Question about Infinity BASSLINK Car Subwoofer
Phntom bass sounds
I have a basslink installed in a 1997 Cherokee. Works fine, except I am getting phantom bass sounds that sound like the bass to some other song cutting in, even when sub turned down. Just comes out of nowhere. Only solution is to shut off sub, which is no solution at all. I had it installed at Best Buy a few years ago.
Suggestions?
  • Praz Sep 23, 2008
    Hi looks like this the week for BassLinks to start doing the phantom sounds. I got my BassLink installed by Best Buy in my 08 Mazda 3. The sub started doing the same thing in the last week. I actually stopped on my way to work b/c I thought something was rolling around in the trunk. On my way back from work in the afternoon, the phantom thumps happened again and then the BassLink just stopped working. About 15 minutes later, it cut back on again and seemed to be okay the rest of the way home. I've got a 6pm appointment at Best Buy tomorrow to get them to look at it. FYI I usually play music from my iPod using the aux port and a 2 sided 3.5mm audio cable with the iPod EQ set to OFF. Plus I usually keep the sub settings pretty low (1/4 gain and boost and volume 1/4 - 1/2).
  • Praz Nov 03, 2008
    Ok an UPDATE. The last time the phantom bass sounds occurred, the sub went off for 15 min and then came back up. That was abount a month ago I guess. So it happened on Friday again, but this time the sub hasn't come back up. The servo light doesn't light up w/ the beat, but the power light is on. I took a look at the fuse but it looks ok (though I'm not sure what a blown blade-style fuse looks like) - I figure the power wouldn't come on if the fuse was blown, right?
    I have to take the car to BB to get an XM receiver installed, so I'll tell them to try thicker gauge wire for the ground wire. The one they used initially is really thin. Hopefull that helps...
Uhhh....try you change your wire setup
Posted on Sep 20, 2008
Back speakers can't handle bass
you need to replace all the speakers in the truck except the front tweeters if you have them. I replaced all four with new infinitys from futureshop. Installed it was near 500 dollars. You need to get 2 ohm to match the infinity deck if yours is infinity. Most other systems are 4 ohm, these are 2 x 2 ohms for 2 and 4 ohm use. the factory's are garbage and use paper cones. The rears have plastic caps holding the tweeters in. On all four the paper was ripped away from the magnet and it caused them to vibrate and shake, once replaced with 180 watt infinitys...great sound.
Jul 06, 2010 | 1997 Jeep Grand Cherokee
Basslink works in 'on' but not when the engine is running
check your amps ground wire i had similar prob the vibration from engine caused the wire to move interupting the current
Jul 19, 2009 | Infinity BASSLINK Car Subwoofer
Basslink red light on but no sound
check the all power lines and regulator .is any of them overheating?
then check the power amp ic or transistors.
nuwan.
Jan 12, 2009 | Infinity BASSLINK Car Subwoofer
Infinity Basslink
That popping you hear is most likely the voice coil blown and your not going to get much out of it now. Discontinue use of the unit so it doesn't blow the amp, and you can get the sub replaced if you don't want to toss it.
Good luck, hope this helps
Aug 02, 2008 | Infinity BASSLINK Car Subwoofer
Basslink keeps cutting off into protection!!
From what i have heard, If you have a speaker level input connection. this sympton does occur. You buy a scosche LOC and try giving the input to Basslink, it should work fine
Jun 24, 2008 | Infinity BassLink II Car Subwoofer
Infinity basslink is messed-up
You may have blown the fuse in the AMP. Check it and let me know.
Jan 15, 2008 | Infinity BASSLINK Car Subwoofer
Infinity Basslink 2
Follow these instuctions and piece together where you went wrong. Sounds like a wiring fault.
http://www.ehow.com/how_5829_wire-car-stereo.html
Dec 23, 2007 | Car Audio & Video
Basslink II problem running off speaker input
Definately a wiring issue. Go to this site and backtrack to see where you went wrong. hope it helps.
Dec 12, 2007 | Infinity BassLink II Car Subwoofer
Basslink intermittant
i posted similar prob. servo lights when power is being cut to speaker (over drive) and manual shows it for purpose of tuning gain. it should flicker at highest input only...mine is on always too. infinity wasnt much help since mine is out of warranty.
Nov 13, 2006 | Infinity BASSLINK Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
128 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
