Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Reads "machine is rinsing open knob"
After descaling my Starbucks (Saeco) Barista Italia Digital machine, it continues to display "MACHINE IS RINSING. OPEN KNOB". I've emptied & refilled the water tank 4 times. I've also unplugged the machine for a few days. After turning it back on, it still reads the same. Machine still gets hot on top (cup warmer), but doesn't make any of the usual noises when turning it on. Any suggestions? It's no longer under warranty.
  • 6 more comments
  • angieseay Sep 19, 2008
    I received some advice from an 'expert' but he actually copied and pasted some info. from another espresso machine manual. It did no good, so more advice please!
    After a second response, I still have no answer. I DO have the users manual. I'm NOT able to get the machine to do anything. I cannot start it up and reprogram, or get to the menu. Again, it states, "Machine is rinsing, open knob."
    The position of the steam wand has nothing to do with the problem!
  • angieseay Sep 22, 2008
    Still hoping someone can help me with this problem. I do have the manual, but I find nothing in it that pertains to this problem.
  • angieseay Sep 23, 2008
    Still looking for a solution. Any more tries?
    How do I check the sensor?
    I again checked the steam wand, made sure it was in the "correct position" and still no change.
  • angieseay Sep 28, 2008
    Okay, one last plea before I ship it off. Any more suggestions?
    Guru:
  • 558 Answers
Your machine problem is serious. It need proper manual diagnose. If you are able to do it, then go for it.
I am providing you a useful link for repairing the Coffee machine.
http://www.coffeeco.com.au/articles/repair.html
Regards
Ellin
Posted on Sep 28, 2008
    Sergeant:
  • 241 Answers
I understand that You don not have the user manual....It would still be a good Idea if you did
have this. Even though you have used this machine several times I will give you some information
that may help you OK.
This is the user manual
www.saecoparts.com/user/Starbucks SUP021 YDR Italia Digital_English.pdf
Here are the Specs/Parts that make up your Machine.
www.saecoparts.com/user/E74057 Sept-30-2002.pdf
Parts and descalling products that are recommend by Saeco.
www.shop.partsguru.com/category.sc;jsessionid=B890837E659CDD350CBC42BE8F6DD65D.qscstrfrnt03?categoryId=62
Here is the Phone Number and Email contact If one
granita@rcn.com.
Services Unlimited, Inc,
Saeco authorized parts and Service center
Phone: 215-361-7000
If you still are not find the problem fixed
I would recommend that you visit the website...
www.saecoparts.com/SaecoItaliaEspresso.html
Posted on Sep 23, 2008
  • Jayson Brollini
    Jayson Brollini Sep 23, 2008
    Call 1.800.334.5553
    Here this is the free hot line if you are still having problems ok>
    Thank You
    Jayson
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to check the sensor
if is ok!
then replaced the sensor
    President:
  • 1,952 Answers
The appliance takes too long to
heat or a limited volume of water
comes out of the nozzle.
The circuit of the appliance is
clogged by scaling.
De-scale the appliance.
Press the steam button . The display will
say STEAMING.
• Direct the steam wand towards the drip
tray and turn the steam knob for a few
seconds so that any residual water comes out
of the steam wand. Continue until only steam
is dispensed.
• Turn the knob to OFF.
Posted on Sep 22, 2008
  • mohammed marika thambi
    mohammed marika thambi Sep 22, 2008
    Scaling occurs naturally when the appliance is
    used. Approximately every 3 to 4 months you
    should descale it and also when you notice a
    reduction in the water flow.
    Descaling is important in order to guarantee a
    good performance, a normal functioning and
    a good beverage.
    To descale you can use a Starbucks product
    the Starbucks® Barista Cleaner and Descaler
    especially for this purpose. Please ask Warranty
    Services for information.
    DO NOT use vinegar to descale.
    The display will read: DECALCIFYING/READY
    FOR USE, this is just another way of saying
    descaling.
    To proceed with descaling you must follow these
    instructions:
    1. Mix the solution with water as specified on
    the package and fill the water tank.
    DECALCIFYING/ READY FOR USE
    2. Switch on the appliance ON /OFF power
    switch (8).
    3. Press the button (31) ON and hold for 5
    seconds to select the function.
    DECALCIFYING/OPEN KNOB
    4. Direct the steam wand (13) towards the drip
    tray.
