Question about Whirlpool GGW9250PL Gas Dryer
ERROR CODE E1 MODLE #GGW9200LW O
I have a whirlpool GGW9200 gas dryer. It will heat up during the cycle but it stops before it's finished showing E1 as an error code. It doesn't do this all the time, but it has to be somethingwrong to cause it to continue doing this . Any help????
  • susanwiss Nov 03, 2008
    I have the same problem, can you tell me where the thermistor is and how to replace it? Is it a part I can find online, or do I need to contact Whirlpool? Thanks!
    Sniper:
  • 88 Answers
E1 error code is for the thermistor, try cleaning off the bottom of the thermistor, (sometimes tacky lint will coat them), if that doesn't help, just replace the thermistor.
Posted on Sep 17, 2008
F7 E1 codes for a whirlpool cabriolet wtw5600xw2
See http://www.appliancepartspros.com/diy-story-f7-e1-error-code-whirlpool-cabrio-washing-machine-diy559429.html should be a big help I also use www.repairclinic.com I am a natural Gas Appliance Tech and Heat Dryers any product hook to our natural gas line do other repair work to
Sep 02, 2016 | Whirlpool Washing Machines
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
Ran out of gas during cycle, filled up tanks now won't heat. Is there a safety switch or something?
Are you sure gas is on for the dryer?
It's possible they have an error code? Can try to unplug overnight, it may reset its brain.
Mar 13, 2015 | Whirlpool Dryers
Shortly after starting a load in the dryer, the dryer stops, beeps and the lighted code says E1. The grid on back wall of dryer is very hot. I am unable to find my instruction booklet. This keeps...
The E1 error code means that the electronic thermostat is the problem. With what your describing as far as it being very hot and the E1 code,i would suspect one of 2 things;
1) the thermister is bad and needs to be replaced
2) thier is a blocked/restricted vent and or excessive lint built up in the blower housing causing the heat to be retained in the dryer instead of being vented out and across the thermister where its getting a false reading and throwing up the E1 error code
GENE
Sep 12, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Stops frequently during cycle...get an "E1" error code
HI, This error code concerns a faulty Thermistor. The actual circuit is open. Check the wiring to this device. if it is ok and, connected properly, replace the Thermistor. it has failed in this case.
Jul 21, 2009 | Whirlpool Dryers
E1 comes on during mid cycle and stops the dryer from drying
replace the compressor "compressor relay and the compressor overload" that are on the side of the compressor.
location: should be in the back on the bottom behind the panel.
if you have a circuit board they may need to be replaced as well.
May 09, 2009 | Kenmore Elite HE4 Electric Dryer
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer stops soon afetr cycle starts, E1 appears
ensure lint trap is clean and venting is not restricted or blocked.
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Feb 10, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer turns off and shoes e1 code
E1- Thermistor open.
It monitors the exhaust temperature, and cycles the heater relay on and off to maintain the desired temperature.
It could be the sensor, or electronics.
May 08, 2008 | Whirlpool GGW9200L Gas Dryer
Clothes warm but not drying
did the coils help at all?? sounds as if its cycling to quickly, forom perhaps a bad cyclyng thermostat or a thermistor(usually would so an error code of e1--e2), you sure this is set for correct tyoe of gas,, lp/ natural???
Apr 12, 2008 | Whirlpool GGW9200L Gas Dryer
Open Questions:
Strange issue with my gas dryer and the control panel I am having a strange issue with my dryer. I have a Whirlpool gas dryer, Model: GGW9250PW0; and am having issues with the Electronic Control (mfg part 8558753). Yesterday, I went to go use the dryer and I press the "Control On" button like normal, but nothing happened. I did not get any lights or anything, yet when I open the door, the inside light comes on. I have a similar model washer plugged into the same electric outlet and everything there works fine. After researching the issue out a bit, I took off the toe panel and took off the duct-lint (mfg part W10128606) so that I could reach the wires connected to the dryer thermister and dryer thermal fuse better. I then took the wires off both of those as well as disconnected the sensor wiring harness (mfg part 3406653) and used a vacuum to clean out any lint as well as compressed air to clean off those connectors. I re-hooked all the wires back up and plugged the dryer in. I pressed the "Control On" button and all the proper lights lit up. I then pressed the "Cancel" button to turn it off, unplugged the dryer, and put the duct-lint back on. I plugged the dryer back in and tried the "Control On" and "Cancel" again, and it still worked. I then put the toe panel back on, pushed "Control On", then turned on the dryer using the "Hold to Start" button and everything worked like it used to. Here is the strange issue I am having. I ran a load in the washer and when done, I put in the dryer and tried the "Control On" button. Everything came up, but when I pressed the "Hold to Start", nothing happened. I then tried to press the "Cancel" button, and nothing happened. I could turn the knob and the different lights lit up, but none of the buttons seemed to be working. After holding the "Cancel" button for a few seconds it turned off the panel lights. I then pushed the "Control On" button again and had to press it a few times before the panel lights came on. After a little bit of playing with the buttons and knob, I was able to start the dryer. I stopped the dryer (didn&#39;t want to run it the whole time in case something is wrong) and tried to start it again. I can get the panel lights to come on, but it seems like the buttons are sticking and not fully working like they should. I don&#39;t want to have to buy an expensive part unless I absolutely need to and wanted to see if anyone can think of anything else that might be going on or that I could try before paying almost $200 for a new Electronic Control, especially if I will still have the same problem after replacing this part like some other people have reported. Thanks!
Jun 14, 2013 | Whirlpool GGW9250PL Gas Dryer
See all Whirlpool GGW9250PL Gas Dryer Questions
Whirlpool GGW9250PL Gas Dryer Logo
658 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
