Question about Fuji FinePix J10 Digital Camera
Camera power problems?
I had just bought my camera a couple months ago. I rarely use it (more for special occasions). It has worked well up until now.
My battery takes forever to charge even though it's supposed to only be 100 minutes. When it's finished charging, I put it in my camera and try to turn it on. The screen turns on with the Fujifilm logo and the lens folds out like normal. But then the screen goes black like it's lost power and the lens stays folded out.
Sometimes the screen goes from the logo to a completely white screen and stays like that. During the white screen, I can't turn the camera off using the power button and have to physically take out the battery.
Thank you for your help. :)
It's not the battery. It turned out to be a memory card problem.
I took out my old memory card and put in a new one. It started working properly after that.
Posted on Sep 18, 2008
I bought a FujiFilm FinePix S1600 one month ago. I used it for couple of times and was working fine. Then suddenly I couldn't switch it on. When I press the power on just flashes and it is not switched on....
The sounds like a systems control board problem, or the systems control has detected an issue with the camera. The only option is to return it to the place of purchase for repair or exchange.
Jan 18, 2011 | Cameras
Power would not come on
the chip set in your camera is damaged.you must go to a near by servicing center to repair it. god bless you
Jul 19, 2009 | Cameras
Canon XSi not powering up
if it has a view finder make sure in the settings that the image is set to show up on the LCD screen also make sure the batteries have a FULL charge which means at least 8 hours of uninterrupted charging before use.
My guess is that with most nice digi cams it is set to not show the image in the LCD viewfinder but rather the actual real time with your eye view finder. look around the menu if you can and see what you can change as far as view finding and if i didn't help please specify the problem a little more and i will be glad to do whatever i can to help.
Jun 01, 2009 | Canon EOS Rebel XSi Digital Camera
Camera powers off
I think battery went on protection mode and if you give couple of hours rest to battery by take out from camera and place it on shelf. Hope this trick will work.
May 28, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
New kodak digital camera problems
Hey hashbrownz,
What it sounds like to me is the drivers required for the camera to communicate with your computer have either been deleted or corrupted. I would try reinstalling the software that came with the camera, and I have provided a link below from the manufacturer on how to troubleshoot this problem. I hope this helps!
http://www.kodak.com/global/en/service/publications/urg00810toc.jhtml?chapsec=urg00810c6s2&pq-path=12693
Sincerely,
Allan
Go Ahead. Use Us.
May 21, 2008 | Cameras
Canon 20D err 99 and shutter going off continuously
its not the battery
its the exposure of the shutter speed of the camera
it might need to be set manually. set it to 2.8 or 4.5 speed
i had the same problem when i bought my sigma 20mm-80mm lens.
the lens wasnt talking to the camera properly, it didnt know what it was aying about exposure speed rate.
put the camera in AV mode and set the speed rate.
the lens might be compatible with your camera even though it is a canon, or it could be defective
return and replace
Apr 21, 2008 | Canon EOS 20Da Digital Camera
NEW Batts but keep getting low batt indicator and....
Sorry, no solution. Same problem here. I am very unhappy because initially it took great pictures. The first one I tried only worked a couple of days and I returned to store and they replaced. Second worked a couple of months and now immediately draws down power and won't work on new batteries. I was told to use NH-10 batteries (rechargeable). I did this from the beginning. Still won't hold charge.
Jul 29, 2006 | Fuji FinePix A340 Digital Camera
Camera won't turn ON
First off, everything was not fine until this morning. You had this occur a month ago. Frankly, I would have done exactly as you did a month ago and nothing more. I have seen too many electrical problems permanently solved by turning a device off and then on, or by rebooting. Here is what I would generally recommend: 1. See what the camera manual suggests. 2. Charge the batteries fully before using them. New ones are often not charged up. They could have been in a warehouse for months. 3. The electrical contacts on your camera, the ones that interface with the batteries, may be a little corroded. If you can access them easily, try cleaning them with the eraser on the end of a pencil. Same with the batteries themselves. 4. If exposed to prolonged high humidity, electrical problems may include not only the power supply, but other electrical switches, such as the reset button., which you cannot address on your own. 5. Call Sony.
Sep 13, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
Fuji FinePix J10 Digital Camera Logo
155 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
