Question about Refrigerators
Has LG fixed the problem I am reading about online regarding the interior lights remaining on while door is shut resulting in overheating/fire hazard with plastic housing?
  • DrDon40 Nov 25, 2008
    Intermittently, the lights in the refrigerator section of my LG French Door fridge (without ice on the door) stay on when the doors are closed. The light housing melted. An LG authorized service person installed a "fix," a bimetallic switch that turns off the light when it gets too hot. However the interior still gets hot and when the switch trips, it's dark in the fridge. Home Depot, where I purchased the box denies knowledge of the problem. Pretty soon I may get upset!
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    regarding model number __________________?
  • 1,543 Answers
There are service bulletins covering some models regarding this issue. If you post a model number I can see if your refrig is one of them.
Posted on Oct 05, 2008
We have a 4 year old LG fridge obviously out of warrenty. Repair man was just here. Why does LG wire lights into main board? Why does LG install TWO 60 watt bulbs (120 watts!!) when the notice in the...
LG issued a service flash about this very problem, so you may be in luck. The last one I did for a customer was paid for by LG.. In a nutshell, LG screwed up. The control board that the lights tie into has a bad relay, which causes the lights to stay on all the time. The fix is to get a new control board and a new light harness. The new harness has a thermal switch that shuts off the lights should they not shut off in the future. I'd try LG customer service and see if they can help you out.
Good Luck!
Sep 29, 2010 | LG Refrigerators
Lights stay on in fridge
HI. The door switch will be the culprit here.
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Dec 10, 2009 | LG LFX25960ST Stainless Steel French Door...
LG LFC25760SB french door light off but hot
try to replace the bulb/ door switch
Nov 13, 2009 | Refrigerators
LG LRFD22850SW light won't go out!
if you stay on the line and dont take no for an answer
they just might cover it for you
make sure you mention several times its a fire hazard
and just dont take no for an answer
Oct 08, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
The refrigerator light will not turn off when the door is closed. How do I fix that?
THIS PROBLEM IS A SERIOUS FIRE HAZARD!!! And, apparently, it's a common issue -- one we had as well. Remove the bulbs immediately and call LG, stressing the fact that it is getting hot in there.
For us, they sent out a replacement circuit board and cover for the lights because the original one had MELTED.
Oct 04, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
My LG refrigerator door switches work, as evidenced by the display panel turning on and off with pressing both switches, but the internal lights just stay on, even when the switches are both pressed. Is...
Same problem with my LG. Mine almost started a fire and melted a good part of the interior, I'm glad I was home to catch it. I called LG and they are fixing it for free, even though it is out of warranty. This makes me think it is a very common problem. Now going from what my repairman has said, it is an issue with a control board inside the fridge. It quits working and the lights no longer shut-off. The only solution is to replace the board. My repairman is going above and beyond for me and replacing the melted parts (obviously), the light housings, the door switches and wiring, the main board, and I think another board for the lights. Try calling LG and telling them the problem, they may help you out too. There really should be a recall on this, but I guess it will take a serious fire before that happens :(
Sep 25, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
LG Refrigerator--Melted Light Fixture
I just had the same thing happen yesterday. The Sears repairman has been and gone, and he has advised me that LG has issued a Service Alert for the problem. They have created a new panel for the fridges with a thermostat that measures the temperature of the lights and shuts them off if they get too hot. In addition, he is going to replace the motherboard of the computer in the fridge. I feel that LG should send notifications to retailers that sell this product and that every purchaser of these fridges made in 2006 should be alerted to this potential problem.
Jul 21, 2009 | LG LFX25960ST Stainless Steel French Door...
Interior light remains on when the door is closed
i believe this refrig, is produced by the LG corp, ofr kenmore, they do have a repair for this issue, ( i just changed one last month), which inckluded replaing hte light housing(the new one has a high limit thermostat to cutt off lights in case of this prblem) as well as replacing hte main control board behind the unit.scream safety issue!!!!!
Feb 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator Lights Stayed on, Melted Plastic and Stopped Cooling
The control board relay switch for the light bulb stuck in the on position and needs to be replaced along with the light cover and housing.  There is also a replacement light harness that has a high limit switch to shut off the lights if this happens again.  LG knows about this problem and if you call LG customer service, they will grant a one time warranty extension to take care of this problem.
Jun 09, 2008 | LG LFC25760 French Door Refrigerator
Lights would not go out,overheated and burned out
Yes it is a stuck relay. LG has also come out with a new thermal disk in the light housing as well. This will stop it from melting, but at times you may not have a light on when you open the door. Get the new board and it will solve the problem.
Sgt48
Nov 12, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
