Question about Apple iPod MA446LL/A MP3 Player
30g ipod locked up
My ipod has the lock in the top left corner off screen,it wont reset or restore as the click wheel has no use due to it it being locked(hold),yes the hold button is switched to off.but nothing happens.any ideas???thnx.
  • 3 Answers
I had this same problem and tried everything posted on the internet to get it working. Nothing was working...
I had the harddrive replaced at some point but some internet ipod drive saver guys. Got it back working fine. Then my battery wouldn't stay charged very long, so I bought a replacement and swapped it myself. Worked fine initially but shortly after got the lock icon in the top left, regardless of the HOLD switch position.
After trying everything else, I opened the case again, and moved the switch on and off using the exposed connector on the inside rather than by the external part of the switch. While doing that, I instantly saw the screen light up on the table it was laying on. I turned it over and the lock was gone! So apparently, there must have been some issue with the HOLD switch that by moving from the inside was able to fix.
Posted on Sep 19, 2008
Is there a way to restore my ipod with my tablet?
Follow these steps to reset an iPod Classic, or in fact any iPod with a Click Wheel.
Make sure the iPod Classic isn't simply paused or locked.
Check the screen for a lock symbol.
If you see a lock, unlock the Hold switch.
You should be back in business.
Put the iPod on a flat surface to stabilize it.
Slide the Hold switch on, then slide it off.
Hold down Select and Menu together for several seconds with two fingers.
Make sure your finger isn't touching the Click Wheel.
When the Apple logo appears, release Select and Menu.
If the iPod Classic doesn't reset, repeat the above step.
If that still doesn't get your iPod Classic to restart, plug the iPod into a power adapter or a computer and see if it starts up.
http://support.apple.com/kb/TS1382?viewlocale=en_US(URL)
Jul 06, 2013 | Apple Audio Players & Recorders
Tip
Resetting an iPod if you forget your password
<p>The iPod is a security measure to prevent unauthorized access to your personal media player. Apple included an option to set a password to be used to unlock the device at startup. If you draw a blank password, you can still have the ability to unlock the device, but the process depends on the model of the iPod. IPod Touch owners to restore the device to a password reset code. Other iPod owners need only plug it into iTunes to lock the screen around. <br /> <p><br /> <p>Lock the iPod <br /> <p>1. Connect your iPod to your computer you normally sync your device. <br /> <p>2. ITunes load. <br /> <p><br /> <p>3. Click the "Eject" on the right to offer your iPod under "Devices" in the left column of iTunes. The iPod will be unlocked. <br /> <p><br /> <p>4. Select the "Extras" on the iPod. <br /> <p><br /> <p>5. Select "Lock screen". <br /> <p><br /> <p>6. Select 'Turn Off Screen Lock. " <br /> <p><br /> <p>Unlock iPod Touch <br /> <p>1. Connect your iPod Touch to your computer. <br /> <p><br /> <p>2. Open iTunes. <br /> <p><br /> <p>3. Click on the iPod Touch icon on the left "Devices" section column. <br /> <p><br /> <p>4. Select the "Summary" tab. <br /> <p><br /> <p>5. Click "Restore" and confirm the prompt action in the resulting pop-up. Follow the wizard prompts for the restore process to complete. <br />
on Jul 21, 2011 | Computers & Internet
How do i reset an ipod
Step 1:
There are many iPods each having there own specific method of restore them WHAT MODEL ? The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo. This error error occurs when the hard disk is unable to access the information and stalls while opening a file. A reset of the device usually corrects the problem, as it clears the device's memory and any errors. Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch. Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position. Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel. Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo. Plug the iPod's connector cable into the dock connector on the bottom of the iPod. Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod. Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu. Click "Eject iPod" in the sub-menu to disconnect the device. The iPod takes four hours to completely charge its battery.
Feb 17, 2013 | Apple iPod Audio Players & Recorders
My ipod wont turn back on
You have not stated any model no. which makes it hard to provide a solution.
Hope this helps.
Jan 24, 2013 | Apple iPod Audio Players & Recorders
REBOOT IPOD
which model ipod they all have different ways to reset usually through iTunes
Hope this helps.
Jan 20, 2013 | Apple iPod Audio Players & Recorders
Only turn on de logo apple no more
Hi, NOTE: First make sure that your iPod's hold button isn't on. This is the little switch at the top left corner of the click wheel iPod that you can move to "lock" the iPod's buttons. If this is on, you'll see a little orange area at the top of the click wheel iPod and a lock icon on the iPod's screen. If you see either of these, move the switch back and see if this fixes the problem.
If the hold switch wasn't the problem do the following:
Move the hold switch to the on position and then move it back to off.
Hold down the Menu button on the click wheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod video. You'll know the iPod is restarting when the screen changes and the Apple logo appears.
If this doesn't work at first, you should repeat the steps.
If this doesn't work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
If this doesn't work, you may have a bigger problem, and ought to get more help.
apple.com/support/ipod/
Feb 23, 2011 | Apple iPod touch
My screen is locked on my ipod nano 4GB
Switch the lock button on top to off.
Oct 19, 2009 | Apple iPod nano
80 GB Ipod Classic shows locked and click wheel not working
Slide the switch on the top of the ipod to where it shows white instead of orange. If it is already off hold, then you may have a broken hold switch.
Aug 10, 2009 | Apple iPod MA446LL/A MP3 Player
Locked
unlock it by pushing the lock level over on the top
Oct 24, 2008 | Apple iPod nano
Ipod 30GB
There may be 2 solutions for this problem:
The 1st solution:
The first thing you should do is locate the lock button on your ipod. Second make sure it's unlocked, lock it and wait for one second and then unlock it. Finally hold the inner Grey circle button in the center of the ipod until you see the apple logo appear on your screen.
The 2nd Solution:
Plug in your ipod and click on your ipod in your itunes library. By doing so you should be on your contents tab. Click on the settings tab and then click on restore. This should restore all your defaults on your ipod. Before you do all this; make sure you back up1.gif your ipod library if you don't currently have them in your itunes library.
If this solution helps you out please give rate me and leave a comment. Thank you...
Mar 15, 2008 | Audio Players & Recorders
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
