Question about Sony Playstation 3 (PS3) Console
Will turn on but screen says "hard disk data base will be rebuilt", says to "push X button to start", nothing happens just starts all over again with the same thing
  • 344 Answers
Hello. You need to reformat your hard drive with an external USB set up. If you do not have an external hard drive case with USB then try another hard drive. Here is a link to show you the one I use to reformat Xbox 360 and PS3 hard drives.
http://cgi.ebay.com/External-2-5-SATA-Hard-Drive-USB-Enclosure-Silver-h09_W0QQitemZ150293421808QQcmdZViewItem?hash=item150293421808&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Sometimes the drives will not reformat due to a physical problem inside of the hard drive though. But either replacing it or reformating it will always solve this problem.
I hope this helps. Good luck and happy gaming!!
Posted on Sep 18, 2008
When I press start nothing happens then "door" flashes on screen even though the door is definitely closed
have you tried push the door in harder once u have turned it on my grandads old hotpoint washer was like this and wen used to jus push the closed door a liltte and it started
Dec 03, 2011 | Hotpoint Washing Machines
Tip
How to make an Image of your HDD Partition
<p>Backing up your computer is extremely important. Without it, it would be a hard drive failure or corrupted file may cause that you lose all your data. When these disasters may also lose valuable time in the operating system and reinstall the software before returning to work. Avoid loss of data and loss of time by an image from your hard disk or partition. When a problem occurs, the train ensures their unit begins to replace the computer and continue working. <br /> <p><br /> <p>1. Install the image or backup software. If the software is downloaded, double click the downloaded installation file and follow the instructions on the screen. If you have the boxed version, insert the CD into the drive and follow the onscreen instructions. <br /> <p><br /> <p>2. Connect your external hard drive and open the software by double clicking the icon on your desktop. If there is no icon on your desktop, click Start, Programs, and click the name of open source software. <br /> <p><br /> <p>3. Click "Backup Drive" near the center of the screen in the software. <br /> <p><br /> <p>4. Click on "Switch to partition" in the upper right corner of the screen only one partition, or click the "Switch on your hard disk to back up the entire disk. <br /> <p><br /> <p>5. Check the boxes next to the disk you want to record to select. <br /> <p><br /> <p>6. Choose your external hard disk in the "Target" box in the middle of the screen and "Back Up Now" click the button below to start the backup process. <br /> <p><br /> <p>7. Separate additional hard disk and place in a safe place, ready with the primary hard drive in case of emergency. <br />
on Jun 22, 2011 | Computers & Internet
This isn't the latest macbook air, but its problem is that when I turn it on after a while after the apple logo appears, a message pops up saying, "You need to restart your computer. Hold down the...
This means your MAC is having a kernal panic, which could be caused by a failed update, a driver or program that is incompatible. You may need to start your MAC with your system cd/dvd and run the disk checker to repair hard drive errors and file permission errors.
I'm not sure what OSX version you are running but you could also try the steps outlined in this apple knowledge base:http://docs.info.apple.com/article.html?path=Mac/10.5/en/8965.html
If this does nothing, you will need to take it into a apple store for servicing, or reinstall the OS (you may loose your programs and data depending on how your reinstall)
Chris
Sep 08, 2011 | Apple MacBook Air
Hey there. I have a problem with an external harddrive. "My Passport Essential". When I connect it to my compute sometimes nothing happens and sometimes "Local Disk (E:)" shows up in my...
The problem might be a loose connection or bad configuration file (an autostart ini file that makes the hard-drive do certain things when plugged in) in the root folder of your hard drive. Are you able to connect to it sometime or it doesn't work at all? If you can read it, try backing up all your data and format the hard drive and copy back the backup again. But remember to copy only the needed files and not the system or ini files.
May 06, 2011 | Western Digital My Passport Essential...
I own a Gateway nv7802u laptop computer that has recently crashed. When I turn the computer on, I get the normal Gateway startup followed by a black screen that says: PXE-E61: Media test failure, check...
Check and see if the hard drive came loose check the bios to see if it is recognized..It is saying there is nothing with an O/S on it and when you put the disk in it does not register a hard drive to restore..Check the hard drive and start the computer up and see if you can cancel the restore and start the laptop up regular..
Mar 28, 2011 | Gateway NV7802U Notebook
Product: LaCie 2big quadra ((Professional 2-Disk RAID. I have no back-up with the 2 disks, and this soon after purchase (August 2010). Serial number: 5102001839. Disk 2 does not work. At the front, light...
If the failed hard disk drive is replaced with the exact same capacity, RPM and make of hard drive, then the array can be rebuilt. Raid 0 cannot be rebuilt as each drive contains half of the data, If RAID 1 then can be rebuilt as data on each drive is an exact copy. However if combination of RAID 0 and RAID 1 then can be rebuilt. It's best really to handel this hands on, I recommend taking it to a computer technician especially if the information on it is important.
Thanking you
damnor01
Nov 13, 2010 | LaCie 2TB 2BIG QUADRA RAID EXT ESATA FW800...
Wont boot on its own, wont boot with install disc,
As the hard disk appears to be showing up when you boot up using the install disc, I would suspect that the system is somewhat corrupted. You could reinstall the system again and if you are happy starting from scratch and wiping the hard drive select this option failing that and there is some data on the imac you could install using the preserve user data. A fresh install should sort out any problems. Hope this helps.
May 18, 2010 | Apple 20" iMac Desktop
I opened my recently purchased Compaq Armada M700 laptop. i pushed the blue "on" button. the machine is stuck at "Initializing Intel Boot Agent Version 2.6 (build 004)" Nothing else...
First place your recovery disk in the cd drive. Then hold down the power on/off button for 15 seconds. The machine will power down. Then restart normally and reinstall from the disk.
Jul 18, 2008 | Computers & Internet
Hard disk problem
I have a problem with ps3 Cannot start the correct hard disk was not found. can any one help me on this.
Dec 31, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
62 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
