Question about Sanyo Televison & Video
I HAVE A SANYO hv-dx2 DVD/VIDEO. WHENEVER I WATCH SKY OR ANALOGUE TV I GET GOOD QUALITY PICTURES. BUT WHEN I SWITCH THE DVD/VIDEO ON - THE ANALOGUE CHANNELS STAY OK BUT SKY PICTURES GOES VERY GRAINY AS IS ANYTHING RECORDED FROM SKY
snakehead
  • 1074 Answers
SOURCE: Sanyo DRW-1000 DVD Recorder / VCR Combo
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
Posted on Jun 04, 2007
  • 3422 Answers
SOURCE: Unable to set TV channels on dvd recorder since connected to Sky box
Please connect ariel to vcr then dvd then tv .scart(tv)on sky box to tv.scart(vcr)on digibox to vcr.vcr ariel out to dvd in,& dvd ariel out to tv. to record vcr video to dvd must set to av on dvd player. you should be all right with this.
If you still have problem connecting then Just refer THIS link and it will tell you everything as how to set it up step by step with the diagrams.
Goodluck...
Posted on Feb 18, 2008
SOURCE: I have a Panasonic DMR-EZ47V
For an unknown reason the problem was solved by turning off the DVD recorder for a minute or 2 and this reset the the entire recorder. This was done because apart the means of resetting the tuning within the recorder's menu wasn't solving the problem.
Posted on Apr 29, 2008
  • 70 Answers
SOURCE: Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Posted on Jul 28, 2008
SOURCE: watching another channel while recording
Hi there! Sorry but you can't unless you have My Sky/HD recorder. The sky decoder is simply a one channel watch decoder. You can only record a sky channel and watch the channels normally provided via your VHF and UHF aerials connected to the decoder or vice versa.
My Sky fixes that although you cannot record to a dvd disc on this thing and the privilege comes at a price of course!
Posted on Sep 14, 2008
I have a Sanyo HV-DX2 but it is locked is there anyway i can unlock it
I think this manual will work
If you forget your 4-digit code
If you forget your password, to clear the current pass-
word, follow the procedure below.
1 Press SETUP to display the setup menu.
2 Use the Number buttons to enter the 6-digit number
"210499".
The 4-digit password is cleared
Sanyo HV DX1E Instruction Manual
Jul 13, 2017 | Sanyo Cell Phones
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
Whenever I try to watch a DVD the screen splits and a message reads "PSCAN"
You need to do one of two things:
1) Look at the back of the DVD player for a switch that is labeled with " PROGRESSIVE SCAN', you need to set it to OFF (since you are using Composite Video jack (Yellow RCA jack) output of the DVD to feed your TV, but the DVD player is set to PROGRESSIVE scan mode, taht is why you are seeing "PSCAN).
2) Use the component video input/output instead by using 5-wire cable set (Red, Blue, Green for video, and White and RED for audio).
Sep 03, 2011 | Sanyo Televison & Video
I watch tv via Digital DVD recorder but am unable to see sky tv. Do I need an analogue recorder
You need an analogue receiver to view the co-ax output from your sky box but you should be able to connect via scart
Feb 08, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I am unable to pick up sky and set it to a position on analogue tv settings. The Tv is sanyo ce26ld90b.
If first we could ensure some connections are tight before moving into TV settings.
You have told me that you are using sky over an analogue connection. Make sure that these are plugged in at both ends (sky box and TV) and that your sky box is on.
Now using your TV remote, enter the TV settings (there should be a button for this specifically on your remote), and opt for Tuning and manual tuning. The layout for most TV settings are similar.
By manual tuning, you are able to select the number on which you want to view a channel (in the analogue case, Sky as a whole is considered one channel on your television)
Now you should be able to use the left and right keys on your remote to tune up and down a range of frequencies, one of which Sky will be on. Once you have found this frequency, you should store it to the channel you have selected.
To my mind, the only thing that would then cause this to reset is if you turn off your TV from the mains each time you finish using it.
Aug 23, 2009 | Sanyo Televison & Video
Problems with previewing/capture with ADS DVD Xpress DX2
I'd suggest removing all your other USB devices. I had heard that a Netgear wireless internet transmitter in another USB port could interfere with the ADS recognizing the signals from the video player or camcorder.
I had no picture preview at first. Then I tried unplugging my internet transmitter from the other USB device on my computer. It worked like a charm and started previewing right away.
I also found I had better luck with the old-fashioned composite video cable versus the S-video cable. Picture still looks great though after transfer, so sometimes old fashioned still does the job.
Good luck.
Jan 02, 2009 | A D S DVD Xpress DX2
Sky
You do not say which breed of sky you have.. old analogue, digital, sky + or sky HD if you have old analogue then you may have to connect through aerial connection, digital will have a scart socket to connect to your tv, sky + will have the same and finally the cream of the crop sky HD will have hdmi in addition to scarts.
The very least you need to do for a digital picture (not to be confused with hi-def which it isn't) is connect through scart lead then unless it auto-switches to scart input upon switching on sky use your tv remote to select the ext input 1, 2 or 3 etc (some remotes have a button called source for this some call it input etc) select each ext input until you find the one your sky is connected to
Oct 12, 2008 | Televison & Video
I was wondering what is the typical ideal set up in terms of picture settings to obtain the best picture from my 46" samsung 6 series. It is currently connected to my sky box (not HD)through a normal...
If you are not connected to HD, pixelation can easily occur, especially if you are using an analogue connection. Here is a list, from best to worst, of how you should connect the video on your system.
1) BEST - HDI cable between the TV HDMI in and the sky box HDMI out. This is a full bandwidth digital audio and video connection.
2) BETTER - S-Video between your TV and sky box (with L & R audio)
3) GOOD - Component Video with L & R audio
4) STANDARD - single video cable (yellow) along with L & R audio
5) standard coax
These are listed, as stated, from best to worst quality. If you are not using a digital connection (HDMI), then pixelation can be expected.
Sep 03, 2008 | Samsung Televison & Video
Digital TV
right hdtv stands for high definitian tv witch basically means if you buy a hd dvd player or blueray then you can watch the films in really high quality alot better than normal dvd. The same if you had cable tv or sky you pay a fee for an hd converter then this lets you watch certain channels in high def. So it basically means that your telly is capable of using all the new hd equipment thats coming out like the playstation 3 can play high def dvd's as long as you buy the hd lead as you need this due to the fact that it sends more data to the telly their for giving alot better sound quality and alot better piture quality when watching hd dvd's.
At the moment their are only a few tv channels that are using hd at the moment but this will soon change.
So to watch hd dvd youll need an hd dvd player and to watch hd tv you need to contact your cable or sky people and ask them what you need to do to watch hd programmes. they will then upgrade your box and should send you an hd lead to plug into your telly from the sky or cable box.
Hope this is helpfull and easy to understand.
Hd is well worth having as the quality is amazing you wont believe it till you try it i was shocked as the detail and quality is mind blowing its like watching real life, it really is that good.
Let me know if you need further assistance ok
May 14, 2008 | Sylvania 6427TE 27" TV
Pioneer vsa e06
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
Jan 24, 2008 | Pioneer VSX-1015 Receiver
Televison & Video Logo
54 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
