Question about Audiovox Televison & Video
Portable dvd player claims to be loading but does nothing beyoind that
  • 171 Answers
AudioVox DVD Players customer support may be reached the following link.
http://www.800customersupport.com/products.aspx?p=75&pn=DVD%20Players
To fill out a customer support request, click on the following link:
http://www.800customersupport.com/request.aspx
If for some reason these links fail to direct you to the AudioVox Customer Support Website, copy the link and paste it into the address line of your browser. When asked to select brand, click down arrow and choose AudioVox. On the left side of the window you will see the manu option for the DVD Players, as well as, the various other lines this company provides support for..
Please remember to rate this solution.
Posted on Sep 18, 2008
Keeps loading then nothing
The DVD doesn't load - it just plays. The player mechanism has failed, a common problem with portable players.
Apr 01, 2014 | Zenith ZPA-314 Portable DVD Player
I have portable DVD model : LMD 5702RT When I put the DVD in and it starts loading, after about a minute it says no disc. And nothing is playing. Please help
try very gently cleaning optic (EYE) on player with a Qtip and rubbing alcohol
If that doesnt help; you need to replace the lens.
Jun 06, 2011 | TruTech LMD-5702RT Portable DVD Player
Phillips PET 706 portable DVD player. Won't play DVD's.
1. The pin, right side in the back of the dvd-tray-lid, which triggers the switch on the motherboard of the dvd player is broken.
2. Not impossible, but unlikely: the proper switch on the motherboard is broken, corroded or just full of dust and does not close the circuit.
Solution to 1.: you need a new lid with intact pin, or glue an improvised pin on place of the broken one.
Solution to 2.: take the whole player apart (not difficult at all), while not disconnecting any cables, so you can now test the trigger switch (momentary switch) manually and see if something happens (on screen appears loading)
ATTENTION: BEFORE pressing the SWITCH: cover the laser lens with a piece of paper - do not look into it - it can damage your eyes!!!
If nothing happens by manually triggering, try to spray some electronic cleaner (fat and oil free) into that switch, while pressing it continously. If still nothing happens, disconnect battery, DC, de-solder that switch and look at mouser.com or any other electronic parts dealer to get a MOMENTARY switch with exact identical dimensions, etc.
Solder it in, everything should be perfect now.
Good Luck
Apr 05, 2010 | Philips PET741 Portable DVD Player
I found an Astar portable dvd player with only the battery charger attached months ago and nobody claimed it. I used it night before last and watched a whole movie, last night I watched a movie and it just...
Possibly you just need a new power supply/battery charger. There is nothing "magic" about the original power supply. Take the player into an electronics supply shop. They should be able to look at it and match
Voltage In Voltage Out Power requirement (milliWatts or Watts) Connector Type Polarity (center of plug positive or negative)
Oct 10, 2009 | Astar PD-3010 Portable DVD Player
Dvd player does not load nor spin
hay look for qulified tecnician and clean for you the lens or if the ploblem is much bigger sony compuny have one year warrant for original quality if not replace with original lens from sony company thanks
Apr 23, 2009 | TruTech PVS12701 Portable DVD Player
Loading but nothing happens
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.I hope this information helps your problem.
Apr 07, 2009 | Mintek MDP-1810 Portable DVD Player
My MUSTEk MP-100 does not load avi (DVIX/XVid) files
The player actually loads divx (.avi) format files. It does not loads some .mp4 format files.
Jan 23, 2009 | Mustek MP100 Portable DVD Player
No disk
Try playing Different DVDs, Second Make sure which Region Disk your playing is it Region 1 or Region 2, If your DVD player is Manufactured in USA it plays only Region 1, If its manufactured in UK it plays only Region 2, If still you face same problem Use Lens Cleaner, If still you face same problem do Reset.
To Reset Dvd player, Remove DVD from Dvd Player, Unplug Power chord from Walloulet for 15minutes so player goes to Defult Factor Settings, Then plug back again Power chord. Turn on Dvd player insert DVD, It should Play or else Claim Warranty.
Nov 29, 2007 | Curtis DVD8017 Portable DVD Player
Televison & Video Logo
71 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
