Question about Whirlpool Kitchen Ranges
Whirlpool stove RF368LXMS exceeds the tempeture limit and both broiler and bottom heating elements turn on.
  • 27 Answers
SOURCE: Magic Chef 6551WUW Oven
is the element still in one piece and mostly smooth to the touch? if you find any part of the element very rough where it looks like it actually melted then you've found your problem. post an update if this doesn't solve the problem.
Posted on Nov 01, 2007
hotuna
  • 288 Answers
SOURCE: Oven not working in Bake setting
Visually inspect the element for any kind of rupture on the shield covering the element. If it looks good the next step is the wire connections at the back of the element. Most likely is has a burnt wire.You will have to pull the back cover off to check this.
Posted on Nov 04, 2007
fridgetech
  • 473 Answers
SOURCE: GE Spectra XL 44 Gas Oven Bottom Heating Element Faulty
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 05, 2007
ranger25
  • 72 Answers
SOURCE: my electric glass top stove won't heat up?
They have a thermal overload resistor in the burner itself and they have a propensity to burn out, or it could be the infinite switch. You will have to check resistance across the leads that correspond to each pinout. You can find this out by backtracing the wire to each terminal on the block. Replacement of either part is the only option, there are no safe alternatives to repair them. Hope this helps. BTW, you can go here for parts.
www.appliancepartsdepot.com
Posted on Jan 28, 2008
aborcass
  • 2651 Answers
SOURCE: MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Posted on Mar 06, 2008
Whirlpool Gold Series stove. When turning on the oven to pre-heat, the broiler came on and we got a fault saying FAULT - PRESS ENTER TO RETRY.
Appears the burner is faulty, check connection at burner receptical first then check with meter for opens. Here is the Whirlpool link for parts repair manual etc. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.whirlpool.com/services/replacement-parts.html&ved=0ahUKEwiCvdH97rDTAhVk7IMKHX4gAtMQFghZMAA&usg=AFQjCNEsdfUwvP3qyVcDj7qJikAtiHTfUQ
Apr 18, 2017 | Whirlpool Kitchen Ranges
When baking in whirlpool accubake electric stove model GR475LXMS only the broiler works not bottom element what could be wrong?
The element could be open or the thermostat for the oven could be stopping power from reaching the element
Oct 17, 2016 | Whirlpool Ovens
REPLACED UPPER HEATING ELEMENT AND THE TEMPERATURE SENSOR. OVEN AND BROILER STILL NOT HEATING UP.
Your machine has an "upper broil hi-limit thermostat" that has likely tripped and is not allowing L2 to your element... Range Stove Oven High Limit Thermostat WP71001844 If you get no heat anywhere, reset your circuit breaker! It can trip halfway and you can't tell by looking at it...
Jul 09, 2016 | Maytag Kitchen Ranges
The broiler element on my Whirlpool RF368LXPB model stove stopped heating. the stove is 8 years old. Any suggestions?
When you press the broil button do you hear a click if you do you need a new element if you don't you need a new control board
Nov 04, 2013 | Kitchen Ranges
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The broiler or baker won't ignite when I turn on oven
if it is all electric then you probably have bad heating coil elements.
If it is a gas then you probably have a bad electric igniter, unless it is an older model with a pilot flame, then you have a bad thermocouple.
Mar 14, 2010 | Whirlpool Kitchen Ranges
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
Mar 05, 2008 | Kitchen Ranges
HOTPOINT ELECTRIC STOVE
two things---when you open the oven door do you see a button on the right or left side?if so thats a door switch and if its bad you will get no voltage to the element.the next thing is your hi limit is bad.this is a sensor that monitors the temp of the oven and if its bad you wont get any heat.some hi limits reset themselves others you have to manually reset them.let me know.
Jul 30, 2007 | GE JKP15 Electric Single Oven
Kitchen Ranges Logo
150 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
