Question about GE WSXH208A Front Load Washer
Wont spin locks and unlocks will not spin
    Problem Solver:
  • 7 Answers
I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Posted on Oct 26, 2008
LE error code has popped up & suddenly the control lock is on, I have pressed the control lock & it counted 3,2,1 & nothing happens, won't unlock & LE is still there
if the door locks and wont unlock
LE error
then your machine still has water in it from the last spin/ wash
i think its a blocked up waste outlet
or the pump is blocked up
you need to check the machine is draining correctly and in a timely manner.,..
or it will fail
you need to fully drain the machine then turn off the mains
wait 5 mins and the door will then open
then check the drainage...
Feb 08, 2015 | Washing Machines
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Mcahinw will not start.
Hi, Press and hold the DRAIN/SPIN button for 3 seconds. If the Control Lock feature will not lock or unlock the appliance,unplug the unit for AT LEAST 30 minutes in order to reset the main control board.
Apr 12, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Car doors wont lock with remote
Sounds like the rod that goes from the lock to the key came off. There is usually a little plastic clip that holds it together and they break and you get what you are experiencing. You have to take the inside panel off of the door to get inside it.
Jul 05, 2017 | Peugeot 406 Cars & Trucks
Peugeot 406 door lock barrel just spins and wont unlock?
hi.just try to oil the lock an try to take the key in and out and turning some times.
on peugeot this is a normal problem.
Jan 22, 2010 | 2005 Peugeot 405
DOOR WONT OPEN
Hi There
First of i want to tell you Merry X-Mass and a Happy New Year. I have this for you and hope this gets you in the right direction. Let me know how it went.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 15, 2009 | Washing Machines
Not spinning out, all icons flash, so therefore door remains lock
This is a major control fault within the chip set on the main control board. replacing this damaged control will fix this issue you are having at this time.
Jun 13, 2009 | Washing Machines
LOCKED UP AND WONT SPIN
POSSIBLE PUMP PROBLEM, REMOVE 3 SCREWS 7MM FRONT BOTTOM PANEL CLEAN OUT PUMP WHITE PLASTIC ,, THATS IT CLOSE IT BACK UP ...
Dec 31, 2008 | Kenmore Elite 45986 Front Load Washer
Drivers side door lock
is the lock mechanism siezed,or is the linkage disconected?
Jun 08, 2008 | 1999 Chevrolet K1500
GE WSXH208A Front Load Washer Logo
674 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
