Every time i plug the usb cable into my pc to link to i tunes, it crashes the pc and reboots it. if i keep the usb cable in its slot it just automatically reboots. have been on to apple but after 2-3 hours of trying different ways around it im begining to tear my hair out. anybody had the same problem ??? im running windows xp
It sounds like either a faulty usb socket or a driver issue with usb on your system... do you use microsoft update to keep your system up to date and the drivers current? if not you should do so. If you have more than 1 usb socket on your computer try one of those... remember itunes/iphone/ipods use usb version 2 and may not work properly if you have the older usb 1 standard on your computer
That occurs when the update did not complete successfully or because of a newly installed app, if you go to recovery you will lose all you data as it will do a factory reset, to avoid this here is what to do. Download the LG Mobile Support Tool and install it, you can google for it or go to LG website and search for it there. With your phone off and not plugged into the PC yet, open the mobile support tool with the USB cable plugged into the PC but not into the phone, press and hold the volume up button and power button at the same time and while holding those buttons down plug the cable into the phone micro port. Keep holding them until you see a circle made up of two arrows , that puts your phone into downloader mode, looking at the software you should see on the left that it is trying to connect, if it does not , then you press install USB option under connecting, if it does connect it will show your phone model and if an update is available, you can press the center button on the left side, entitled update and let it complete the process before removing it from the PC, this should not affect any info or apps currently installed including your contacts. Good luck
If it is a USB webcam, then First BEFORE you plug anything in, install the software/drivers, that came with the Camera. When installed, reboot. Then when at desktop next, plug in the USB cable. The Camera will/should detected by the PC, it may ask for drivers, if so point it to where the CD/Drivers are, when it seems finished, reboot. Now, when your PC reboots this time your camera should be ready to use. You can use your webcam either with the software program that came with it and you installed. Or you can get a program, freeware, called AmCap2.
Here is a link for your convenience.
http://en.softonic.com/s/amcap-2.0-webcam
If it gets to windows and gives a Blue screen before rebooting I would try updating graphics drivers. If it wont even begin to boot Windows you may have a hardware problem.
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
You have to leave it on itunes for about 15 mins, let the iphone download the software itself, once the software update is done, the usb and itunes logos will come again you have to leave the phone in the usb for a while and then it will work.
From Control Panel > Priinters, remove all printers.
Unplug USB cable to printer and reboot.
Install software for printer. I would suggest using the newest drivers from the manufatures site. I would have given a link if I could, but you didn't post a make or model number.
1.Remove the battery, SIM card and the memory stick from the phone and then replace the battery but DO NOT turn it on. 2.If you're operating Windows XP or earlier use your PC suite however with Vista you might have to download Sony Ericsson's Update Service software from the Sony Ericsson website 3.Then you'll have to download: WontanClient server, open it and allow the program to update. NOTE: you must leave the login box empty 4.Plug the USB cable into the computer but not the phone 5.Press start in Wontan 6.Press 2 and 5 Simultaneously 7.Plug your phone in and hopefully the phone will to reboot 8.Take out the battery for a few minutes and now your phone is hopefully working again. ---------------------------------------
Hi Jane, I just imagine: 370 photos, some more sounds than the 64 poliphonic sounds, and music reader by default...no more memory from those 92Mb. That's why there is no more memory to comunicate. All you need is
SAMSUNG E530 SGH-E530 PCB160LBEG/STD PC Link Cable
Connect your phone to your PC or Laptop, to transfer files to and from your phone
