sounds and Audio Devices". On the popup window that opens, click on the "Voice" tab, then click on the button that says "Test Hardware". After several seconds this will bring up a test program that will show a noise level meter when you're speaking into the microphone. (The default device listed under voice recording should be "Realtek HD Audio Input".)
Jan 31, 2009 | Acer Aspire One PC Notebook
Acer aspire 2920 webcam won't work in msn messenger
Make sure that another webcam application isn't running such as Crystal Eye or whatever program you use to take pictures with the webcam.
Jan 11, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 webcam doesn't work
Sir after formatting webcam and microphone need thier driver so please install webcam and microphone driver. I sure your problem will be solve.Thanks
Jethu Singh
Nov 26, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5920 keyboard replacement
http://www.gadgetsmanual.com/aspire-5920-series-users-guide.html THat should be whatcha looking for. Good luck!!
Oct 15, 2008 | Acer Aspire 5920-6727 Notebook
Weird noise from Acer Aspire 3000
When you open the sound control panel, is the mic muted or turned down? The feedback may have been coming from the built-in microphone?
Jul 16, 2008 | Acer Aspire 3000 Notebook
1,505 people viewed this question
 Grubhead
Grubhead
