Was chatting with marked about my c4480 hp printer
Trying to connect it to a usb port as the printer does not show in the device mgr
    Scholar:
  • 95 Answers
According to the specs, the printer can only be setup using the USB port. The easiest way to install this is going to be to insert the CD that came with the printer, and reinstall it. If you have misplaced the CD, you can download another copy of it from hp's website by clicking here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3418705&. You'll need to choose your operating system, then locate the HP Photosmart Full Feature Software and Drivers. Then once it's downloaded, just run it. Remember to disconnect your current printer before beginning the installation. It will prompt you when you are able to plug it back in to the USB ports.
Steven
Posted on Sep 17, 2008
How do I connect my hp photosmart c4480 printer to a wireless network?
Hp Photosmart c4480 is not wireless capable.It can only be connected over USB cable.
Jul 24, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
Hp C4480 Photosmart, imaging device not found, wont scan.
Please try it on another computer and verify it's detected there or not.. If not there's internal problem. In case, it's detected, reconnect on your computer on another usb port. Let me know if you need further assistance. Good luck Thanks for using FixYa.
Jun 06, 2010 | HP Photosmart C4480 All-In-One InkJet...
My hp photosmart c4480 will not print attached to my laptop it keep putting the print jobs in que
start - print and fax - right click on HP Photosmart C4480 - properties - port (change to USB)..
Feb 21, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
My computer is unable to detect this printer when I connect it. What could be the problem? The printer also does not turn off when I press the power button sometimes.
If the printer is not being detected correctly check both ends of the USB cable to ensure they are firmly attached. Do not have the cable connected to a USB hub or other device. If possible, try using an alternate USB cable that has been tested with another device and is known to work correctly. Ensure the USB cable is connected to a port on the BACK of the computer if possible as some ports on the front of the computer do not neccessarily supply the amount of power that is needed for printers.
Check the Device Manager listing to ensure the printer is showing up. To do this power the printer on and right click the My Computer icon on your computer then left click Properties. Select the Hardware tab and click the Device Manager button. Are there any listings displayed with a question mark or exclamation mark? Is USB Printing Support listed under the Universal Serial Bus Controllers section? You may need to click the plus sign beside this listing to expand the category tree.
If the printer is listed with an exclamation mark or question mark, right click the printer and click Remove, then select Action from the top of the window and select Scan For Hardware Changes. This should 'find' the printer again and the drivers should be reloaded successfully.
If the printer is listed correctly, try selecting the printer properties (browse to the printer window, right click the printer and select Printing Preferences) and clickc the Ports tab. Ensure the port that is selected is USBPRN01.
I hope this helps!
Feb 03, 2010 | HP PSC 1510 All-In-One InkJet Printer
I get a message in device mgr. comm3 disabled.
Comm ports are changed in the BIOS. You'll have to look at your screen and it will tell you which key to hit for setup before the Windows splash screen appears.
Jun 25, 2009 | Computers & Internet
New printer not recognized?
Here two causes are possible first your driver that you installed is not insralled properly so turn off your computer, reboot, delete HP Photosmart C4480... driver from the printer list icon and install again properly.(if you will not get the right solution of your problem then try the next step)
Second your U.S.B. cable maybe faulty so change your U.S.B. cable.(if you will not get the right solution of your problem then try the next step)
Third your U.S.B. port of computer is faulty so cahnge the port(many computer have more then one U.S.B. port if you have so try one(if you will not get the right solution of your problem then try the next step)
and
after this all you try your installation on other machine.
I hope you will get your problem solution.
thanks
TTYAGI
Apr 04, 2009 | HP Photosmart C4480 All-In-One InkJet...
Printer is working but item to print doesn't get listed in queue.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
k24674
