Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool model ed5jhgxrboo
I replaced my module and after each drop of ice the arm goes up about an inch and stops making ice then i put the arm down the dial turns and stops and struggles untin the heater loosens the ice
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
  • 958 Answers
SOURCE: Stop making ice
check if there is ice in the ice maker, see if there is water coming in to the ice maker. maybe a water problem or a solenoid problem...if there is no ice in the ice maker...try to pour manually a cup of water on the ice maker and empty the ice bin so that you can observe if the ice maker is working if there would be ice in the bin after an hour. if there is ice, then a water problem is most likely to look at. i hope the freezer is working perfectly..
Posted on Feb 12, 2008
  • 172 Answers
SOURCE: I have a Whirlpool side
Humm thats a good one, but I will try to help you out. First off you say the icemaker is new, so does that mean you bought the icemaker and installed it on the refrigerator. Or is the refrigerator new and it has an icemaker. If you installed the icemaker new on an older refrigerator you can have a few problems. Most likely the freezer is not getting cold enough for the icemaker to cycle on its own. Especially if you are peaking in every few minutes like I would be doing. The icemaker will start a new cycle when the temperatur hits 0 degrees. If the freezer is only getting to 5 degrees the icemaker will not cycle. In that case the problem would be with the refrigerator not the icemaker. If the freezer is getting to 0 degrees then you may want to take that icemaker back and get a replacement. Good luck and I hope I helped. mca0824@aol.com
Posted on May 02, 2008
  • 1073 Answers
SOURCE: Ice Maker Won't Drop Ice
you have a problem in the module of the ice maker if it is new take it back for a new one
  • 1073 Answers
SOURCE: Whirlpool Gold icemaker not working Model GD5SHAXLB02
problem with the heater or the thermastat of the ice maker
Posted on May 11, 2008
My maytag msd2433he only makes one tray of ice. It has a new filter, plenty of water pressure and no air in the line
Hello Dave;
My name is Peter. I am a retired field service refrigeration technician.
Lets run a check on your ice maker:
1.) Remove the plastic front cover on the ice maker. Do not unplug your unit and do not remove the ice maker. Having removed the cover you will see a white gear with a plastic shaft in the center.
2.) On the right is a metal wire arm for turning the ice maker on and off. Put the arm in the down position and then lift it up until it locks in place. Did it lock? If not reinsert the wire end into the back of the motor module. The motor module is the assembly with the plastic gear.
3.) Lets cycle your ice maker. On the front of the ice maker there are 2 holes at the 5:00 position off of the dial they are marked 'T' & 'H'. With a short length of about 12 gauge wire, strip about 1" off each end. What you are going to do is put on end into the 'T' hole and the other end into the 'H' hole. A few seconds after the dial starts to rotate remove the jumper. Observe the complete cycle.
Does it fill with water?
4.) Remove the ice maker. There is 1 screw on the bottom - completely remove. There are 2 screws on the top. These are hangers. Back off the screws so you can lift the ice maker up and away from the wall. With a small screw driver wedge it into the wire harness connector to release.
5.) Remove the 3 retaining screws and disconnect the control arm. Inspect the subassembly for burn marks or broken plastic parts.
6.) You may have a bad thermostat. The thermostat is located between the ice maker module assembly and the cast steel ice cube mold. This sensor tells the motor module that the water is frozen. Then the motor module tells the heater which is on the bottom of the
mold, that the water is frozen and for the heater to turn on. Then the module tells the motor to rotate the harvesting fingers. Maybe a bad heater? Maybe the motor module is bad? Parts are available for your ice maker unit.
Nov 04, 2014 | Maytag Refrigerators
Whirlpool Model ED25DQXXN side by side with ice maker running.
either lift the arm up and this should stop it or u can unhook the plug for the icemaker thats about ur only 2 ptions
Feb 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker control arm goes up enough(by itself) to not dump cubes until manually put in down position again. Is there an adjustment or repair/cleanining I can do?
The arm is hanging up internally . Other than replaceing the ice maker , go to a hardware store , and buy a few stainless steel nuts ( for bolts ) . Unhook the fill cup end of the arm , and install a few nuts . This should give enough weight , to make the arm drop .
Sep 30, 2009 | Refrigerators
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore ice maker not releasing ice - it stays in the bottom and ice maker makes sounds like it's trying to kick it out but doesn't. It's frozen in a big block.
