Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound on tv or dvd
Turned tv off monday night. no sound tuesday a.m. Dishnet says it is the TV, Sharp/Aquos says its the tv. Techie says its a fuse. Must remove back panel. Unable to get panel off. Repairs to cost $500 plus or minus according to two repairmen I spoke with. They scoff at the idea of a burnt fuse. why? Also, techie told me the fuse is 1c33 0 ohm. What does this mean? Radio Shack didn't know wht I was talking about! Help!!
  • 12 more comments
  • winksy Sep 18, 2008
    The advice was not aimed at a solution. Rather it just said beware of repairmen.
    WE have tried that. There is no sound in the DVD either.
    Problem: 26-month old 37" Sharp Aquos Model# LC37D4U lost all sound. Same is true of the DVD player. There were no warning signs. I turned it off Tuesday night. On Wednesday morning I turned it on. No sound of any kind. Someone suggested a burnt fuse in the DM Board...or inverter board. I can't remove the back panel, however. Others opined that it was probably NOT a fuse. Serviceman gave me a $500 plus or minus estimate for repairs...but without any concrete ideas until he comes out here at a cost of $100 just to "look" at the problem. Help! Thanks!!
    Guru, how do I go about asking a tv techie to replace the defective board? thanks.
    tried that, unfortunately, still no sound.
    especially interested in mohammed 387's suggestion but lost it unfortunately. Resend, please?? Thanks!
    muhammed387 will you please repost your suggestions?? thank you
    the tv menu will not allow us to change the redirect outlook. We click on it and nothing hapens
    thanks. Is muhammed357 or is it 387? still out there? I found the advice interesting and would like to pursue it but accidentally lost it. thanks!
    no sound anywhere!
    tim nolan, how do i send you my email address?
    need to hear from tim nolan or mohammed357 [387?] please. thank you
    experttv, can we fix this ourselves or do we need to hire a repairman? Do we have to take the back panel off the tv in order to do this? if so do we need special tools? thank you!! winksy
    thanks to everyone who helped, especially mohammed387, experttv and maklean, etc.
    Genius:
  • 1,665 Answers
I think best way is to take it to an authorized service station to troubleshooting and estimate the cost and parts need needed to repair audio circuit. Normally the cost will be reasonable.
To troubleshoot yourself and replace components is difficult if you have no previous experience in repairing electronic printed boards and you must have at least some basic tools and instruments.
According to repair cost estimation you can have a correct decision what to do next. Good luck!
Posted on Sep 18, 2008
    Novelist:
    Champion:
  • 203 Answers
There is a knowen problem for this with your model and there is an update needed. I just fixed one of these yesterday with this exact problem. On the back of the audio out IC the heat sink fails and causes no sound. If you give me your email address I will send you the PDF file on what needs to be done to correct the problem. Let me know!
Tim Nolan
  • experttv
    experttv Sep 18, 2008
    post it on here or email me at experttv@comcast.net
    Scholar:
  • 147 Answers
There's usually only 1 fuse in a TV set, right near where the line cord attachs to the main board. If it's blown, you won't have a picture either. Since it sounds like you have a picture, it's not likely the fuse.
It may be something as simple as a loose connection from the audio processing chip or amplifier to the speakers.
If your TV has "line out" connections, you could try hooking those up to a stereo or computer "line input" using a pair of RCA cables to see if the audio chip in the TV is still working. If you get sound out of some other device, I'd guess the amplifier circuit needs attention - maybe a couple transistors need replacement. $5 for parts. If the "line out" is dead too, then the audio decoder chip may be cooked. Resoldering surface mount stuff like that is an acquired skill - best left to experts, who would more than likely swap out the bad audio board completely.
Also, there may be a setting in your TV's menu to redirect output - or even mute when closed captioning is enabled - that may have been accidentally changed.
  • 4,472 Answers
First off how long have you owned the television? The sound doesn't work on any of the inputs? You can still adjust the volume? Also make sure that in the options that speakers aren't off. If you still have a problem your only real option is to have it repaired by a professional. Unless you are willing to take a chance doing further damage. Being that you can't get the back off it is a job for a professional. If you still have any questions let me know. If you have a moment to accept and rate accordingly it would be appreciated.
  • Lee A.
    Lee A. Sep 18, 2008
    Not sure how maklean got the rating but good luck.
    President:
  • 1,952 Answers
It may be shorted out and that the fuse needed to be replaced. 1c33 0 ohm is fuse code number used in ur televisio..it may be 2-5amps fuse
Look inside the TV and see if you can locate any other large power transistors in metal (TO3) cans or plastic (TOP3) cases. There may be a separate transistor that does the low voltage regulation or a separate regulator IC. Some TVs have a switchmode power supply that runs off a different transistor than the HOT. There is a chance that one of these may be bad. If it is a simple transistor, the same ohmmeter check should be performed.
If none of this proves fruitful, it may be time to try to locate a schematic.
A blown fuse is a very common type of fault due to poor design very often triggered by power surges due to outages or lightning storms. However, the most likely parts to short are easily tested, usually in-circuit, with an ohmmeter and then easily removed to confirm.
If you find the problem and repair it yourself, the cost is likely to be under $25.
