Question about ASUS A8N-SLI Deluxe Motherboard
Start up A8N-SLI Deluxe will not boot passed start-up screen
Make sure you are grounded and your PC is unplugged, then simply press on your BIOS chip gently but firmly and see if it moves in. I had the same problem as you, RMA'd the board and they tested it and said it was ok, right before I ordered a new BIOS chip it hit me, if I can take the chip out, could it be loose ? sure enough the chip moved just slightly, I then plugged my PC back in and turned it on, it's worked great ever since.
I know it sounds to simple to be a fix, but often times we look for the hard answers first.
I unplugged all of my drives, swapped out ram and even power supplies and it was a loose chip all along that not even the factory caught after an RMA.
Posted on Jan 01, 2009
I removed my second HD, and all other drive devices(CD, DVD, floppy, + USB mini SD). This did not allow me into BIOS.
Then I switched the Primary IDE connection to my second HD - This allowed me into the BIOS. I then changed the boot priority.
Returned the Primary IDE connection to my primary HD - now the computer starts.
First - back up all recent files before continuing (dah!!!)
Try restarting - Start up screen is crashed but computer still boots up
Connected all devices individually - start up each time - no problems
I think it's a "Gremlin"
Need to do more research
Posted on Oct 13, 2008
    Scholar:
  • 95 Answers
Try removing all IDE/CDROM/Floppy devices from the machine. Then remove extra PCI cards like modems and sound cards (if you have any). Then enter the bios, and reset the bios to it's defaults, and reboot. If that gets to the looking for OS section, then plug each device back in one at a time. Start with the most important devices like the hard drive and Cdrom drive. Then after testing that it still tries to load the OS after each device, you'll identify which one is preventing startup.
Steven
Posted on Sep 17, 2008
Asus a8n sli deluxe motherboard diagram manual?
Download page.
http://www.asus.com/Motherboards/AMD_Socket_939/A8NSLI_Deluxe/#download
You must choose an OS like XP. Required, but indifferent. Click on Manual and choose Global link.
Oct 14, 2012 | ASUS A8N-SLI Deluxe Motherboard
A8n-sli deluxe one long beep and end. Please help. Thanks
Hi krzysio007! If you hear a beep once you start the system and it does not go away, this might be the CPU fan not functioning correctly. Try disconnecting the fan, cleaning the connectors and then plugging it back again. I have a similar problem with a motherboard just like yours, and usually the beep goes away after it boots into Windows. Since this motherboard has an Award BIOS installed on it try these error codes: Here. Hope this helps you with the problem!
Feb 28, 2011 | ASUS A8N-SLI Deluxe Motherboard
Sata drive wont boot, at boot up it not reconziged
Go in the BIOS and set the SATA disks to be recognized as PATA (probably called legacy mode)
Nov 22, 2009 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
Boot usb cdrom a8n sli deluxe
Press Deleate key at boot enter bios goto boot settings set 1st boot devise as usb press F10 and enter to save changes
Nov 14, 2009 | ASUS A8N-SLI Deluxe Motherboard
Does ASUS A8N-SLI DELUXE support fan speed changing?
You can research *********** board and drivers at ASUS.com.
You may find a new BIOS update which controls the fan speeds and temp.
If not, you can find plenty of frreware which will handle *********** board.
Nov 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
Coolmaster cm690 asus a8n-sli deluxe
the boards today have real fine typeset near the connection pins but they are there
Jul 31, 2009 | ASUS A8N-SLI Deluxe Motherboard
ASUS EZ-PLUG not plugged in?
ASUS EZ_PLUG is optional for SLI mode...this model of your motherboard has an SLI that connect 2 video card using pci express...if this is only you problem for bugging the EZ_plug not connected,you can disable that in BIOS setup...
Oct 28, 2008 | ASUS A8N-SLI Deluxe Motherboard
Ram problems
Your memory should be in slots A-1 & B-1
You Asus board uses the Award bios. The link posted below will tell you what your beeps are saying.
http://www.bioscentral.com/beepcodes/awardbeep.htm
In your case do as I suggested above. I have two working
A8N-SLI Deluxe boards & the memory works fine in A-1 & B-1 slots.
Good luck & best wishes!
please vote.............................
Mar 14, 2008 | ASUS A8N-SLI Deluxe Motherboard
System wouldn't Boot
If your CPU or memory were an issue your Asus board would sound off with BIOS beeps. Asus uses the Award BIOS & you can see what these beeps mean at the link below. Regaurding your PC not able to boot is an issue with your PCIE/PEG video card-in relationship with BIOS setting & the SLI switch card mode that came with your board. When running 1PEG video card you must set this in the BIOS to Auto & you need your SLI switch card connected in its slot. By default, the EZ Selector card is set for a single graphic card. When you install dual PCIE graphic cards on A8N-SLI series motherboards, please make sure EZ Selector card set to the Dual Video Card side and properly inserted. Link to Award Bios beep codes: http://www.bioscentral.com/beepcodes/awardbeep.htm
Will come in handy.
Reading the FAQ's at Asus site will help you better understand your A8N-SLI Deluxe. You'll need to fill in the, "Please Select the Product" first: http://support.asus.com/faq/faq.aspx?SLanguage=en-us
Dec 05, 2007 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Deluxe Motherboard Logo
71 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