Sounds as if your water valve is letting too much water in and too big of ice cubes won't let the rake strip out the ice. Look and see if the ice in the tray is up to the round arm with the fingers. If it is then the water valve needs to be replaced but you will need to get that ice outta there. Take the ice maker down by removing the 2 screws holding it above the tray. Sometimes there is one under the tray as well. Unplug the ice maker and run hot water over the tray keeping the water away from the electronic part. This will release the ice and then reinstall the ice maker.
Another possible problem is the motor module may be broken. Pull the white cover off the front of the ice maker. This will take a little elbow grease. When you access the module (You will see a white dial about as big as a half dollar) see if right in the center of that dial one of the two prongs holding that dial is broken. If you pull on it a bit and it comes off then you are sure that your module is bad. To replace it...remove the three Phillips head screws holding it on. The shut off arm will also be attached...just pull it out with a good tug. Pull the module straight out and replace the module. When replacing the module, you may need to rotate the arm in the ice maker with the fingers on it to fit in the slot in the center of the module. You should have ice within two hours.
Apr 11, 2009 | Refrigerators
Ice maker won't shut off when full
check the Shutoff Arm:
An arm extends away from the ice maker over the ice cube bin. During each ice making cycle, the arm rises up and then drops back down after the new ice is dumped into the ice cube bin. As ice accumulates in the bin it prevents the arm from dropping back down. When the arm is high enough, the ice maker shuts off and no more ice is made until the ice level in the bin drops.
The ice maker can also be turned off manually by lifting the arm all the way up into a locked position (shown belowef280e4.jpg
The arm is supported at one or both ends. One end extends into the back of the front support (see photo above). If it is not securely in place, it could cause the ice maker to malfunction. Confirm that the arm is securely in place.
For proper operation, confirm that arm is in the lowered position and that nothing is blocking it from normal movement.
To test the shutoff function, lift the arm up into the manual shutoff position. Recheck the unit later to confirm that no ice is being made.
If unit continues making ice even when the shutoff arm is in the up (off) position, refer to the diagnostic table or for a modular ice maker, replace the control module.
check the Shutoff Switch:
Before testing the shutoff switch, unplug the refrigerator to avoid an electrical shock hazard.
There are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver.
Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. Component units (like the one shown below) usually have exposed gears and don't have holes for test probes.
Modular units do not use a separate shutoff switch. Instead follow this link to view instructions for checking the shut off arm.
Jan 30, 2009 | GE Monogram ZDI15C Automatic Icemaker
Whirlpool Ice Maker Won't release ice
Jetguy77,
I have a 1993 year (16 years old now) Whirlpool side-by-side with icemaker, Model ED22PW. I have had similar problems with the icemaker - water goes in, freezes, but ice does not eject from tray. It has happened to this unit 2 times since 1993. It turns out the problem is not the thermostat. It is the icemaker motor module. The icemaker has a small synchronous (clock) motor that rotates the ice ejector. When it goes bad, the ejector does not rotate, either because the module timer had failed or the motor itself has failed. The solution is to go to your nearest applinace parts dealer and by a new "icemaker motor module" for Whirlpool Model (your model here). Mine cost $58.85 the last time I replaced it in 2006. To install the new module, you will need to remove the icemaker from the refrigerator. Mine has 3 screws that attach it to the side. Also unplug the power & control cable. The water tube slides out when you pull the unit forward. When you get it out, it is then easy to remove the motor module and insert the new one. You may have to reset the timer on the module to get the tray to fill completely.
Jan 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Kenmore Elite refrigerator won't stop making ice
sometimes when you pull the shelf in and out, it will bind on the shut off arm and cause it to "pull out" of the i/m module. the arm has to be put back into the back of the module. you can take the i/m out of the freezer or just use a mirror and look for the place the arm goes. it looks like a 1/4", round, white plastic slot. the arm just pushes into the white piece and thats what causes the i/m to shut off when full or when the arm is lifted up.
Dec 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Ice Maker not dropping ice
Sounds like the arm which determines if ice bucket is full is hanging up on something. Does this arm move up and down freely? If not, you just need to replace the complete ice maker.
Nov 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker stopped making ice
hi there,
sounds like the i/m is making ice. if you have ice in the bucket, it means that the only problem is the dispensor. if you have frost anywhere, the problem is with the actuator, which is the ice pladdle. you may have a broken spring or just the ice paddle need to be replaced.
Oct 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
54 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
