Question about HP Photosmart C6180 All-In-One InkJet Printer
Pictures print all smeared and heavy on the ink
I changed the Magenta ink and now the photos print all smeared and heavy on the ink. I used Fixya Premium last evening (worked with mastersaintx) He diecided it is because there was special ink for photos and I had bought the wrong one. Today I went to Staples for the right ink and they said my ink was right. I have changed the paper, the settings, run diagnostics etc. Still pictures smear. Any words of wisdom? Sorry, I don't want to spend another $15. for a dead end solution. Help!
4 Suggested Answers
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
  • 2386 Answers
SOURCE: my lexmark c532dn printer when printing a coloured
it shows that yellow and magenta colors gone end, need re-fill or replacement.
hope it helped, if so rate the solution
Posted on Nov 16, 2010
CreativeTECH
  • 1719 Answers
SOURCE: HP CP2025 Heavy smears of magenta
It is due to spilled magenta toner leaking from side to the toner cartridge. Take the cartridge out of the printer and clean it. Clean visible inside of the printer. Shake the cartridge lightly in horizontal position to evenly distribute the toner inside the cartridge and put it back. The issue sould be fixed after some prints.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Posted on Dec 23, 2010
How can I clean the ink pad?
Take a look here, these issues with the ink pads/cartridges can be a true pain but give this a try:
http://www.wasteink.co.uk/adjprog-tutorial-ver2/
EJ Kudelka
Mar 13, 2012 | Epson Stylus Photo R800 InkJet Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Ink from smearing all over my papers
Using original cartridges won happen like this.
May 30, 2010 | Canon Pixma MP450 All-In-One InkJet...
When I print a picture it is greenish. All the
You need to make sure you are not using the photo magenta, your printer doesn't use photo magenta and it leaves the prints green. You need also to run the nozzle check print by holding the resume button until the green light flashes twice, and see if all colors are printed. If not you need a new printhead, the part number is on the side.
Nov 11, 2009 | Canon I960 InkJet Photo Printer
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
Aug 19, 2009 | HP LaserJet 1300 Printer
Color photos printing very faded
Some nozzles could be burned out on the printhead, and you need to make sure you have no photo inks installed where regular inks should be. Photo magenta prints much lighter than regular magenta.
Aug 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon i9900 isn't printing photo magenta
Use denatured alcohol to soak the print head. Then use suction to draw the alcohol back thru to the foam ports where the ink cartridges rest. Continue until the alcohol runs clear. Then use water and then repeat with alcohol. Allow to dry and re-install in printer. Use new ink cartridges when re-starting printing.
Dec 31, 2008 | Canon i9900 InkJet Photo Printer
Incorrect color matching
probably its print head, it is you that changes its like the ink cartridge .
Dec 21, 2008 | Canon PIXMA MP960 All-In-One InkJet...
Problem with color quality - Canon PIXMA iP4000
i had this problem... its the ink! Check you are using magenta and NOT "photo magenta", and also that you are using "cyan" and NOT "PHOTO cyan"... basically photo cyan, photo magenta and photo yellow are not designed for the ip4000, if you check the smallprint on the box it does not list the ip4000.
This exact problem happened to me and it was driving me crazy. I think the "photo" versions of the inks are for printers that take two tanks of each colour, and the photo version is used for very subtle colours... so if you are ONLY using these inks, photos will appear washed out, yellow etc
Oct 30, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
My Canon i960 printer is printing red streaks on the pages
It's possible that the heads need to be replaced. That's one disadvantage to the printers that don't have the heads contained within the cartridge.
Feb 26, 2007 | Canon I960 InkJet Photo Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
41 people viewed this question
Ben Johnson
