Question about Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-9152D Car Audio amp
I have a ken-wood kac-9152d car amp and its the same when the bass hits it cuts off for a few then back on again and this repeats its self. the LCD light on the amp back cuts off when the bass hits, whats wrong with this thing? I don't want too get charged an arm and a leg to get it fixed. Its hooked up to only two twelves?
  • 631 Answers
There could be several problems. The following page should help you determine if you have a problem with the amp or something connected to the amp.
Amplifier in Protection Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Sep 18, 2008
Kenwood repair manual
I have the Kenwood KAC-9152D Repair Owners Manual. This is my E-Mail address. canalv11@gmail.com send my a e-mail. & I will e-mail back 2 U w/the Manual ATTACHED
Dec 21, 2011 | Kenwood KAC-9152D Car Audio Amplifier
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Power amp wont power up
Check the fuses-should be a pair of 30 amps on the side. use a paper clip and jump power from the power+ to the remote+ and see if that lights it up-if it does than your remote lead isnt giving it juice-
Apr 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood amp kac-x401m
How long will the bass play before the amp kicks into protection mode and how loud are you listening to it? I've noticed with my amps that if they don't have enough air flow they will get hot and kick into protection mode. They will also kick into protection mode if you are running it at more than it can handle. Check your adjustments on both your amp and the head unit. Make sure you are not running more bass than the amp can handle.
Nov 04, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-9152D monoblock
The amp says it's 1 ohm stable, so assuming the DVCs are dual 4 ohm, you should be able to connect all "+"'s together and all "-"s together, like the picture below:
As for the amp shutting off for a few seconds, it sounds like it's either:
A) Not getting enough power at high volume.
OR
B) Overheating.
The cap on the +12V to the amp should help, but putting a meter on the +12V might tell you whether it's dropping too low (<11V).
When you first turn the volume up, how long does it work fine before shutting off? Is it with the vehicle running or not?
Mar 25, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood kac 9152D
Usually, protection mode is caused by one of these conditions:
  • Shorted speaker outputs.
  • Speaker output shorted to ground.
  • There is an internal issue, causing DC voltage to be present on the speaker outputs.
  • Amp overheats.
  • Ground connection is insufficient for amp or HU.
I'm not sure of the history or symptoms of your amp, but those are the reasons why the amp could go into protection mode.
Mar 13, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Bass knob/remote for kac-9152d
dont try that yet,doesnt require remote to work,only added feature
Aug 11, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood kac-9152d
by jump do you mean all it does is thump and no sound besides thumping noise? if so put a better ground on your amp, double grounds work the best. please reply
Oct 06, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Amp stopped working...
Has the amp been overheating lately? It's quite possible that the amp could have just blown. Smell around the outside of the amp for an electrical burnt smell. If available, see if a friend also has an amp hookup and try removing your amp and copnnecting to the friend's cables. That will tell you if it's a wiring problem or an amp problem.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
174 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
