Front loader? Welcome to our hell.
Seriously though - it's not that bad. You need to have a different mindset with these machines. First, throw away your old detergent. You've GOT to use the type with the HE logo on it. Really. There is a difference.
Wipe out any standing water in the gasket between the drum and door opening after the last load of the day.
Leave the door open slightly to allow air to flow around between washes.
Open the other doors for detergent, bleach, etc. between laundry days.
Don't use liquid fabric softener. Use dryer sheets instead.
Run a small, empty load with hot water and bleach ONLY. No clothes, as your last load for the days that you do laundry.
Use a product like Affresh, once or twice to rid the washer of existing smells. You can use Affresh any time the smells start coming back - and follow the suggestions above.
I hope this helps you as much as it helped me when I learned it! Good luck!
SOURCE: clothes smell
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: All my clothes smell horrible especially after a
you need to use some type of dis infectant in a wash cycle. sometime that will kill mold and bacteria. and start leaving your door open. i seen appliance direct talk about that on there web site. i believe they sell some special treatment for that issue
