Question about Mitsubishi WD-52525 52" Rear Projection HDTV
V chip code
How can i get this v chip code off my tv?
  • 927 Answers
Good Day;
Go to page 70, 71, 72 of your owners manual.
Good Luck, big IRISH.
Posted on Sep 28, 2008
How do i get the v-chip lock code to unlock the parental lock from my Mitsubishi model code ws-55413
Bypassing the V-Chip Lock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode
hope this helps
John.
Jan 11, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I HAVE A MITSUBISHI (MEDALLION MODEL TV).THE V-CHIP IS ON AND I CANT RELEASE THE V-CHIP BECAUSE A CODE IS NEEDED. IS THERE AN OVERRIDE CODE THAT CAN BE USED TO CLEAR THE VCHIP?
Mitsubishi sets use a four-digit code for a V-Chip locked program, view a locked TV, cancel the lock, or to enter the V-Chip lock menus. You can view the locked shows on the TV set by pressing the number 9 and QV buttons on the remote at the same time, whenever your code is requested. This process temporarily unlocks the TV and asks you to enter a new code.
Oct 02, 2008 | Mitsubishi Televison & Video
Rca truflat tv parental code is locked and channels are dark
Hello
Just unlock your RCA tv, by folloing the methods given below. One amoung them will surely unlock your V-Chip. After that you have to reset the V-Chip settings with an other code of your like.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jan 07, 2011 | RCA TruFlat 27F520T 27" TV
Mitsubishi parental unlock code???
Hello
OK.
Dec 28, 2010 | Daewoo DTQ-13P2FC 13" TV
NO HAVE THE CODE TO UNLOCK IT. RCA MOD. 14N26
Hello
Your TV has been locked I thinks. There is a way to unlock RCA tv, and you must V-Chip code and other things later.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
OK.
Dec 07, 2010 | RCA E13344 13" TV
There is a lock in the corner off the screen., how can i get it away. I dont have a manuel.
Hello
I think your TV has been locked, and you have forgotten the four digit V_Chip code you have entered earlier. If so there is a method to refresh the V-Chip code. The orginal code for the V-Chip, when the TV exits the factroy is set "0000".
You can set to this code by the following method.
Press the remote control keys in the following sequence, which reset the pin to "0000".
POWER OFF==> MUTE==> 8==> 2==> 4==> POWER ON.
TV will come with a fresh V-Chip code "0000", which you have to readjust to block any channels if you wants. Ok.
Nov 06, 2010 | Samsung TXM3296HF 32" TV
How to change the v chip code to a mitsubishi medallion projection tv 62
Bypassing the V-Chip Lock on most Mitsubishi sets:
Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it.
To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV.
To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
Good luck, and let us know how you made out with this TV set.
Mar 20, 2010 | Televison & Video
Sampo LME-17S1 TV/Monitor w/RC-235B Remote-V-Chip - No Code
Master V chip over ride code is 8,4,8,4,100 (use the 100 button not 1,0,0) you should be good to go!
May 23, 2009 | Sampo LME-17S1 Television
V-chip reset
I cannot find any way to reset it. You might contact the manufacturer.
Oct 06, 2008 | Durabrand DWT2704 TV
V-chip code forgotten
I found this to work on my Toshiba TV/VHS combo MV19M4 after trying others suggestions that had worked on similar models but nothing worked on mine. Maybe it will work for yours. Follow these steps:
1: Unplug the TV for 1 minute then plug it back in.
2: In the menu select "TV Set Up".
3: Move the blinking block to beside "V-CHIP Set" BUT DO NOT SELECT IT.
4: Hold in the number 1 button on the remote.
5: Hold in the volume down button on the TV.
Your TV will turn off. Give it a few seconds to reset itself and then turn it back on and you will have to completely reprogram your settings. When you go to the V-CHIP settings it will ask for your new code.
- Jenny
Nov 01, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
