Frigidaire FTF530FS Front Load Washer Logo
Anonymous Posted on Sep 22, 2011
Ftf530fs3 no water - Frigidaire FTF530FS Front Load Washer
Dolf
Level 2:
Habit-Forming:
New Friend:
  • Expert 46 Answers
  • Posted on Sep 24, 2011
Dolf
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
46
Questions
0
Helped
10683
Points
110
1st check to make sure water is coming through the hose to the washer.2nd check where hose is connected, often there is a plastic shipping stopper preventing it.
I have LG refrigerator LSC27950, there is ice in the icemaker& when I press the lever I hear humming noise for water and clicking noise for ice, but no ice or water are dispensing?
The error code dH on your LG refrigerator is indicating a water supply problem. This could be caused by a few different issues:
  1. Clogged or frozen water line: The water line supplying the icemaker and water dispenser may be clogged or frozen. This can prevent water from flowing to the icemaker and dispenser. Check the water line and make sure that it is not clogged or frozen.
  2. Water inlet valve: The water inlet valve that supplies water to the ice maker and dispenser may be faulty or clogged. This can prevent water from flowing to the icemaker and dispenser. You can check the water inlet valve and make sure it is functioning properly or if it is clogged.
  3. Water filter: A clogged water filter can prevent water from flowing to the icemaker and dispenser. If your refrigerator has a water filter, make sure that it is not clogged and has been replaced recently.
  4. Water pressure: If the water pressure is too low, it can prevent water from flowing to the icemaker and dispenser. Make sure that the water pressure in your refrigerator is adequate.
You should first try to check the water line, water inlet valve, water filter, and water pressure. If none of these solutions work, please contact a professional technician or LG customer service to diagnose and fix the problem.
Dimensions for the Frigidaire Front Load Washer FTF530FS3
For a normal install, the washer is 36" H x 24 3/4" D x 26 3/4" W. If you install the washer under a counter with the top sheet, then it needs 34 5/8" to the bottom of the counter. The dimensions are given in the installation guide available from Frigidaire or Sears Parts Direct. See https://secure.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-Parts/user-manuals/manual-downloads/Model-FTF530FS3/1428/0153200?modelNumber=FTF530FS3&diagramPageId=&documentId= . A direct link to the Installation Guide is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/INSTL/L0709314.pdf . See page 3 with the Rough-In dimensions.
I hope this helps.
2answers
It will not steam. We put in a solution of vinegar and 2 parts water from a pitcher that filters water. Will this be considered distilled water or is distilled water critical?
Distilled water and filtered water are not the same. Distilled water is water that has been boiled then condensed so that most of the impurities that cause water hardness (Sodium, Calcium, etc.) have been removed. Filtering does not remove these which is why your iron will clog up much quicker. Same applies to your car battery, distilled water only! To clean it mix "Lime Away" with water about 1/4 cup with water every 6 months or so, then rinse with clean water a few times to get rid of the green color, steam until it comes out clear again..
1helpful
I have a Frigidaire front loading washer, model FTF530FS3. The dryer that is stacked on top of it just quit. I have discovered that the new model of the dryer for this type, now called Affinity is slightly...
I would bet the manufacturer has an adapter for just this kind of problem. I did an installation on a stacked unit with a similar situation and there was an offset angle piece that attached the base of the dryer to the top of the washer. The front had a molded plastic piece to allow the dryer to rest on the front of the washer. Hope this helps
2answers
What is bottle water
Bottled water. Generally bottled water is just a glorified tap water. However there are many things that go on to put water into a bottle. It is chemically treated things such as ozone is added.among other things as it can't just be plain water, some of these bottles have to remain on shelves for a very long time. But rest assured no one would ever do anything that could harm us, now would they. Some bottled water is actually really what we would hope it to be like some of the spring waters that are out there are actually from mineral springs. However in my personal opinion I think it's all the biggest scam in the world, we bay more for a bottle of water than we do for a liter of fuel to run our cars on & it's just water it falls from the sky for free. Think about it people.??????
Does not have much hot water gets cold fast
tank water heater? if so its because the water is much colder this time of year. water heater has to work harder to heat 40deg. water than 70deg. water in the summer. That also means as you use the hot water from the tank its replaced with very cold water. Causing you to have less hot water. Either get a larger water heater. Or even better go tankless and have never ending hot water and save money at the same time.
2helpful
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
4answers
Runs out of hot water
I wonder if you have this problem below caused by a drop in water pressure from someone flushing a toilet or a washing machine. I would call the company to remedy this issue.
17. What is a cold water sandwich effect? The term “cold water sandwich effect” is a term that is used to describe the introduction of cold water into the hot water supply line during frequent on/off operation of an instantaneous water heater. The cold water sandwich effect, when present, appears as a momentary drop in hot water temperature as it is discharged from a hot water supply outlet (i.e. shower, tub, or faucet). This phenomenon is present in the operation of all instantaneous, tankless style, water heaters, but is minimized with the high tech design of Rinnai water heaters.
The technology built into the Rinnai water heaters is designed to minimize the cold water sandwich effect. Rinnai water heaters are microprocessor controlled and when water flow through them ceases, they remain in a “ready to fire state” for approximately 1 minute. If water flow through a Rinnai water heater begins within the first minute following water flow stoppage, the water heater will fire back up within 1 to 2 seconds. This minimizes the cold water sandwich effect that would otherwise be experienced with a low tech tankless water heater. It should be noted that the cold water sandwich effect cannot be removed completely from tankless style water heaters. The safety standards developed to insure the safe operation of water heaters require a delay in the ignition sequence of all gas water heaters.
While the cold water sandwich effect cannot be completely eliminated from standard plumbing systems, it can be eliminated from plumbing systems that have a supply and return hot water circulating system. Rinnai has developed 2 methods to eliminate the cold water sandwich effect in residential hot water circulating systems.
The first (and preferred) method to remove the cold water sandwich from circulating systems utilizes a small electric tank water heater (powered up) that is used with a dual purpose. The small water heater acts as a mixing tank to eliminate the cold water sandwich effect from the Rinnai water heater and it uses its electric heating element to offset the heat losses from the hot water circulating system.
The second method to remove the cold water sandwich from circulating systems utilizes a small 2 to 6 gallon storage tank installed on the hot water outlet of the Rinnai water heater. This tank acts as a mixing tank to blend the cold water sandwich with hot water and eliminating its effect at fixtures.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
