What would cause your inks to build up on the back edge of your blanket to the piont it slings
    Novelist:
  • 217 Answers
Dirty platten usually
Posted on Sep 17, 2008
Dual control electric blanket doesn't get warm, the controllers just blink
The problem can be caused by a defective heating element in the blanket.
Nov 24, 2013 | Sunbeam Electric Blanket Dual Controller...
Can i use a thermal blanket for my Rheem Glasfury 82v40-2 hot water heater
Modern water heaters are well insulated to the point that adding additional insulation is not beneficial. Some units may also suffer from a blanket blocking air vents or causing condensation build up.
Dec 31, 2012 | Rheem 82V40-2 Fury Electric Residential...
Myriad 2 polyester plates constant toning problems, tried different fountain solutions added varnish to the inks need your expert advise
Darrellf674
Did yor even find a resolution to this problem? I am having a similar issue. I have ink transferring from the non image area of the plate to the blanket. I can't see the toning on the plate but I sure do see the ink on the blanket.
May 05, 2011 | Xante PLATEMAKER 4 Laser Printer
Noisy freezer, could be fan or condenser
I wouldn't defrost it. It could be a couple of different things causing this, from a bad defrost thermister to cubes overflowing out the back of the ice bin. Try removing the ice bin and clearing the cubes off of the dispenser motor cover. The fan will eventually sling the ice formation off.
Feb 14, 2010 | GE Refrigerators
Ink absorber full
For the ink absorber to full in most ink-jet printers it is caused by the buildup of the black ink (it is organic based and will solidify). The colored inks are more of a water consistency and will not build up at all. The only way most ink jet printers can clear the black ink build up is to take a flat head screwdriver and scrape the mountain of ink out of the printer. You do have to move the printer heads & carriage out of the way by turning off the printer, powering it back up and when the carriage is out of the way remove the ac power cord! The inks are water soluable so a wet paper towel will clean up most messes with the ink!!!
Nov 26, 2008 | Office Equipment & Supplies
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Is there a drainage plug or hose on the air conditioner? It's leaking.
To increase the efficiency of the air conditioner's cooling to meet US energy requirements, most manufacturers eliminated the traditional drain plug. Instead, they switched to a design that used the extracted moisture from the room to help evaporatively cool the condenser.
To do this, the traditional fan blade was replaced with a 'sling blade' which was a fan blade with a rim or ring around it. The drain plug or drain hole in the bottom of the pan was eliminated and replaced with overflow notches in the back edge. Along with a solid piece drain pan, this provided a pool of water for the edge of the sling blade to dip into and pick up water to 'sling' or spray around the compartment to create evaporative cooling. The overflow notches established the maximum depth of the water pool and are also the lowest place when installed properly.
Although this is more efficient, this has caused 2 problems: increased noise as the water is slung around and water spray from the side air vents.
Persons have drilled holes through the pan or back edge as drains. This is not recommended as it negatively effects the colling ability of the unit and could lead to a voided warranty or premature failure.
Instead, insure that there is adequate pitch with the installation and make sure the overflow notches are kept clear.
If you 'need' a drain hose, my suggestion would be to drill into drain pan's back edge or the rear potions of the sides. The hole should be at the same level as the overflow notches. Once the drain hose is installed, block/cover the overflow notches to redirect the excess water to the drain hose instead.
Jul 07, 2008 | Samsung AW0603B Air Conditioner
Robot coupe maintanance
That plastic piece is a sling disk or sling blade and made to sling product to the discharge chute. Believe it or not, the motor shafts wear out and could be the cause of premature failure. When you install the new sling blade, check to see how much slop/ play there is by moving this back and forth on the shaft, a small amount is ok (1/16th to 3/32nds). The other thing to look at is forcing or overfeeding the unit. You can contact them at Robot-coupeusa.com
Nov 15, 2007 | Robot Coupe CL50 Food Processor
Build up of ice
YES
The thermostat is not cutting out.. It needs to be replaced.. Your compressor risks burning out if its is continoulsy running ...
Nov 14, 2007 | Hotpoint RLA30 Compact Refrigerator
43 people viewed this question
jasbo
jasbo
