Still having problems with computer
I am unable to access the web with this device because of no 'IP Address'. My IP (Verizon) believes that the problem lies in the RealTek RTL8139/810k Ethernet driver. In the 'Device Manager' I uninstalled it with the intention of reinstalling it but thought that it was the driver I was dealing with. Now I don't know how to reinstall it.
I also have lost my ability to open MS Outlook 2003 on my laptop due to error 'Missing Extend.dat'.
Don
  • Donald Cobane Sep 18, 2008
    I posted what has been happening via e-mail. Look forward to your contacting me. Thanks.
    Don
    Sergeant:
  • 241 Answers
Hey Do it sound like you are having a lot of problems. I can see if what ican do for you ok.. Give me some time
I am so busy and I really had know idea that you were still having this problems OK
Thank You
Jayson
Posted on Sep 17, 2008
  • Jayson Brollini
    Jayson Brollini Sep 17, 2008
    I am still here so post here if this going to make it easier for now.... I will try to Call but I have to finish up my other customers.... You are in good hands ok so just please stop deleting and uninstalling things until I get back to you . It will be today/Night You are in WA
    Please Post every thing that you tinkered with and were told to uninstall. Make a list and you can email me... Or post it here... MY email will be on the Chat post not in here ok .......
I have been trying to set up the Ricoh 1224C on my Mac OSx 10.4.11 network. I am unable to find the scanrouter v2 admin utility for mac. Is there any way for me to access/update the destination list and...
The Scanrouter program is windows only.If you web into the interface using the ip address I believe the log in is admin and there is no password.
Mar 02, 2010 | Ricoh Aficio 450 Copier
How do I add a new user to scanfront220p
Best advice is to access the web menu on the device and log in as the administrator.
Firstly, the network scanner needs an IP Address in order to access the web menu. You will need to log in as an administrator to change the IP address settings on the device.
I found that the default "administrator mode" password was just blank - no password whatsoever.
Sit down at the scanner and click the administrative mode or administrator button at the login screen. You should be prompted for the password.
If you have a router that uses DHCP then be certain that the device is configured for use with DHCP. Otherwise, configure a static IP address on it that is within the IP range of the network it is connected to.
Once you have either discovered the IP address of the scanner or assigned one manually you will want to go to another computer on the same network.
To access the web menu you will need to go to the IP address of the device - I.E. if the scanner has an ip address of 192.168.0.2 type in:
192.168.0.2
into a web browser (as though you were typing in http://www.google.com - ONLY type in the numbers and periods). The web browser needs to be on a computer that is on the same network or connected directly to the scanner via an ethernet cable and have an IP address set statically on its network card. I would google "Setting a static IP Address" and the name of your OS.
From there you will see a "To Administrator Mode" link in the upper right hand corner of the Web Menu screen. Click on that and authenticate with the same administrator password that was used earlier.
You should be able manage user accounts from within the administrative web menu!
Feb 11, 2010 | Canon ScanFront 220P Flatbed Scanner
How do I open ports 500, 4500, 53, and 52428 on Dell TrueMobile 2300 wireless router. Need to open them for Verizon Network Extender
1.Open the router interface by checking the default gateway
2.Under FIREWALL, you can find an option that would say "Virtual Servers"
3.Enable these ports, along with their types(TCP/UDP/Both) and assign an IP address that your Verizon Network Extender is going get( you to set that manually on the verizon device)
Save the changes and the ports will get forwarded!
**Note: In this case, DMZ under FIREWALL will NOT work!
Jan 18, 2010 | Dell Wireless 2350 Router
JN763. Access rejected from your IP address.
Jul 27, 2009 | Computers & Internet
Access web configuration
Note: Not all D-Link routers, print servers and access points have a web-based configuration utility. Please check the manual for your particular product. In particular, the DWL-900AP does not have a web utility while the DWL-900AP+ does have a web utility. You cannot gain web-based configuration utility functionality for the DWL-900AP by installing the DWL900AP+ utility. When entering the IP address of the D-Link device (192.168.0.1 for example), you are not connecting to a website on the Internet or have to be connected to the Internet. The device has the utility built-in to a ROM chip in the device itself. Your computer must be on the same IP subnet to connect to the web-based utility. Make sure you have Java enabled and are using an updated web browser. We recommend the following: Internet Explorer 5.5 or higher Netscape 6 or higher Mozilla 1.2.1 (5.0) or higher Opera 6.0 or higher Safari 1.0 or higher (with Java 1.3.1 or higher) Camino 0.7 or higher Firefox 0.8 or higher -------------------------------------------------------------------------------- Internet Explorer 6 (SP1) users: If you continue to receive Error 500 when trying to connect to the web-based configuration of your D-Link device, make sure you have the latest Windows update for Explorer 6. -------------------------------------------------------------------------------- If you have Windows XP or Server 2003, you must download the latest Java patch from www.java.com. Click here to download patch - http://www.java.com/en/download/index.js... To resolve difficulties accessing a D-Link model that has a web utility, please follow the steps below. Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on. What type of cable should I be using? - http://support.dlink.com/faq/view.asp?pr... Step 2 Disable any internet security software running on the computer. Software firewalls such as Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, and Windows XP firewall may block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Step 3 Configure your Internet settings. Go to Start > Settings > Control Panel. Double-click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows. Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.X range. Click here to find your IP Address on your computer - http://support.dlink.com/faq/view.asp?pr... If you are attempting to configure a D-Link router, then make sure you take note of your computer´s Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range. Click here to set a static IP address on your computer - http://support.dlink.com/faq/view.asp?pr... Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration. There are several more FAQs that cover the configuration of the different D-Link routers, Access Points and Print Servers.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Access configuration
Feb 16, 2006 | D-Link DI-704P Router
Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on. Step 2 Disable any internet security software running on the computer. Software firewalls such as Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, and Windows XP firewall may block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Step 3 Configure your Internet settings. Go to Start > Settings > Control Panel. Double-click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows. Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.X range. Click here to find your IP Address on your computer If you are attempting to configure a D-Link router, then make sure you take note of your computer´s Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range. Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration.
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
Can´t I access the web-based configuration
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Electro Med Services...
