Question about Whirlpool Washing Machines
I have the Duet, front loading washer and it now has a rotten egg smell every time you start it. Any suggestions on how to get rid of the smell?
    Sniper:
  • 88 Answers
This nasty smell is generally soap scum build-up. First thing i would do is to remove the bottom panel and clean the pump filter, (sometimes junk builds up there and stinks) if the inside of the pump is slimy, make sure your drain hose is not installed too deep, pull up the hose and see if it is wet and slimy at the end, if so, it is siphoning dirty water back into the machine after the cycle has ended. If that is the case, correct the drain hose so it is only 5-6" down the pipe, and then run a sanitary (hot) cycle, with nothing but a half gallon of bleach. Don't use that much bleach regularly though, as it can wear on hoses. After the machine is clean, make sure you leave the door open while not in use, use only HE (high efficiency) soap, and use a max of 3-4 Tablespoons. Also, to reduce odor, try sprinkling Oxi-clean powder in the door boot lining occasionally. Hope this helps..
Posted on Sep 17, 2008
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
How to get rid of rotten egg smell coming from washing machine
Check the drain where the wash machine is plumbed into it should have the blung to stop the smell comming out of the drain,also check the filter but it is very rare that the smell will come out of the washer it will be a drain issue that is backing up through the washer,if you havent got a u bend trap on the drain it will allow the drain gases to come back into the house.
hope that helps a little bit.
adrian
May 28, 2014 | Hotpoint Aquarius WD63 Front Load...
The washing machine smells like rotten eggs on the rinse cycle. The clothes also smell afterwards as well. What can I do to resolve this?
Rotten egg stench is caused by sulphur content in the water or building up over time in your water heater. It can also build in a water system that is rarely run. Have you noticed this smell from other taps in your house? There are inline charcoal filters that can remove it from the water, or you can also try removing the water lines from the washer and running them awhile.
Is this new, or has it been happening for awhile?
Dec 04, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Jacuzzi jets smell like rotten eggs when turned on.
Any time you get a strong smell of rotten eggs it is due to a high concentration of sulfer in the water. Are you on well water? I would suggest using a cleaner like http://www.sani-bath.com/ to clean out your system.
Mar 17, 2010 | Home
My front load washer has bad rotten egg smell when draining water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} A lot of machines can suffer from this problem. It is usually down to a bacteria build up between the drum and the tub. The majority of appliances that suffer form this have been used mainly on 40 degree washes and with a biological detergent.
The best way to get rid of this smell is to place two tablespoons of washing soda or soda crystals in the detergent drawer and then run the appliance empty on the 90 degree wash. You may have to repeat this treatment several times before the smell goes but it will go eventually.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Jan 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Terrible smell during washing cycle!
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it.
Nov 27, 2009 | Kenmore Elite 45986 Front Load Washer
Laundry room smells like rotten eggs
Does the sewer drain line have a trap at the bottom that prevents sewer gas from entering the room? If the smell seems to be coming from the washer itself, run a wash cycle empty with a cup of baking soda, detergent and hot water to clean the interior.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Smells like rotten eggs
The smell of rotten eggs normally means you have some water that has been sitting arround awhile and has gone bad. You may have to unplug your machine and remove the front cover to take a look arround the inside of your machine to see if any water has leaked out and has puddled up. You may also have something caught in the drain pump's filter, which may have gone rotten from sitting around too long. This filter is easy to unscrew and gain access to once you have the front cover off. Make sure you have lots of towels or a wet vac handy when you unscrew the filter cover.
Jul 26, 2009 | Kenmore Elite 45986 Front Load Washer
Front loading washer
it could be that your motor in the washer could be blowin or your belt
Feb 11, 2008 | Kenmore 24832 Top Load Washer
Rotten Egg Smell
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Jan 21, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
179 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
