Question about Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660
The keyboard entry on my Nuvi is miscalibrated. The touch is shifted by 3/4 of a character. It makes it difficult to select the right side char's (it's shifted left).
Is there any way to recalibrate the touch screen?
  • Garmin Master
  • 2,130 Answers
Have you tried the Recalibrate Screen option in the tools menu? It may be in the "Display" option. I don't have a Nuvi in front of me to walk you through the steps but there is an option for it.
It will show you dots at various locations on the screen and you touch them. By doing so, it calibrates the screen.
- Jim
Posted on Sep 24, 2008
Device: Garmin Nuvi 660 NA. After power on, nuvi boots thru to the "Where to" page. On the prior page, the touchscreen will not click "Enter" but after a time delay, nuvi proceeds to...
*Master reset your Garmin Device:
1.Start with the unit OFF and unplugged from power;
2.Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
3.Continue touching and holding the lower right hand corner of the screen then power the unit ON
4.Release the power button when the device powers ON
5.You will see a new message: Do you really want to erase all user data?
6.Remove your finger from the touchscreen when this message displays - Touch Yes
7.The device will automatically reset. Please follow the on screen prompts on the nuvi .
*If the touchscreen is incorrectly detecting where your finger touches the screen, the screen may need to be calibrated.
1.Power the unit On.From the Where to? and View map screen, touch Settings . Touch Display>Touch Re-calibrate
2.A new screen will display that says Press Dot,Touch the Center of the Dot.
>Keep touching the center of the dot as it moves around the screen.
3.When Calibration Complete appears on the screen, please touch OK.
The screen will now be Re-calibrated.
*If the screen is not responding to touch, the device may not have enough power to function properly. Recharge the battery completely and try again. If the battery does not charge, it may need to be replaced.
If the screen is still not responding to touch commands or displaying properly, the display may need to be replaced. If sound comes from the device, it is likely the motherboard is working, and only the display needs to be replaced.
Refer to:Garmin Nuvi 660 Screen Replacement Guide
Before replacing the display, check that the ribbon cables connecting the display to the motherboard are connected securely.
Oct 04, 2011 | Garmin Nuvi 660 GPS Receiver
Tap the letter or number and display shows the letter or number directly below.
This is due to a miscalibration of the touchscreen. The touchscreen needs to be recalibrated. A procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1286154637
- Jim
Feb 26, 2011 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 610- working perfectly then sudden crackling and now loss of sound/or at best crackly and intermiitent sound- but map/navigation and on-screen directions fine
Check the audio output setting on the nuvi. There is a possibility that the FM Transmitter setting has been turned on or that the device has been muted.
To check the audio output setting:
  1. Touch the Speaker icon below the Wrench icon.
  2. At the bottom of the screen, touch Audio Output.
  3. Make sure that the Internal Speaker is selected and touch OK (660, 670, 680, and 5000 models only).
  4. Make sure that the MUTE box does not have a check mark in it. If it does, touch the box to clear the selection.
  5. Make sure the volume level is at a reasonable percent level.
Sep 24, 2010 | Garmin Nuvi 610 GPS Receiver
Nuvi 660 screen locked
I HAVE THE 205 UNIT MY LOCK IS ON THE POWER BUTTON SLIDE IT TO THE RIGHT IT LOCKS AND PUT IT IN CENTER TO UNLOCK - YOURS SHOULD BE CLOSE TO THAT - HOPE IT HELPS
May 09, 2010 | Garmin Nuvi 660 GPS Receiver
No sound
Aug 13, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 touch screen freezes up. Soft
I sat on the phone for 30 minutes waiting for Garmin support when my Nuvi suddenly had no touch screen response. They had me delete a file on the device (with it hooked to my computer) then reboot and it went thru a touch screen alignment and it worked.
Sadly, it has frozen again and I don't recall the file (it had been a GCD file in all caps, that is all I know and I don't see a file in all caps any more). I will be calling support tomorrow.
My take is that it *is* a firmware thing *and* there is some way to reset the firmware.
May 01, 2009 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 670 touch screen is not calibrated
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
- Jim
SHARCNET- USA
Dec 09, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin 660
Try to recalibrate the screen. You could be touching the adjacent character since are you see is **** as you enter the PIN.
Jan 08, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
139 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
