Question about Acer Computers & Internet
Acer aspire 5310 following a liquid spillage the laptop has been dried out thoroughly, disassembled ad put back together. All seemes to be working fine, passing all tests i can run on PC CHECK,the only thing which i can find fault with is the bios defaulting constantly, this does not stop the laptop working, as it is a pretty basic bios and not a lot can be modified, do i need to replace the motherboard or can i continue to use the laptop as it is.
    Brigadier General:
  • 5,158 Answers
Defaulting as in date / time ?.... if that is the case ensure that you have put the bios battery back in correctly.... or replace the battery.
Robert
Posted on Sep 17, 2008
My keyboard works except some keys are not working?
Your question is not specific about specifically which keys work and which keys do not work and exactly what you mean by the keys not working, whether you mean there is no reaction at all when the relevant keys are pressed or whether it is just that incorrect characters result from pressing these keys.
If incorrect characters result from pressing certain keys towards the right of the keyboard, use the Fn key, bottom left, pressed simultaneously with the Num Lock key, top right, to toggle 'on' or toggle 'off' the Alternative Symbol function of some of the multi-function keys.
If there is no reaction at all when you press a significant number of keys, then there may have been liquid spillage damage to the NetBook. Liquid spillage damage can sometimes be resolved by partial disassembly of a NetBook/Notebook and wiping congealed liquids off with mild solvent or allowing internalized water to evaporate. This type of repair is best done by an experienced NetBook/Notebook repair center or technician.
If only one or two or a small number of keys do not work, then it might be that particles of some or other substance, trapped underneath the keys might be interfering with the function of the non-functioning keys. This can sometimes be resolved simply by inverting and gently shaking the NetBookso that any trapped particles come loose and fall out. Occasionally, individual key caps have to be removed and replaced after the obstructing particle has been removed.
If several keys are defective but the fault was not caused by liquid spillage or trapped particles, then the keyboard unit itself might be faulty and need to have its internal ribbon cable and cable connectors tested for cable damage or connector damage (typically either from liquid spillage, shock caused by dropping the computer or by previous unprofessional internal repairs). If no fault is found with the cable or the cable connectors, then the entire keyboard unit may have to be replaced.
Nov 19, 2011 | Acer Aspire One Netbook 8.9" Notebook
Spilled water on my keyboard, touch pad stopped working. Dried it ff and left it for an hour. Unfortunately curser/ Touch pad still not working and can no longer connect to the iternet, seems like the...
When this happens, you should fully disassemble the notebook & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the notebook.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Feb 26, 2011 | ASUS Computers & Internet
Hi. I accidentally spilled coffee on my Asus EEE PC 1000H Laptop. Is it true that its keyboard is waterproof? If so/not, what should I do to avoid damaging it permanently? I've been using it for 2 hours...
When this happens, you should fully disassemble the netbook & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
When you are done, re-assemble back the netbook.
Feb 01, 2011 | ASUS Eee PC 1000HA Notebook
How To Fix A Laptop Sony Vaio With Water Damage & not turn up
When this happens, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
When you are done, re-assemble back the laptop.
Jan 02, 2011 | Computers & Internet
Toshiba Satellie L305D-S5974--spilled orange juice on keyboard, keys sticking, speakers not working...what are my choices
Nov 30, 2010 | Toshiba Computers & Internet
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very...
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Nov 15, 2010 | Apple MacBook Housing, Top Case with...
I spilled tea on my laptop. A day later the keys are tyoing the wrong letters.
Oct 26, 2010 | Dell Studio 1737 Laptop
I spilt a little water on it yesterday! It continued to work fine. But now today, the battery light is off and on flashing even though I have it plugged in and it will not turn on.
1. Unplug the AC adapter.
2. Remove the battery.
3. Disassemble the laptop & clean all internal components.
4. Assemble it back & test it.
When this is done, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
If it still does not work, the motherboard might be damaged & needs to be replaced.
Oct 06, 2010 | Dell Latitude E5500 Laptop
Laptop keyboard needs cleaning
I had a client with that problem--we removed the keyboard and tried to clean it. Turns out that our cleaning job was less than perfect because the laptop keyboard is mostly sealed. There was liquid that seeped down onto the motherboard as well--that we could clean up. The long and short of is--you will probably need to replace the keyboard. Of course, with nothing to lose, you could wash the keyboard and let it dry out thoroughly, plug it in, and see if it works. The key here would be the thorough drying. If you decide to try this chancy procedure, don't dry it with high heat. A hair dryer set on low might be the answer.
Feb 04, 2009 | Acer Aspire 3634WLMi Notebook
Regarding drivers of acer aspire 5310 laptop
Hi - You can download the software from the link below:
Aspire 5310
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 05, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
67 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
