Question about Acer Computers & Internet
Cant recover system i do have orignal recovery disc erro message system not fully installed when trying to boot in safe mood tried several times to reboot same result. tried to repartision-repair-delete drive got blue screen of death error message check for undates or disc space. reboot again loads up goes to welcome screen of windows freezes. reboot again goes to windows logo screen freezez what am i missing
  • 320 Answers
Try to boot from your recovery CD and reinstall system
Posted on Sep 17, 2008
Updated tool for restore Windows hard drive data
If the hard drive will not boot, use the Windows installation disc to repair the operating system. If that fails, install a fresh drive and install the operating system. Then attach the old drive to restore your data.
If you accidentally erased your hard drive data, you may need to purchase recovery software, or send it to a company to recover your files.
May 05, 2014 | Computers & Internet
I receive a blue screen for windows 7. I am unable to log into safe mode. Repair Your Computer on Advance Boot Options does not work. it restarts the same for safe mood I have tried Last Known Good...
Check if you installed something before this happens. Try to uninstall it or removed the device. You may also need the recovery disc which came with the laptop or make one or borrow one as long as when the key is asked you use the one for the laptop (normally found in the sticker on the laptop). Other than that you may need to re-install the operating system.
Jul 06, 2011 | HP Pavilion dv4000 Notebook
Error unitialized corrupt boot structure detected biohd-4 boot path, keep getting this after trying to install windows 7, cant boot disk anymore so cant install windows 7
try repairing the file system using chkdsk with /f switch. However, it is strongly recommended to run this tool only if you have a full data backup
. To do so, click \'Start\' and then \'Run\'. You can then type \'chkdsk /f <drive name>\' in the \'Open\' box and click OK. Here, the drive name should be exactly what is appearing in error message. Alternatively, you can opt for deleting the corrupt partition provided the backup is available. If no good backup exists, you should consider to use a Windows Data Recovery utility. These are powerful and valid Windows partition recovery utilities built to scan the corrupt or deleted partitions and safely recover the lost data. The applications are easy to install and use.
Jun 11, 2010 | HP Pavilion Slimline s3620f Desktop
Cannot complete recovery or clean install windows Compaq Presario
You could have a Boot Sector Virus. you would need to run anti-virus software to try and remove this issue. I would recommend Avast or AVG. I have attached a link of website that microsoft recommends. http://support.microsoft.com/kb/49500/EN-US/
Jan 10, 2010 | Compaq Presario 5000 PC Desktop
When i try to recover my dell inspiron desktop it
call dell and get the factory program discs as well as factory restore discs...They'll make you happy!!
Sep 26, 2009 | Dell Inspiron 530 Desktop Computer
HP DV4 displays only a blue screen running vista
Shutdown the computer,disconnect external peripherials.
Turn on the computer and hit F8 key as soon as you restart the computer
You will get the windows advance options menu.
Select the Safe mode option and hit enter.
If the computer boots in safe mode, do a system restore to previous date.
If computer restore then issue is resolved.
If still unable to boot in safe mode.
Ran a harddrive diagnostic.If harddrive test passes. If harddrive test fails replace harddrive.
Boot the system using the windows xp or vista operating system disk. Try to repair the OS then reboot the system and check.
If still unable to boot possible issue with corrupt operating system.
Reinstall Operating system. / Recover System . Good Luck.
Aug 27, 2009 | HP Pavilion dv4-1140go Laptop
Black screen on laptop, will not boot in safe or normal. no back up disk, tried f11 sys recov did not work
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
May 15, 2009 | Compaq Armada E500 Notebook
Bootmgr
Try this:
7. Click the operating system that you want to repair, and then click Next.
OR :
try this
Boot from DVD -> setup recov. -> command prompt
<bootdrive>\windows\setup\scripts\bootinst.exe /nt60 all
should fix the bootmng
Feb 20, 2009 | Acer Aspire 5500 5570-2609 Laptop
R15s829 tablet fails to fully boot
try reinstalling windows vista. back up your data and reinstall using the recovery disc
Jan 16, 2009 | Toshiba Satellite A135-S2276 Notebook
Trying to reinstall xp with recovery discs, now i cant get it to boot
If you can boot go to safe mode using F8, see if you can do system restore from start/programs/accessories/system tools.
If you cannot boot, or system restore does not work you need to reinstall Windows, either using recovery CD from Acer, or generic Windows disk. In last case you will need to reinstall driver after installing windows.
If you do not format hard disk or delete partition, you will be able to recover your data (documents, pictures, music, desktop contacts etc) after installing Windows.
Always better than incinerating your Acer.
Aug 11, 2008 | Acer Aspire T135 PC Desktop
Computers & Internet Logo
166 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