    5. Position a cup of adequate size under the
    steam wand and turn the steam knob (17)
    counterclockwise. The espresso machine
    starts the descaling cycle.
    The display will show:
    MACHINE IS DESCALING
    6. At the end of the cycle, the flow of the
    descaling solution is shut off.
    DECALCIFYING FINISHED/CLOSE KNOB
    7. Turn the knob of the hot water wand (17)
    clockwise to OFF. The display will nowread:
    RINSE MACHINE/FILL WATER TANK
    mohammed marika thambi Sep 23, 2008
    reset the message asking you to descale your machine.
    Press
    “MENU” and use the up/down keys to move the asterisk till the end of
    the line on the menu “Sign. Descal” and confirm the selection with the
    “ENTER” button.
    The following message will be displayed: "RESET DESCALING " "NO"
    Use the up/down keys to change the selection to “YES” and press “ENTER”.
    Through this reset operation, the internal counters of the two water systems are reset and the message DESCALE is removed.
    Genius:
  • 2,035 Answers
The steam wand should be twisted towards you to be in a firmly and fully closed position. Please check this one more time.
Posted on Sep 19, 2008
    Brigadier General:
  • 5,158 Answers
You open the knob.... but when it is finished you close it... i presume you haven't missed that step ?
Robert
  • Roberta Smith
    Roberta Smith Sep 19, 2008
    when you have closed the knob press the button to confirm the rinse and away you go... or should be able to
    Robert
    Brigadier General:
  • 6,966 Answers
To my understanding, this is a function meant to clean and then rinse (with heat water) the inner tube that goes from the brewing section to the coffee dispenser. If it is in this constant state, then it could only mean that the machine could not complete the cycle/function. Possibilities are:
  • clogged inner tube; and
  • it may be needed to manually de-scale the machine.
Alternately, you could try to turn off this function manually by
  • turn the machine ON;
  • after it has finished its Self Test and the display shows "ENERGY SAVING", pls press the MENU/OK button;
  • when the display shows "WARMING UP", pls press the MENU/OK button;
  • the display shows "ENERGY SAVING/RINSING", pls press the MENU/OK button;
  • press the cursor (arrow down) until display shows RINSING;
  • pls press the MENU/OK button;
  • to turn OFF the rinsing, press the cursor UP.
  • pls press the MENU/OK button.
The above procedures are better explained in the user's manual available here should you be wanting one.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Master:
  • 726 Answers
I have the same one of them and the same model and it said to me once rinsing open knob
took it took get fixed and they said it was the senser inside that reads the machine when its dirty and needs a clean or low on water it was 120 dollars to fix over here in aus so i threw it in the bin tio much i got a new one ant way there is a sensor inside and its faulty now and its hard to get to the hole machanie virtually gets pulled apart
so sorry **** not a easy fix over the net from chris
  • chris07551 Sep 19, 2008
    i dont no why it blocked it out i wrote but with a double t so it thinks i swore
    Sergeant:
  • 399 Answers
The internal motor is not running .so its not making noises as usual.
servicing required
Posted on Sep 18, 2008
  • masterexpert Sep 18, 2008
    ENGLISH • 34 • RINSE MACHINE OPEN KNOB 10 Turn the steam knob (16) anticlockwise to empty out the contents of the water tank MACHINE IS RINSING 11 When the machine rinse cycle is completed the display will show: RINSING FINISHED CLOSE KNOB 12 Close the tap, reload the circuit and let the machine heat up If you use a product other than the recommended one, you should follow the manufacturer’s directions on the package. 12.1 Interrupting the descaling cycle If the descaling cycle is interrupted by switching the machine OFF, it will automatically resume when the machine is switched back ON. The descaling cycle can be interrupted by turning the steam knob (16) clockwise and then pressing the button (27). The display will show: DESCAL. INTERRUPTED EMPTY WATERTANK Warning! After interrupting the cycle you must empty the water tank of the descaling solution and wash out the tank with fresh drinking water; the machine circuit must be cleansed by carrying out a rinse cycle. The display will show: RINSE MACHINE PRESS KEY Follow the directions for a normal rinse cycle provided in section 8 of the previous chapter. 13 FUNCTION PROGRAMMING The user can change some machine operating parameters according to personal needs. 13.1 MENU/OK command In order to program functions you must access the programming mode by pressing “MENU/OK” (28) when the machine is in a standby status. To select the desired function, press the “” button to move up one line or the “” button to move down on the display. To exit the programming mode press “ESC” 13.2 Choosing individual functions Select the desired function by pressing “” or “”. Press “MENU/OK” to enable the desired function; you can browse the selectable settings using the “” or “” button; to store a setting press “MENU/OK”. Note: by pressing “ESC” you can exit the programming mode at any time without saving the changes made; exiting without saving is possible only before you have pressed “MENU/OK”. 13.3 Description of programmable
    for more clear description just click this link
    http://www.fixya.com/support/p5846-gaggi...
