My Samsung TV is flashing all three lights so I assumed it was the light. I changed the light(after changing it only two months ago) and the TV makes all the sounds but then right when it usually powers on it clicks and the light never goes on. The lamp light will then flash and it will try to power up again and again before eventually turning off.
  • bwilliams41 May 04, 2009
    when i cut the tv on it stays on for 5mins or less and cuts off and the three flashing lights starts flashing
    Master:
  • 505 Answers
First make sure all the cable at the back of the TV is connected properly.
The problem you referred means that the TV is going in protect mode because it detects an internal problem, try leaving it unplugged for a longer time, let say one hour or two.
Basically, what happens is that the TV does not start because it detects that there is an internal problem, such as a wrong voltage, a bad component, overheating etc.
When you unplug power and restart it, you reset the internal circuit, and the TV will restart, not detecting the internal problem.
As soon as the TV gets hot, after staying on for a while, the defective part start giving troubles, as the defective component (probably an IC, starts overheating).
From description, the digital processing board. can be cause for the problem as there is no video.
However all the following parts can be involved.
Parts involved can be
Polaroid digital processing board.
Polaroid replacement ballast.
Polaroid Replacement LCD controller
Its time to get it repaired.
Thanks
Posted on Nov 03, 2008
    Novelist:
    Champion:
  • 203 Answers
There are several things that can cause this. Colorhweel, ballast, power supply, dmd module. Try to listen carefully to the set and see if you hear the colorwheel spin. If you dont hear it spinning then that may be your problem. If it is spinning then you will need to know how to use a meter to determine what part is bad. if it is not spinning then it is most likely bad. Let me know what you find and if you need more help!
Tim Nolan
Posted on Sep 17, 2008
TV Turned Itself Off - Now - No Power No Lights Flashing
power supply board is faulty need to check the power transistors and fuses u will need a tech to solve this
Jul 14, 2013 | Samsung HL-R6167W 61" HDTV
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Hi I have a Sony kv36fv27. Two days ago screen started to change colours. Red blinking light flashing 5 times. Light flashes also when tv is shut off. Production date NOV 2001. Thanks for your help.
Hello, I'm afraid 5 flashes indicate failure television screen itself. In addition to your description of the changing colors. It can be assumed that the screen is broken.
Mar 06, 2011 | Sony Televison & Video
Samsung dlp hl61a650c1fxza turned off in the middle of the nfl playoff game. Turned it back on and the blue on/off button stays lit but the three lights (red, green, green) blinks constantly with no...
Hey dsfrank6088, i have the same issue right now. I called tech support and they are telling me that i need to change the light bulb which i did less than 3 months ago. Please let me know if you did find a solution!!
Jan 19, 2011 | Samsung HL61A650 TV
Misfire and check engine light-flashes 12 times
There is a dead cylinder, so its not getting a spark at one spark plug. Check it at Autozone for free, that will tell you where the trouble is.
Aug 19, 2009 | 2003 Jeep Grand Cherokee
Indicator light flashing red.
You have a shorted circuit board inside the TV, have it repaired.
Jul 06, 2017 | Panasonic PT-50LC13 50" Rear Projection...
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
HL-p4663w/3 flashing lights
The Problem you have with your set is that your lamp is dead. you will need replace it. The Part number for the lamp is on the side of the TV. BP96-00826A is the part number. You will need a service Person to change the Hour timer in the service Menu.
Jan 04, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
1,920 people viewed this question
Top Televison & Video Experts
Electro Med Services...
