Question about HP Compaq WF1907 Monitor
Wf1907 lcd monitor driver
When i turn the computer on a message appears locate and install drivers for monitor while installing device windows encountered a problem installing the driver software acced denied
  • 7 more comments
  • Shikonah Nov 02, 2008
    When Windows Vista starts, it puts up the general "hardware found" message about this monitor, but when I try to use the disk or let the computer search for an installation, it tells me access is denied.
    I'd tell the computer to not give me the message, as the monitor clearly works without being "completely installed" but that selection makes it stop working properly and I have to reinstall the driver to make it work again. It seems to be a software problem instead of a hardware issue. Any help is appreciated.
  • Anonymous Jan 15, 2009
    tells me access denied
  • Anonymous Jan 21, 2009
    mine says access denied and will not allow drivers to be installed
  • apast Jan 21, 2009
    my monitor goes in the sleep mode and will not come out unless computer is turned off and back on . Sometimes this does not work. Also wil not let me install drives, it says error and access denied.
  • 127markaz Jan 25, 2009
    Same as everyone else. My Monitor was purchased separately, but my computer is an HP and it came WITH setup info for the WF1907 as the monitor is an HP
    product also.
    I can use the monitor with the plug and play and should probably call it a day, but I am the ONLY user and THE Administrator. Why access would be denied anywhere is what is concerning to me with the computer. I've got others working on these issues. When I get the answer I will repost. Good luck!
  • Anonymous Feb 09, 2009
    I have the same problem but if you set it as a generic pnp monitor you can still use it and mine had a dvd playing issue until i did that.
  • Anonymous Mar 09, 2009
    I have the same problem but it seems to function just fine. Yet everyday, when I bot up, I get the message that the monitor driver needs to ne installed and when I click OK, I get the access denied, monitor not installed. I have not used my system to play DVDs. yet. Will I have a problem in the future? I hate to make any fixes that might cause other issues. Mine was just purchased (Monitor and PC) as a package from Best Buy.
  • Anonymous Apr 09, 2009
    Yeah, ditto.
  • jamescrisp May 11, 2010
    a message appears locate and install drivers for moniter HPw1907 WideLCD says access denied.
    Problem Solver:
  • 14 Answers
Ok so i was searching around the internet and found a similar problem with another monitor so for giggles i tried there method. This is the website where i found it :
The Secoind wntry has a download. Download it then extract the files to the desktop. Dont worry if you get errors when the program runs it will fix them, if they come up just press enter to keep going. Once the program completes install the driver again and it should work as it did for me.
If you cant get to that website heres the post from it:
"Ok, once again i checked updates for HP My Display/Drivers, and found this:
Here is a direct link to fix for "Access Denied" issue (HP LCD Monitors & Vista):
Download The fix contains 3 files including this readme. All must be in to the same folder.
  • readme.txt - This file
  • RestoreDisp.exe - Executable required to restore permissions. DO NOT RUN THIS FILE
  • DVRFIX.exe - Run this file in Administrator mode after reading the instructions completely
To perform the fix do the following:
  1. Extract all files in to a folder on your desktop
  2. Open the folder, right click on the DVRFIX.exe file and choose "Run As Administrator"
  3. Follow the on screen instructions. When complete, you should be able to install your drivers
If you find this helpful, please let me know.
I fixed this issue manually (from registry), about month ago.
But gladly i found this help file, by mistake. wf1907 lcd monitor driver - emotion-1.gif
There you Go, KD0BGA
Posted on Feb 19, 2009
Compaq WF1907 19" monitor backlights are on, but
Check the monitor on another computer to verify if using correct setting for this monitor will allow a clear image to be displayed.
In windows 7, the monitor should be detected and installed automatically.
What version of windows are you using?
Dec 25, 2010 | HP Compaq WF1907 Monitor
Sorry im using windows 7 32 bit and the auto recog works yet drivers are not installed! This is the message that appears in device manager! Any ideas?
That means that the hardware is recognized but you need to install the drivers for it to work properly, Right now it is working of the standard windows 7 driver
Dec 02, 2010 | ASUS PG191 LCD Monitor
I have downloaded driver for philips 170c monitor but when i go to zip file there is no driver there
These are the steps you need to follow to install the driver: Download from the link below:
Philips 170c Monitor
It is a zip file so you will need to unzip it into a separate folder. Once the files are unzipped you need to locate the 170C8.inf setup information file. Once you have located that file right click on it and you will see the option to Install. Click that and it will ask you to open it. Choose open.
If that fails you can do the following:
Installing a new device
1.Open Windows Device Manager. In the Device Manager make sure the device you're attempting to install is not already listed from past install attempts. If the device is found highlight it and remove it from Device Manager to prevent any conflicts during the install.
2.Once Device Manager looks ok reboot the computer.
3.As the computer is rebooting an install new hardware wizard should appear if Windows detects the new hardware using this wizard you should be able to point Windows to the folder containing your drivers either on the CD, diskette, or the folder containing the files you downloaded.
If Windows does not detect any new hardware open Control Panel and double-click the Add hardware icon to run the hardware detection wizard. During the steps you will have an option to tell Windows you have a disk containing the drivers for your new hardware device, at this point Windows to the directory containing the drivers for your device.
Once drivers have been installed reboot.
Nov 10, 2009 | Philips 170C4FS 17" LCD Monitor
No sound from monitor
Try to re-install your audio driver !! Also go to add and remove and remove media player and then go and re-install windows media player again( probably a newer version ) should work!!! swampratt200 AAAEEE!!!!!
Jul 21, 2009 | HP Compaq WF1907 Monitor
Cannot install: HP Compaq WF1907 Wide LCD Monitor Update.
I found in the folder of Hp the file that does the " UPDATES".
So, thanks for the offer to help me, but all is well now with me and the Hp UPDATES.
May 19, 2009 | HP Compaq WF1907 Monitor
Vison Monitor ( device installer error)
First you need to uninstall the driver for your old monitor. Then install the driver for the new monitor. With both drivers installed your computer is confused and shows the conflict as an error message. Hope this helps.
Dec 23, 2008 | Computers & Internet
My monitor
Try inside your Display Properties. Settings tab, Advanced button, Monitor tab, Properties button, Driver tab, Update driver and follow on screen instructions. Eventually it would ask you where the drivers are located (CD drive?).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 31, 2008 | ViewSonic VX2235wm LCD Monitor
No driver appearing in Vista
Sorry this is late but:
Unplug the monitor from the PC and then boot.
after you hear the windows starting sound wait for it to load everything up (say 1 min) and plug in the monitor
Windows then plays the "i have found an unknown device" sound and begins to search for drivers
Wait 5 min for it to do this and then shut down the computer with the power button.
Re boot
Monitor should work.
Note: you must be connected to the net for this to work.
- Adyhood
Dec 14, 2007 | Acer AL2017 20" LCD Monitor
Device not installed properly message
Try this:
Go to Device Manager, right click on the monitor, choose uninstall, reboot the computer. When Windows starts up again, it will look for a driver(s), and might find the right one. If it doesn't, choose Cancel (this will set the monitor driver to Plug & Play Monitor or something like that which should be fine). Now, when you boot up you should not see that message again because the correct driver loaded or you chose Cancel.
Good luck.
Jan 12, 2018 | Wintergreen CMV CT-723A 17" LCD Monitor
HP Compaq WF1907 Monitor Logo
644 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
