Question about BenQ Joybook 5100U Notebook
Hard Drive Replacement on Notebook
I have a BENQ joybook, standard drive is 60 gb and am trying to replace with 250gb Western digital
So far installed and Bios recognizes the Hard drive but will not see the DVD therefore will not boot from rebootable disk.
Question is there possibly an upgrade to the Bios to allow the change of Harddrive or is there a part of the proce3dure I am missing.
I have installed the HDD into another notebook ( Different brand) and no problem
Any Ideas
Cheers Tony
    Scholar:
  • 95 Answers
If it's an IDE hard drive, then check your jumper settings on the hard drive. It might be conflicting with the dvd drive. There's a small section of pins on the right side of the drive.
Steven
Posted on Sep 17, 2008
  • Steven Parker
    Steven Parker Sep 17, 2008
    Oh yeah, if it's an older laptop, then you might need to update the bios to detect the whole drive. I doubt it though.
    Steven
  • 446 Answers
Your computer might not able to support this capacity i suggest calling the manufacturer for Hardware compatibility, if it does not recognize, then the bios might not be able to recognize this big capacity, updating to higher version of bios might help but sometimes not, it all depends on your motherboard config.
Hangs before it complete installation of Windows Xp Home at 35 minutes before due to finish exact each time Its a SATA drive with an ASUS Board P5GC-MX I was hoping to see if both Motherbard and the...
Its not a driver Issue I don't think. Maybe an unsupported driver trying to load in the background.. when it hangs try pushing alt-tab and see if another window comes up asking for input
May 05, 2011 | Western Digital WD2500JS 250GB SATA2...
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
Why wont my Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive work?
Several possibilities:
* bad USB port in your computer (try another USB port)
* messed-up copy of Windows (try connecting to a different computer)
* damaged USB cable between computer and the Passport (replace it)
* bad disk-drive inside the enclosure (replace it)
* bad USB-to-disk-drive adapter (buy a new "empty" enclosure)
Check the warranty on it, to see if W.D. will replace it, at minimal cost to you. If the warranty has expired, W.D. has a "Customer Loyalty" program -- buy a new Passport through their web-site, and you qualify for a discount on your purchase.
Oct 30, 2010 | Western Digital WD Passport 250GB Portable...
What voltage and amperage the western digital wd25001032-001 will work. I lost the original power supply and need replacement.
Mine has a 12V 4A power supply. This is not generally available as a generic replacement, due to the high current required. Good luck!
Feb 21, 2010 | Western Digital 250GB MyBook External USB...
My benq joybook r45 won't boot. the battery is fine.. the screen will go brighter/dimmer.. and attaching an lcd doesn't work.. what is wrong with this machine?
a number of things could be wrong- bad ram, bad motherboard. a bad hard drive will still usually get you a post screen. if you are at least getting a post screen, i would look towards hard drive issues.
Oct 31, 2009 | BenQ Joybook R45 - R45-PE-16, Intel Core...
Installing new sata drive in HP pc
a clean xp installation does not recognize sata drives at all. you can either use nlite to build a custom install cd, press f6 during setup to load additional drivers, try to change your sata mode from native to compatible in your bios or use your restore cds.
Mar 18, 2009 | Western Digital WD2500BEVSRTL Scorpio...
BenQ Joybook 5100U Notebook Logo
235 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