    thanks.
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
How do I decalicy the Starbucks Italia Digitial?
Use a coffee machine descaling liquid or powder. Follow directions on product. Add it to water container on machine and push the descaler button "bottom right" on machine. Follow directions on screen.
Jul 17, 2011 | Starbucks Saeco Italia Digital Barista...
How do I de calcify?
HI
The Digital Italia is programmed to descale the boilers on its own. With the machine turned on, push and hold the descale button (bottom right button). This should say "Descaling" in the display. Mix your descaling crystals in your water tank. Stir until they are completely dissolved in the water. Next have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz's. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, the display will say "Finished descaling" push any button to continue. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, push the descale button again, then close and then open the steam knob again to let water just flow through the boilers until it is emptied by the machine, but don't turn off anything until the machine stops again on its own. This will clear the descale if you have gone to the "Reset Descale" in the menu and chose "Yes". Refill the water tank again with fresh water and then close and then open the steam knob again to prime and your ready to go.
Feb 17, 2011 | Starbucks Saeco Italia Digital Barista...
How do I descale the Starbucks Barista Italia Digital machine? There is no "descale" option on the menu list like other machines I've had. I received this machine as a slightly-used gift with...
The Italia is programmed to descale the boilers on its own, when set in the correct mode. To program the machine to descale it's self, do the following. With the machine turned on, push and hold the descale button (bottom right button). This should light the top right red indicator light. Mix your descaling crystals in your water tank. Stir until they are completely dissolved in the water. Next have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz's. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the top will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, push the descale button, then close and then open the steam knob again to let water just flow through the boilers until it is emptied by the machine, but don't turn off anything until the machine stops again on its own. This will clear the descale light. Refill the water tank again with fresh water, then open the steam knob to prime the machine and your ready to go.
Feb 14, 2011 | Starbucks Saeco Italia Digital Barista...
Time to descale
http://pdfdatabase.com/saeco-italia-service-manual.html
manual above
http://www.schwer.us/journal/2004/10/03/hacking-the-starbucks-barista-digital-italia-espresso-machine/
http://search-manual-online.com/download/manual/Perfect%20Italian%20espresso%20coffee%20-%20Spidem%20-%20Perfect%20Italian/aHR0cDovL3NwaWRlbS5pdC9pbWFnZXMvc3BpZGVtX2VuZy5wZGY
Copy/paste above to address bar.
http://search-manual-online.com/saeco-digital-italia-espresso-manual.html
lots of coffee tips for it.
Apr 08, 2010 | Starbucks Saeco Italia Digital Barista...
After descaling the two coffe cup lights keep flashing .
Hi
You have finished the descale process and your descale light should be gone. Put a fresh tank of water on the machine and then open the steam knob. This should clear the water light and your machine will start heating again.
May 24, 2009 | Starbucks Saeco Italia Digital Barista...
It keeps saying I need to prime.
Had the same problem and almost took my machine apart. The very simple solution was in the end: the steam wand was blocked. I unscrewed it, poked through it with a long needle, screwed it back on and everything was fine.
Jan 08, 2009 | Starbucks Saeco Italia Digital Barista...
Saeco Italia water lite and green lights flashing
Try to open the steam knob and make a cup of water (tea), see if you can get a full cup or just a half.
How old are your machine?
How often do you descale the machine?
Best regards
/Mirran
Sep 05, 2008 | Starbucks Saeco Italia Digital Barista...
Need to Prime
Something was in the water lines and the force of the pump pushed it through. Make sure from now on you descale your machine regularly.
May 18, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
248 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
