Question about Maytag Atlantis MAV6451 Top Load Washer
Cerfer 39 i have a maytag atlantis model #mav8600aww . i ordered a new transmission for this washer. put it in and this drum still will not spin? their is no electrical connection to the transmission their is a brake on the bottom of this washer, what else can this be? the agitator is moving back and forth just fine, but this drives me crazy! i wonder if it could be an electrical connection that the motors not doing, or what????
I had the same problem today after disassembling and reassembling the same model. In another post they talk about the idiotic white plastic retainers that sit on top of the tub and how mold collects on their undersides. When you replace these, make sure their seated correctly so that they can move independently of each other. The bottom white ring had shifted and locked against the upper ring causing the agitator to stop spinning as well as the tubs. Once I shifted the two rings back to their correct position everything worked normally. Probably a rare fluke but easy to check out and the good news is you don't have to get out a single tool. Good luck
Posted on Oct 26, 2008
  • 943 Answers
Hi thanks for the question when in spin cycle does the motor run. if not the lid switch is the problem if the motor does run. it should spin thanks the appliance doc
Posted on Sep 17, 2008
Should water back up into the tub upon spin completion on maytag atlantis
No, If water is coming back, the sewer is cloged up or is a big posibility that the washers transmission is not spenning at all. it may sound like is agitating during the wash and spinning during the rinse. To check it, put soap inside the drum if it doesn't get disolved after the cycle is done. The transmission needs to be replace. Is costly you may want to shop for a new one.
Jul 19, 2014 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis mav8600aww
There should be and access panel on the rear, lower left side of the washer. This is where the drain pump is. Remove this panel to see if the hose has come off the pump or if it is broken. Here is the new pump in case you need it.
Oct 31, 2012 | Maytag Washing Machines
Out of balance switch will not stop washer when load becomes out of balance.
Your switch is bad. You don't necessarily need the switch. Snip the wires off either side of the switch and fuse them together with a wire connector.
May 06, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Leaking drum on maytag washer.
Go to www.repairclinic.com and enter MAV6000. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Maytag video showing disassembly and replacement.
May 23, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machine staring making a grinding noise now it broken!
No, not the motor. The pump has a steel sleeve that has come up out of the pulley and has locked down the pump. Replace the pump and you will be fine.
Jan 27, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My MAV8600AWW top load washer makes a loud steady squeal whining noise in spin cycle. Load size doesn't affect noise. Machine is 7 years old. Any guess as to problem?
Maytag had problems with the berrings on the transmission . water gets in and the berring goes bad rorring as it spins. Dump it and get a Whirlpool.
Nov 11, 2009 | Maytag MAV8600 Top Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis Mav8600aww
If your timer has a gray rubber ring on it, the timer is in 4 pieces. Pull the top middle part out. Then there's a white locking piece in the center. Once that's out the other 2 pieces will pull out. Note: The photo shows the top cover removed. The locking pin is the white center. RanchMom
Apr 10, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
118 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
