Question about Welding Tools
Campbell hausfeld gasless 80a mig welder not working, just quit
My subject says it all, it was working one minute, then it quit, wondering why? let it cool down, still not working
  • bj69lat Apr 20, 2009
    I have a 70a mig from cambell hausfeld. It was welding fine then just stop working. There are no fuses on this model and I cant figure it out. I use fluxcore wire and have only used the welder 2 times. The duty light never came on but the wire feeds but will not arc. If you mess with it long enough it will spark every once in a while. Can the mig tip have went bad already or did somthing burn up inside?
  • 70 Answers
May have bad ssr or open rectifire or bad ssr controller or an open in the welding output circuit.
Posted on Sep 07, 2009
    President:
  • 1,263 Answers
There should be a fuse located in the back of the unit near the ppower chord. i would check this keep me posted
Posted on Sep 19, 2008
110 volt welder the wire stays energized even when the feeder stops and your off the trigger. Campbell Hausfeld flux 80. Any ideas?
That could be 2 things. Either the switch in feed assembly is bad or the relay inside the unit is sticking.
Nov 16, 2015 | Campbell Hausfeld Welding Tools
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
Jun 25, 2013 | Welding Tools
Parts and service manual for a campbell hausfeld welder auto stike 85
http://www.chpower.com/manualsearch/
They need the model number. They do not have their search set up to handle the model name unlike other manufacturers.
It will be on the ID label.
Jan 06, 2012 | Campbell Hausfeld Welding Tools
I need the gun for my 80 fluxcore mig welder
Hi:
Her's the link to the site; all you need to do is to input the model number.
Sep 28, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
The gun on my welder is broken and need to fine a new one the wire feedes thru gun to weld it is a cambell hausfeld mig welder
You could try Canadian Tire where you bought it.
If not there, check to see if the gun is replaceable by contacting the manufacturer through their website..
Mar 02, 2010 | Campbell Hausfeld MIG / Flux Core Wire...
Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
Aug 07, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
Welder work OK with flux wire, cannot get penatration in MIG mode
Are you using combination argon/co2 gas? You need a flow regulator and should have it set for about 10cfm. Note that this is different than a pressure regulator. The problem you note is a result of inadequate or improper gas.
Mar 10, 2009 | Campbell Hausfeld WG2060 Mig/Flux Versa -...
I have a Campbell Hausfeld MIG Welder 80, The wire will not feed,
Here's a link to the Campbell Hausfeld web page. Look under "Service Center" for "Find a Part." I hope this has what you need.
http://www.chpower.com/webapp/wcs/stores/servlet/chHome_10051_10001_-1
Feb 22, 2009 | Campbell Hausfeld RBWG202000 NA 70 Amp....
Welding Tools Logo
525 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
