Question about Dryers
Maytag Dryer Dryer has power,lite comes on ,set timer and push start, nothing happens
  • 958 Answers
Are you sure the door is completely close?
if the door is not closing the door switch, nothing will happen when you press the start button.
drcool
Posted on Sep 18, 2008
  • 1 more comment
  • francis rivero Sep 19, 2008
    i your problem fixed?
    drcool
    hi jkhi,
    can you please rate my solution,
    it is just as important to us to help as our ratings also in order to uplift our self esteem, may i request for a fixya rating since you were able to fix your problem,
    I will greatly appreciate it,
    tnx again,
    drcool
  • francis rivero Sep 20, 2008
    tnx 4 d rating jkhi.
    i appreciate it.
    drcool
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
The dryer model # PYE3300AYW The dryer has power but will not turn on when the timer/start knob is pushed. You can hear the timer ticking, but nothing else happens. What are the possible causes for this?...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 20, 2011 | Maytag Dryers
My Dryer is a Maytag MGD5570, just under 4 years old. The dryer has power (light is on), but when I push the Start Button, nothing happens. I checked the Thermal Fuse with a continuity tester and it is not...
Dryer Repair - The
Dryer Repair - The
heatman101
Feb 03, 2011 | Maytag Dryers
Have a Whirlpool GEQ9800LW0 and it won't start. When I set the timer and push the start button nothing happens. The timer still makes it's usual clicking sound but the dryer won't start. What needs...
Check power to the inlet valve, if absent let the program move forward and if the motor does not work either it is possible that thetimer though ticking is not contacting.
So go back to check for the wash cycle, when start is pushed, inlet valve on, water comes in, water fills , triggers level sensors,washing starts with motor on.
If there is no voltage on any parts ,the timer contactor is faulty
Sep 19, 2010 | Whirlpool GEW9200L Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Batch complete sounds when start button is pushed
door switch or timmer or the knob on the timer may not be turning the timer
Nov 27, 2008 | Maytag PYE2300AY Electric Dryer
Dryer won't start
does it have drum light ?if so is it working ?if not and bulb is good raise top by pressing clips at each corner on back is heating element.. on element case is thermal fuse with 2 white wires it could be open part# la-1053 ( i think)..if light is on but still no operation possible timer or door switch
Sep 18, 2008 | Dryers
Maytag Dryer #MDE4000AYW
Try first unplugging power cord from the appliance, this will drain power from circuits and reset it.
Check the door latch sensor, if that is stuck the door sensor will not let the machine start.
Keep pressed start button for 10 seconds or so, on some dryer this reset the machine.
If it still does not work then there is an internal fault , probably the timer assembly must be replaced.
If you need to call a technician you can use the number listed on the owner manual.
If you want to do it yourself, test the timer control, then if it is faulty replace it.
You find replacement here.
Sep 17, 2008 | Dryers
Dryers Logo
122 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
