Question about Mitsubishi WS-65513 65" Rear Projection HDTV
How do you changea mitsubishi dlp tv lamp, bulb only?
How to change lamp
  • elegabilldel Mar 07, 2009
    How do we change a mitsubishi dlp tv lamp?
  • 203 Answers
A ws-65513 is not a dlp and does not have a lamp. Is WS-65513 your model number? If not what is it?
Posted on Sep 17, 2008
I still get a blank screen after replacing DLP chip and lamp. Any suggestions. Can you use cleaning duster to clean?
is the lamp turning on, if not then there may be a problem with the inverter board. or the bulb is faulty, bulbs can become faulty in transit.
Aug 04, 2017 | Mitsubishi Televison & Video
Tv won't power on anymore. i get a solid red light. why?
Solid red light means the lamp has failed. Try replacing the lamp first. Mitsubishi DLP TV Bulbs
These folks have the proper lamp you need and have a 6 month warranty
Sep 16, 2015 | Mitsubishi WD-60735 60" DLP HDTV
Mitsubishi dlp tv wd65837 wont turn on.
Hello Ejaz,
You will also probably need to change the blown fuse for the lamp also located near the lamp. The blinking orange led is just showing that the circuitry cannot sense any light output yet!
Good Luck!
Rich Lilja
Mar 26, 2015 | Mitsubishi Televison & Video
What is wrong with my Mitsubishi Tv model WD-65638
Youre lamp has failed. you need a new lamp. 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi WD Televison & Video
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Jul 17, 2012 | Mitsubishi WD-60735 Projection Television
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
When the tv goes out can you purchase just a bulb or do you need to buy the lamp
you can't buy just the bulb
Jan 25, 2011 | Mitsubishi WD-65735 Television
My problem...
The lamp LED indicator light flashes?U used the tv alot at least two years,have not change the bulb?Must change the projection bulb.
Apr 24, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi WT-42311 DLP Bulb Replacement
Your access should be a a panel near the back or side. You will see that it is somewhat easily removed and should have maybe one or two screws. You will see the casing to the lamp. Go ahead and remove it. Now unscrew the old bulb and replace it with a new one. There is not a lot of screws holding it together. It's a fairly easy process once you find the lamp. You should see the lamp once the panel is removed.
Jan 14, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
638 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