  • mohammed marika thambi
    mohammed marika thambi Sep 18, 2008
    it may be shorted out and that the fuse
    be under $25
  • 4,234 Answers
The audio circuits on these sets rarely have isolated fuses. There are a number of possible causes for this symptom. I'm assuming that there are no other problems with the set. Since you can not take of the back, there is little that we can suggest that you do. The $500 seems a bit excessive unless that includes a replacement board.
I looked up your model and the power suplpy board will net about $150 or so and the main board around $350. Given that the lack of sound is the only symptom, I'd recommend looking for a service shop that can do component level repairs. There should be no reason to change the entire board. The output amp chip may be faulty and should be available separately for a cost of $20 or so.
Keep us posted.
Dan
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
If by Dishnet, you are referring to Dish Network, that is most likely the source of the issue. We had same exact problem when phone line was hit by an electrical surge. We were told everything was wrong from the television to the telephone, to the phone line, etc. Finally, when we detached the DishNetwork equipment, we were able to prove that the DishNetwork equipment was at fault. It is connected to the main phone line as part of the agreement (something to do with DVR). At any rate, once DishNetwork was convinced (following verification by telephone company of all other phone connections), the DVR was tested online by their folks. They sent new DVR unit, we replaced, and all was well again. [Please allow me to add that I am NOT a television expert - I am relaying to you the facts of an identical situation in our home that occurred within the last month, hoping that it will be helpful to you.] Thank you!!
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
  • 10,594 Answers
I don't think with out schematics and proper work bench any expert can solve its no sound problem.
TV repair guy is good choice in such situation and if you think tv has worth to spend 500, call them. Do it yourself would be an adventure if you have no knowledge of electronics and could be end upon worse or mess.
I would suggest to buy required parts from HERE on comparatively low prices and ask tv tech person to replaced defective board.
  • Shahid Electronics
    Shahid Electronics Sep 18, 2008
    my suggestion is ask tv tech to identify defective board, get that board on my recommended shop on very low price and replace it. now pay tv tech service charges and save reasonable amount.
    I need bit info, do you get sound signal at Monitor out terminals of tv? you need to connect any amplifier type device to amplify monitor audio out signal.
    if tv has headphone jack, plug headphone and listen is there sound?
    Genius:
  • 1,550 Answers
If you look at the fuse again if it is blown then it is a draw issue on the power board a dead short that over draws amps.
So only techie might have told you about burnt fuse .
Regarding fuse 1c33 0 ohms
It is located approximately 2 inches behind the tuner The surface mounted part has various markings on
the original part from “105” to “F”
and is located below the board marking “7C32'
SAM ANDERSON
    Sergeant:
  • 399 Answers
If its the fuse its not that costly as the repairmen stated you.
as per my knowledge its some tracks short on the main powersupply board which are supporting the tv for producing sound.if the tracks are short the board has to be checked which track is short and the capacitors or ic on that track has to be replaced.and if the whole board is repaired that can cost you about $500 that is possible.but as you said no sound is coming so the whole board must not be faulty.and for the fuse it is located on the main power supply board it is very small and looks like mini tube light and made up of thin glass.and it is not that costly.
you can replace the fuse if you have the proper knowledge to open the tv.
feel free for any further queries.
thanks.
  • masterexpert Sep 18, 2008
    the fuses are very cheap they will not cost u much for replacement try that first if not worked then go for the board reparing.
    thanks.
    Genius:
  • 1,269 Answers
Try to disconnect first the Dishnet and play a regular DVD on your DVD player. Check if the sound works. From there you can isolate the problem if its the Dishnet that is causing the problem.
    Master:
  • 726 Answers
I dont no much about the tv you have but a tv expert will come along soon but i wanted to say looks like the repair guy is taking your money for a ride dont be fooled by them ok one of these experts will provide you with details how to get to the fuse and what that fuse ment
cya chris
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Sharp Aquos lcd tv
Check Dishnet setting System of your Dishnet It should be NTSC/PAL/SECAM select as per your country
Jan 21, 2010 | Televison & Video
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
LC-37D4U TV sharp aquos
Sorry, the only reason I have tv and video listed on my expertice is becouse of remote controls, people post them sometimes under wrong things so I add the whole thing to get the most problems.
ask another expert, use the find experts link on the front page, slinteriors should be able to help ya
Sep 17, 2008 | Sharp LC-37D4U 37 in. LCD Television
LC-37D4U TV
Is this a problem that just started or has been since you bought the TV ..Try going into the control pannel and checking your sound settings. Make sure it is not set to something diffrent on MTS (Mulit-channel Television Sound)Some times the sound gets switched while programing your TV. Make sure it is not turned on to SAP (this sometimes will happen and you will get NO audio) There should be several settings on these tvs for your audio ..Check to see if the "variable " is selected in "output select ". Also check to make sure your plugs to the outputs are correctly installed and if you have it hooked up to a home theater try turning it on , you may also wish to try to change the settings IE , tv , DVD , VCR ect on the home theater as sometimes they get pluged into the wrong input . If all else fails I would return it to place of purchace or call thier tech support at Sharp , ask for a supervisor ...
Sep 17, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound on Sharp Aquos 37' LC-37D4U
Call Sharp. They are fixing my 18 month old LC40C32U for free.
Jun 10, 2008 | Sharp Aquos LC-32D40U Television
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
200 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
