Go to the Control Panel - find the "sound" icon and select it. Find the Properties Button (area) and update the sound driver. If this does not work, please let me know and I"ll send you instructions on how to "calibrate", "test", and enable your speakers. Also, let me know if you have external speakers, or if you're just using the built in laptop speakers.
carsandcomps,
Guru, Premium Expert @ Fixya.com
As you said your internal speakers are OK, then may be the problem with the external speaker. Check with another set of external speaker. if works fine then check your previous external speakers connection. if still no sound the neeed to check the motherboard.
Hi. Try plugging in an external speaker just to test the issue. It could be just the speaker of the laptop is having the problem. If you were able to hear the sound from the external speaker then the problem is the built in speaker of the computer. If there is no sound coming out to external speakers. Try to reinstall the driver of your soundcard.
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
you are try to get sound for external sound. maybe you put the jack in wrong hole ? or your external device isnot working. or your volume is not high.
try these pls. and notice us.
It's probably _not_ the soundcard (chipset), but the teeny little crummy speakers built into the T42. On a thin, light laptop the manufacturers have to make some compromises, and one of them is that they give you miniature speakers that aren't much good for music reproduction.
The fix: either uses earphones or plug in external speakers into the earphone jack. You can get pretty good, pretty cheap external speakers that give you fine sound.
You need to check that all the speakers wires are connected! It might be due to improper connections! This cause an resistance! And hence due to this the sound may be less or distorted. Check all the connections!
