I have a admiral cloths washer .i need to get the back off of it to work on the water lines
  • 943 Answers
Hi thanks for the question the only reason to remove the back is to replace the water valve if this is the problem then . at the top of the console where the top meets the console 2 screms if no screws remove end caps then 2 screws lift up console remove 2 brass clips disconnect wiring harness remove cabinet replace water valve thanks the appliance doc
Posted on Sep 17, 2008
My admiral washer will not fill up with water nor will it wash
Hello Melyssa
Have you tried both hot & cold water?
different settings?
stop mid cycle?
need more info
Jun 10, 2015 | Admiral Washing Machines
Just purchased a new Admiral Clothes washer. When
Could you check and see if both the hot and cold hoses hooked to the back of the machine are actually putting out hot and cold water? If they are, it may be time to return the washer to where you bought it and get another. Be blessed.
Sep 25, 2013 | Admiral AW22 Top Load Washer
Washer does not work well on spin cycle admiral aav7000aww
No you need to check ur clutch, u can check it by running the spin cycle for a few minutes then shut it off and turn machine up so u can look under it. get a spray bottle with cold water and alil soap detergent, then spray the clutch with it, if it shows or steams up or sizzles then the clutch is slipping and bad. the cluth is in the center near the tranny, should look like a round siver pc of metal about 5 inches in diameter
Jul 18, 2009 | Admiral AW22 Top Load Washer
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
Admiral washer, spins too slow so clothes are still soaked
The clothes being wet and the drum spinning slow are probably due to a worn belt, tilt the machine back and the belt can be removed and replaced from below with no tools.
If the machine is constantly filling with water the level pressure switch requires changing. Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up, the pressure switch i at the back LH side, you will see a small pipe attached to it from lower down the drum, replace the pressure switch pull off the terminals and the hose and replace using the same order of connections.
Apr 14, 2009 | Admiral AW22 Top Load Washer
Washer doesn't drain or spin
check here friend for your machine schematic:---
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1
hope this helps... also any parts you require here..
regards..
Dec 02, 2008 | Admiral AAV7000A
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Washing Machines Logo
Top Washing Machines Experts
