Question about Emerson MW8102SS 1100 Watts Microwave Oven
Power cord i have a aproblem with a burn power cord harness and was wondering if there is a power cord harness available as opoosed to getting a complete main harness set
  • 706 Answers
If you are referring to the main power cord then you should be able to purchase one at Home Depot/Lowes of most local hardware stores... make sure you get the current rating off the tag on the appliance.. 15Amp or less can use a cord size of 14 gauge.. you should use a 12 gauge for any appliance requiring up to 20Amps ( in your case ..1100 watts minus losses within the system should allow you to use 14 gauge power cord.)
Posted on Sep 18, 2008
Unit has no power nor is display lit up. Have power to cord. tripped breaker. is there an internal fuse behind control panel
Microwave ovens have an internal fuse to protect the unit. Once you remove the white cover it is easily located on a board where the main power cable first goes into. Despite what you hear about dangerous radiation generated by microwave it is sage to turn on the microwave with the white cover off because the radiation stays within the microwave cavity. If you buy pass the door interlock then you may be exposed to some radiation escaping from the door opening. No match can go wrong in a microwave. Usually its something simple like a bad connection a burned fuse .or a burned power supply if it is microprocessor based unit.
Mar 05, 2015 | Microwave Ovens
I see other people talking about getting error codes on their Kenmore microwave. How do you get these codes my unit stopped working completley and the display is blank. I have been told to look into the...
Scott, if everything has gone blank on your microwave and you have no lights when you open the door, it may be the main fuse or even a tripped circuit breaker. Plug something else into the outlet to make sure that the circuit breaker is not tripped. If that is okay, un-plug your microwave and take out the screws that hold the outside cover onto the microwave and then remove the cover. Look for where the power cord goes into the unit and follow the black wire from the cord. It should go to either a small circuit board with the fuse located on it, or it may go to an in-line fuse holder. If you have access to a multi-meter, you can set it for continuity and check your fuse after you remove it from it's holder. If it is bad it will not show continuity. Replace it with the same amperage fuse that you take out. It will be stamped on one end of the fuse and will usually be either 15 amps or 20 amps. Hope this helps!
Feb 06, 2015 | Kenmore Microwave Ovens
My samsung electric range is off but blowing cold air
If the magnetron was making louder noises prior then replace the magnetron. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Nov 30, 2013 | Samsung Microwave Ovens
Samsung microwave keypad
Then you have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Nov 28, 2013 | Microwave Ovens
Ny microwave is arcing up by the stirrer motor even after the motor is disconnected
You may also have to replace the capacitor. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Feb 26, 2013 | GE XL1800 1100 Watts Microwave Oven
THERE WAS APOWER PROBLEM AND MY MICROWAVE COMPLETELY STOPPED WORKING.NO DISPLAY AND NO SIGN OF AN OUTPUT
Check the main fuse inside the oven on the floor of the cabinet near where the power cord enters.
I believe you will find it needs replacement.
May 27, 2011 | LG Microwave Ovens
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Died completely, no power, no panel, disgusted, 2003, brand new, mad and unscrewing model
Find the main fuse on the floor of the device near where the poser cord comes in to the cabinet. Probably needs a 20 amp ABC rated fuse available where electric parts are sold.
Don't be disgusted, you got 6 years out of it so far. As kitchen appliances go, the microwave is probably the most reliable. Treat it well and it will run for many years. Don't open the door while it is operating to protect the door safety interlock switches.
Thanks for your interst in FixYa.com
please vote
Dec 20, 2009 | GE Profile Spacemaker Over-the-Range...
Why wont it power on?
probably a burned out fuse.
unplug it, open the case, and trace the power cord. There is usually an in-line fuse before the cord attaches to the main transformer.
buy a replacement in the hardware store, look for an old-style automotive fuse.
Oct 20, 2009 | Emerson MW8985W Microwave Oven
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Replace the grille and screws.
Jun 26, 2009 | GE Microwave Ovens
Emerson MW8102SS 1100 Watts Microwave Oven Logo
55 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
